Question about Dell Dimension 2350 PC Desktop
Problem with disk drive A:
When I put a disk in drive A: it reads fine. However, when I remove it and replace it with another disk, the computer will not recognize the new disk and even without the old disk in the computer it reverts back to showing only the files on the first disk. It's like a memory problem...it holds the first disk files in memory and doesn't recognize the new disk files. I've tried everything...I can only read a new disk by shutting down computer and starting fresh with the second disk. It's annoying...any ideas?
    Problem Solver:
  • 10 Answers
First, you should try to keep the floppy drive. If you can find one, I highly recommend getting the floppy drive cleaner diskette. They're hard to find now, but it's worth it if you want to continue to use your floppy drives. If cleaning it doesn't resolve the issue, next item to try is replacement of the floppy drive. You can borrow a floppy drive from someone, plug it in and test to side if it fixes the problem, if not, then it's either a motherboard issue (which I doubt) or a software/windows XP problem (more likely of the two). In which case I would recommend reinstalling windows XP to see if it fixes the problem before shopping for a new motherboard or a new computer.
Good luck
Posted on Jun 29, 2008
My aspire ax3400 wont load disks
Are you saying your CD/DvD drive does not read any disks? If so, are you using disks that a friend made (put music on it) or are you using store bought disks (purchased a music cd from a store)? Most computers have problems with disks made by someone else at one time or another.
Click Start/My Computer and look to see if your CD/DvD drive is showing up in the list. If not, that's the problem. Remove the Power Cord, Remove the Case, then remove the two cables that plug into the CD/DvD drive then put them back in securely. Sometimes the drive just needs to be reseated. Now see if the computer see it in My Computer and if it will Read your Disks.
When you boot your machine, look and listen for the CD drive to make a click and the light on the cd drawer comes on for a second or two. That means the drive is recognized by the computer.
If all fails, Maybe your drive is broken and needs to be replaced.
Mar 31, 2012 | Acer Aspire AX3400-U2022 PT.SE202.007...
Why my dvd /cd not work properly , in hardware it show the it is woorking properly , but if i put any cd and insert it then after its not read the data in cd
Does the led on the dvd/cd drive flash after you've put in a disk? Go into "My Computer" and check that the drive is indicated there. If it isn't, then you would need to check the drive connector inside the computer to make sure it is connected properly and that it is not loose. If the drive is indicated in my computer, try another disk, perhaps a music cd, and see if the drive reads the disk. If it does, that tells you that you may have some defective disks. If the drive is detected in my computer, and no disks are read by the drive, then I would assume the drive is defective and replace it. Good luck!
Jan 24, 2011 | Computers & Internet
When I t urn on my laci external harddrive I get a fast pace blinking light and when I put my ear to it, it seems that the motor wants to start running then nothing Just a constant blinking blue light!
It seems that you have a problem with the disk-drive inside the case. If it still is under warranty, exercise the warranty to get it replaced.
If not, then disassemble the case, and remove the disk-drive.
Connect it as a "slave" disk-drive inside a desktop computer,
to see if it can be read. If not, then it is "dead".
You could buy an identical disk-drive, and put it inside the case,
to construct a "new" external disk-drive.
Sep 28, 2010 | LaCie (300770) 250 GB Hard Drive
ITS NOT READING TE FLOPPY DISK
Try the floppy-disk in another computer.
If it can be read, the floppy-disk is fine, and your disk-drive needs to be replaced.
Dec 13, 2009 | Mitsumi (D359M3) Internal Floppy Drive
PIONEER DVD-RW DVR-106D will burn but won't read
i have the same problem ,but when i restart my pc ,i put the disk it can read without a doult .The problem is your disk drive can't read disk when it on windows mode ,using dos and it just fine,some kind of trouble appear cause i burn too much disk in a time and it can't read next time i open computer .May be your windows problem just restart wins then put the disk in ,if it appear the green light it mean it's reading then the green light off it's mean it had identify the disk and does read it
Jun 26, 2009 | QPS Que! CD-Rewriter CD-RW Burner
Dell Inspiron E1505 CD/DVD Drive reads only dell disks.
If the driver didnt fix your problem, your disk drive might be faulty , maybe the problem is on the disk drives lens this is very common problem 2 any other cd/dvd rom drives.
Jun 26, 2009 | Dell Inspiron E1505 Notebook
I have a WD external hard drive USB 2.0 750 GB. It was working just fine for many months, and suddenly, my laptop won't "read" it -- it's not listed/detected in "my computer." I thought there was something...
If the device is recognized and not listed as a driver in the Explorer, then the disk is not recognized as having been partitioned and formatted. You can use the Disk Manager to see if there is anything listed on the disk.
Start - > right-click My Computer -> Properties
In the management console, go to disk management and check your disks. The external disk should be there and then you can see the partitions and drives assigned to it.
If there is nothing on it, your MBR could be damaged, which needs to be restored.
Alternatively you could partition and format it, but then you'd loose the data on it, so that is a last resort.
I think a program called Acronis Disk Director Suite can restore MBR's. Have a look at this external hard disk troubleshooting article.
Jun 13, 2009 | Western Digital Elements powered by WD 320...
CD/DVD drive stopped working gradually
  1. Ensure the Drive is seen in MY Computer
  2. Try removing the upper and lower filters per this article: http://support.microsoft.com/kb/314060
If the drive is seen in BIOS and in MY COMPUTER, but will not read any media after running the microsoft fix and rebooting, then replace the drive.
Jul 06, 2008 | Dell Inspiron 4000 Notebook
CD drive does not read all disks
You might try going to the website of the printer's manufacturer. They may have drivers online that you can download, which will bypass the issue you are currently having. If this is not the case, you might see if the manufacturer of the cd drive has updated software for the drive. Maybe this is a known issue to them. Good luck.
Mar 17, 2008 | Gateway GT5220 PC Desktop
Problems with pc reading floppy after taking images
Hi JenneyLou, Install your software that came with your camera. Remove disk from camera and put in computer Open up the web page Go to "Insert Picture From File" Choose "A" drive Find the selected photo Choose and Click OK This will insert the photo. You can now resize to fit the page. Let me know if this helps, nightdiver
May 19, 2006 | Sony Mavica MVC-FD7 Digital Camera
Dell Dimension 2350 PC Desktop Logo
121 people viewed this question
Alun Cox
