Question about Northgate Computers & Internet
I have windows xp service pack 2 I keep getting the error message the my virtual memory is low. How do I fix it.
  • clark styx valencia
    clark styx valencia May 11, 2010
    how much ram/memory is installed in your computer?
    I assume that you got a little balloon in the bottom right-hand corner
    announcing that your virtual memory is low and that Windows is
    adjusting it. If this happens just once, don't worry—as the message
    said, Windows found a problem and fixed it. But if it happens
    repeatedly, it could be that your settings don't allow Windows to make
    the necessary adjustment. First, make sure your drive isn't overly
    full. In Windows Explorer, right-click the drive icon and choose
    Properties. If the amount of free space is under about 10 percent,
    you'll need to free up some space. You can use the Disk Cleanup button
    right next to the free space indicator, or manually move some files to
    off-line storage, or uninstall unnecessary applications—whatever it
    takes to get more free space.
    If low drive space isn't the problem, the virtual-memory settings
    may be wrong. Right-click My Computer and choose Properties. Click the
    Advanced tab. Click the Settings button in the Performance panel. Click
    the Advanced tab in the Performance dialog. Click the Change button in
    the Virtual memory panel. Whew! This setting is buried quite
    thoroughly! Look for the System managed size option, select it if it
    isn't already selected, and then click OK, OK, OK. That should end the
    warnings.
    sourcehttp://www.pcmag.com/article2/0,1759,208...
    President:
  • Northgate Master
  • 1,314 Answers
Go into control panel, system, advanced. Under system performance, click settings. Click on advanced and under virtual memory click on change. Make the initial size 1024 and the max size 2048. Click okay on everything to get out of there. Reboot your computer and you're done.
Posted on Jun 29, 2008
Machine check exception
it is hardware problem change power supply unit and try
May 16, 2012 | E-Machines eMachines Desktop PC
Windows XP Virtual Memory is low. How can I regain memory?
Virtual memory is "memory" on your hard drive, not actual memory. The best way to regain this is reboot and shut down some of the stuff that runs automatically when you DO boot up.
(This Virtual memory is space set aside on your hard drive that the processor moves data into and out of like it would put data on a memory module ... but in comparing the two, the virtual memory is SLOW.)
You can increase the size of your virtual memory to anything you want. Some say too large a allocation will slow you down and too little will cause crashing or slow opertion. You are 99.44% probably set to let Windows manage your virtual memory (default) at this time.
thanks for posting your question to FixYa.com
positive comments are welcome
a
Nov 02, 2009 | Gateway Essential 500 PC Desktop
Presario s6500nx wondows xp error message: " the instruction at 0x75606eb5 referenced memory at 0x0000008 could nnot be read.
If u have installed acrobat then uninstall it.
otherwise download the latest service pack and install it is free on microsoft.com for genuine windows.
increase the virtual memory
mycomputer>right click>advanced tab>performance settings>advanced tab>virtual memory click on change and then make the initial and max size 2500.
restart the machine.
Mar 05, 2009 | Compaq Presario S6500NX (DQ181A#ABA) PC...
When I am playing XENO Assault II, it crashes and says virtual Memory error, I have a 256MB ATI Radeon X1300 Pro video card, and 2 gigs of memory. I was thinking about upgrading my processor to a Intel®...
Virtual memory is actually part of a computer's physical memory that comes in the form of memory chips or RAMs. So what right? Well, it is a necessary evil and in order for your computer to run numerous programs simultaneously (at the same time), it looks for areas of RAM (Random Access Memory) that is not currently being used and it copies files over to what is called page files. This is simply a process that allows RAM to free up space and subsequently load new or additional applications. This process is technically called thrashing and the result of it can cause the computer to react somewhat slower in its functions. However, when the computer hard drive (virtual memory) which is slower than the installed memory chips wants to correct itself, it has to constantly swap between the RAM and the hard disk drive.
What Causes These Windows Out of Virtual Memory Error Messages?
  1. The first and foremost probability is that the Windows operating platform page file maximum file size - is too small. You may think your system has a large amount of virtual memory (RAM) because the person that sold you the computer told you so. Well, this may or may not be the actuality if page files are set too low and you are getting error messages. Obviously if you are getting an error message page files are being maxed out and something needs to be changed to correct the situation.
  2. There could have been a power failure or, you shut your computer off incorrectly which led to a file or files becoming corrupted and this subsequent virtual memory message beginning to haunt you. So the two lessons learned here is to have a back-up source of power and, to always get into the practice of properly shutting down Windows via the start button where it reads "Turn off computer" in lieu of simply hitting the power off button.
Okay, so now that you have an idea of what virtual memory is, system thrashing and how it suddenly became an irritant error message, what can be done to make things right in your Windows operating platform?
Realize that although Windows automatically sets both minimum (the amount of RAM installed on your PC + 300 MB) and maximum (3 times the amount of installed RAM) to its page file sizes if you do get that virtual memory error message - then you can do the following steps to increase these minimum and maximum page file sizes;
Re-Setting Windows 2000 virtual page file sizes
  1. Right-click My Computer , and than click Properties
  2. Within System Properties menu box, click Advanced
  3. Click Performance Options . Within this pane (Virtual Memory), click Change to increase the paging file. Take special note that your Windows 2000 minimal value requires at least 126 MB for debugging.
  4. After you change (increase) the setting, click Set, and than click OK to the following message you will receive;
  5. The changes you have made require you to restart your computer before they can take effect.
  6. Click OK to close the Performance Options menu, and than click OK to close the Systems Properties menu.
  7. When prompted to restart your computer, simply respond to Yes
Re-Setting Windows XP virtual page file sizes
  1. Click Start , right click My Computer, and than click Properties
  2. In the System Properties menu box, click the Advanced tab.
  3. In the Performance menu, click Settings
  4. In the Performance Options menu, click upon the Advanced tab.
  5. In the Virtual Memory menu, click Change
  6. Change the Initial and Maximum Value Sizes to a higher value, click Set and than click OK
  7. Click OK to close Performance Options menu, and finally OK to close the Systems Properties menu
Re-Setting Windows Vista virtual page file sizes .
  1. Click on the Start button, click Control Panel, click System and Maintenance, and then click System
  2. In the left pane, click Advanced system settings. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. On the Advanced menu, under Performance, click Settings
  4. Click the Advanced tab, and then, under Virtual memory menu, click Change
  5. Clear the Automatically manage paging file size for all drives check box.
  6. Under Drive [Volume Label] , click the drive that contains the paging file you want to change.
A CPU upgrade would be a good idea, the core 2 duo is a superb processor.
Also a bit more ram perhaps another gig or two? and maybe a 512mb graphics cards would be good for gaming.
perhaps a better power supply too as E520 was not really designed for gaming.
Feb 24, 2009 | Dell Dimension E520 PC Desktop
Low Virtual Memory problem
For some reason your CPU is not using your RAM for memory. It is going to the .pagesys file, which is a file on your hard drive that holds Virtual Memory. Virtual memory is only used when you run out of RAM. So here are your choices.
You are going to need to buy a copy of Windows XP or whatever operating system you want. Then you try two things: First Format your current hard drive to wipe it clean and reload Windows XP. That should clear up your problem if it is a software issue. If that does not work then it is a bad hard drive (but I don't think it is).
If it is a hardware issue, your hard drive is corrupt, then you will need to install a new hard drive and then partition, format and load WIndows XP. Either one of those options will get you running again.
Please rate this solution.
Jan 09, 2009 | Compaq Presario 5000 PC Desktop
Windows Virtual Memory Minimum is Low
fairly normal occurrence but you should have a look at your performance settings
go to control panel
double click system icon
click the advanced tab at the top
by performance click settings
in pop up window click advanced tab
at the bottom you'll see virtual memory
click change
most common option now is to set the radio button to system managed size
you should then ok each window.....
Dec 30, 2008 | HP Pavilion a620n (PC028A) PC Desktop
I need to increase virtual memory
I don't wish to sound rude but if you don't know how to do this, you prolly should just let windows continue managing it. A few wrong keystrokes can have major repurcussions
Jul 15, 2008 | Computers & Internet
BIOS update
1. Check your PC or motherboard manufacture for BIOS upgrade and upgrade BIOS firmware.
2. Try to start your PC in a safe mode by pressing F8 before windows starts. Then select a safe mode with or without network support.
3. If your computer starts in the safe mode, check if your hard drive is not full or close to full. If it is close to full you need to remove some data from your disk. Try to remove temporary files and clear your Recycle Bin. Restart your computer.
4. You might run low on your memory. If your PC doesn't have enough physical memory, windows is creating virtual memory by using space from your hard drive.
5. If neither solution works, try to run a "CHKDSK C: /R" from recovery console.
Good luck!!!
Jun 11, 2008 | Umax Computers & Internet
Computers & Internet Logo
50 people viewed this question
Top Northgate Computers & Internet Experts
Lee Eismann
Abhinandan  Patil
Abhinandan Patil
Brian Sullivan
Brian Sullivan
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
