Question about Kitchen Ranges
Teba Mini Kitchen (Oven & 2 x Hotplates). Left hand side hinge on oven door has come undone? Doesn't look broken, looks as if metal clasp inside has come off?
  • joc24 Dec 26, 2008
    taken oven door of to clean on my teba oven , can't get it back on
Did anyone ever figure out how to fix the hinge problem? My girlfriend has one of these ovens and the right side hinge is loose but i'm unsure of how to tighten it. The door won't close all the way, so it takes forever to cook anything.
Kinney011@gmail.com
Thanks!
Posted on Jan 01, 2010
I can fix most anything. i have one of these and would love to get another. how is it today? email me at rnb3875@hotmail.com. thank you , robin
Posted on Dec 04, 2008
Installing lower oven door on GE profile gas oven`
Removing or Reseating Oven Door To remove most oven doors:
  1. Open door to the BROIL POSITION, where you feel hinge catch slightly.
  2. Place your hands on both sides of the door near the handle.
  3. Lift the door up and away from hinges.
  4. If the door does not readily lift off, there may be 2 phillips head screws on the inside of the door down near the hinges that are holding it on.
To replace the door:
  1. Place your hands on both sides of the door near the handle.
  2. Resting door against knee, line up door with hinges and slip into place.
For instructions specific to your model, check your Owner's Manual or Installation Instructions. Download a copy of your Owner's Manual and/or Installation Instructions
Aug 11, 2016 | GE Profile 30" Self-Cleaning Freestanding...
What replacement parts should I order to keep my Kenmore oven door from just dropping down when it is opened?
If the hinge is not broken "Check the Springs".
They sometimes come off at one end or can be broken.
There are 2 one on each hinge. They are strong so be VERY careful.
As I remember they have a color code according to how strong that are according to the weight of the oven door.
The surest way is to get the MODEL NUMBER from the tag on your oven. The parts store will be able to look up the proper replacement.
I may be able to tell you more with a model number for Identification, the oven is likely a Whirlpool Product made for Kenmore. Let me know if you are in New York City area.
Hope this helps.
May 19, 2015 | Kenmore 47783 Electric Single Oven
Oven door keeps open ay ideas about the fault cheers
make this test and fix it. GOD BLESS YOU
Door Hinge
An oven door repair may be needed if the door hinge breaks or is bent out of shape. Oven doors have two door hinges, a left and right. On some ovens the same hinge is used, on other ovens the right hinge and left hinge have different part numbers. The door hinge sometimes is sold with all necessary parts and springs, other times the parts need to be ordered separately. An oven door repair for a door hinge is a relatively easy repair for a do-it-yourselfer.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Outer Door Glass
If the outer door glass is broken, it can be replaced. This oven door repair requires that the oven door be removed from the oven and layed down on a sturdy flat surface. The outer door glass is made of tempered glass. Use eye and hand protection when performing this oven door repair.
Nov 04, 2013 | Kitchen Ranges
Broken door hinge on Stoves 900dfa oven
STOVES 900DFa - how can I download the USER MANUAL and the TROUBLESHOOTING and MAINTENANCE MANUALS
Dec 30, 2012 | Stoves 900DFa Dual Fuel (Electric and Gas)...
How to re install oven door
There are two pieces of metal that are inserted into the hinge slots on the body of the oven, the spring (upper) and the hinge. Before you can re-install the door, you have to clip these two together by laying the door handle side down and then using all of your body weight to push down on the spring arm, using gloves and a wadded up rag to soften the impact to your hands, and then clip the two pieces of metal together using the little hinged clip on the hinge piece and the slot on the spring piece. When you've clipped these together on both sides, lift the door and insert the metal pieces into the two respective metal slots on either side of the oven body. when they're in as far as you can push them, use a flat edged screwdriver to release the clip and close the door. Good luck, it may take a couple of tries and be careful of the spring, because it can snap back and hurt you if the clip comes off prematurely.
Feb 20, 2011 | Thermador PGR366 Gas Kitchen Range
My viking oven door has literally fallen off the left hand side hinge - is this a diy FIX?
The door slides onto the two hinges and is held in place with two gravity operated latches. I'm not sure of the condition of your range but it sounds like the door was forced or lifted rapidly allowing the one side to release. The only solution I know of is to remove the other side and reinstall. The hinges have multiple locking positions so the next time you are cleaning your oven, open the door about 8 inches, find the small latches in the door hinge groove, and hold them upwards as you lift the door towards yourself.
The hinges should remain slightly opened. For installation, lower the door onto the hinge posts and pull it outwards slightly.
Oct 27, 2010 | Viking VDSC365-6B Dual Fuel (Electric and...
Apparently a spring on my oven door is broken (DCS-RG-4844GG). On the large oven door, the left hinge has no tension in it. I can latch the hinge to remove the oven door for cleaning. However, when I...
spring is broken on the side that is 'slacked' without return tension. may be necessary to get underneath the stove chassis. move away from wall, carefully disconnect the gas fitting after turning off the gas spigot. Pull away far enough from wall to 'tilt' the whole chassis rearward to access the underside. Technicians use a 'jack' to raise stove....
Dec 02, 2017 | DCS RGS-484GG Gas Kitchen Range
Oven door will only open approx.3" will not open any farther on the right hand side appears to be a problem with the bracket/hinge
take the drawer out. pull the oven door out of the brackets. open oven door pull up on door it will come out of the brackets. look at brackets where drawer was. on left an right one bracket spring is off copy from the one that is on
Aug 22, 2010 | GE JGBP26 Gas Kitchen Range
Dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Nov 20, 2009 | Stoves Premier 600EMa Electric Single Oven
Oven door does not close
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
Jan 06, 2008 | Jenn-Air JJW8230D Electric Double Oven
Kitchen Ranges Logo
703 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
