Question about Lexmark Office Equipment & Supplies
Colour ink is showing empty - Lexmark Office Equipment & Supplies
    Genius:
  • 2,785 Answers
Plz install a new one
Posted on Jun 30, 2008
"How do you reset the ink on your Canon MG 3200 printer when you have the cartridge"
Hi, its possible the cartridge nozzle was damaged on refil, or theres ink residue on the sensors, please be careful when cleaning with a soft cloth
Jun 21, 2014 | Canon PIXMA MG3220 Wireless InkJet MFC...
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
No colour print
If your printer is printing but the colour part of the document comes out blank, it ordinarily implies that your colour cartridge is empty of ink or yur nozzles are blocked. to confirm it is not a case of blocked nozzles apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low/empty or nozzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nozzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. In the case of blocked nozzles, the procedure may be repeated over to get results. If no results change the colour cartridge.
Oct 21, 2010 | HP PSC 750 All-In-One InkJet Printer
I have a hp 6500. It has started printing pink instead of black.
Either:
* printers mix in a bit of "colour" ink when you request BLACK,
so that the colour ink-jets do not dry-out. So, since your BLACK has become EMPTY, all you get is PINK,
or,
* some printers mix colours to produce BLACK-ish colour.
Check that your CYAN and YELLOW ink-cartridges have not gotten to be EMPTY.
Jul 17, 2010 | Office Equipment & Supplies
No coloured ink showing
Try to remove and reinstall Ink Cartridges while printer is ON. Be sure the it is lock in place on the cartridge holder. If same issue, power off the printer and unplug and replug the power adapter. Check if the error has gone.
Jun 18, 2009 | Lexmark P4350 All-In-One InkJet Printer
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Refill cartridges
This is normal.
Printer will warn the ink is getting low. almost empty very nearly empty....
then (in effect) it says if you want to use refilled cartridges you can but it may void printer warranty. Press yellow flashing button for 5 seconds to "release ink detection" (summat like that).
Printer will continue to print but shows the cartridge as empty. Its your responsibility to make sure you do not run out.
It does this separately for each colour - tedious for the pro9000 with 8 colours
Feb 14, 2009 | Canon PIXMA Pro9000 InkJet Photo Printer
Mp470 pixma
Do you still need help with this problem?
Regards,
Worldvet
Nov 01, 2008 | Canon PIXMA MP470 All-in-One Printer
Printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Dec 28, 2006 | Brother MFC 210C All-In-One InkJet Printer
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
