My sewing machine's stitch selector breaks into pieces..can it be fix?already went to the service centre but they said they haven't got the spare parts..Right now I can only sew straight line..
There are a few possible reasons why your Simplicity American Quilter SA2400LX is only stitching straight:
Stitch length setting: Check that the stitch length setting is not set to zero or a very small number. If it is, the machine will only sew straight stitches.
Stitch selector mechanism: It's possible that there is a problem with the stitch selector mechanism that is preventing it from engaging properly. You may need to take it to a repair technician to have this checked and fixed.
Tension setting: Make sure that the tension setting is correct for the type of stitch you are trying to sew. If the tension is too high, it can cause the machine to only sew straight stitches.
Timing: The timing of the machine may be off, which can cause the machine to not properly engage the stitch selector mechanism. This is a more complicated issue and may require professional repair.
If you are comfortable with sewing machine repairs and want to try to fix it yourself, start with checking the stitch length and tension settings. If those are not the issue, it may be best to take it to a repair technician for further diagnosis and repair.
It appears your machine is mechanical. Most likely the old oil has dried and is preventing the parts from moving--a very common problem with older mechanical machines. But, if that is in fact the problem, it is reparable. You just need plenty of patience, a bit of time, good quality sewing machine oil, and a handheld hairdryer:
Make & Model??? Sounds like the stitch selector mechanism is stuck. If it's a mechanical machine, you can try oiling the mechanics of the stitch selector with Tri-Flow Synthetic Oil and then heat with hand-held hair dryer.
sometimes u have to sew on scrap for a few stitches for the computer to recognize the stitching has been changed. Then it might break through Hope it works for you
Needs a service, the selector will be seized inside and will need to be lubricated and hope it comes good...if left too long, may never restore funtiion
try adjusting the top thread tension and see if that helps also try changing the thread. also change the needle--make sure it's the right needle for the fabric being sewed.
