Question about Back to Basics 600 Smoothie Plus Work Top Blender
Hi I bought a new boxed Rival HAB011UK Rival hand blender bit when I eventually opened the box, found it had the top part of the handel with the rubber switch and controls on it missing and also the whisk missing. Does anyone know where I can obtain these missing parts from. I am in the UK so will need the relevant voltage. Many Thanks Sue
    Problem Solver:
  • 16 Answers
Plz cont -- 23051554 \ 23095757
Posted on Aug 05, 2008
Broken Part
Hi, i read your are having trouble with the tap on your blender. We pulled our blender out of the box and used it for the first time and it leaked through the base, through the motor all over the bench top.
At first i thought the tap was leaking too, then I investigated a little bit and found it was leaking through the white tension clips on the inside of the black base.
Then i discovered that there is a recess for an "O" ring, which seals the glass jug to the black base thus solving the leak.
However there was no "O" ring in the recess and now I am trying to find a replacement one.
Hope this helps.
May 22, 2009 | Russell Hobbs 3902US Work Top Blender
Seal/Gasket missing on Braun Blender
Hi. There's only one common blender made by Braun, which has a triangular jug in either glass or plastic, but the locking ring and gasket are the same. It'd be a 4184, either a MX2000 or MX2050.
Auckland has a Service Centre:
0.gif Key Service Ltd
7D Echelon Place, East Tamaki, Manukau City Auckland
P.O. Box: 38569 Howick
Manukau City
Phone Country Code: +64
Phone: 09-916 0960
Fax: 09-916 0970
Service for: All products
Otherwise, you can locate Service Centres in Australia.
Apr 13, 2009 | Braun MX 2050 PowerMax Work Top Blender
Philips Hand blender
My wife picked ours up at a rummage sale, and we've grown to love the little thing for making single servings of banana milk shake. (half a frozen banana, cover with milk, a drop of vanilla, and about one minute with the hand blender blade!) When my youngest boys dropped ours, I gathered up the pieces of plastic that connect the attachments to the motor shaft, and carefully super glued them together. I then wrapped the plastic piece with fine nylon thread and a thin layer of super glue and placed it back onto the motor shaft, then let it sit for 24 hours. It is now permanently attached to the motor shaft and good to go. Too bad Philips doesn't care enough to support their customers with a part their engineers designed to break and save the rest of the product. I'll remember this about Philips products when I buy an HDTV.
Aug 14, 2008 | Philips HR1358 Handheld Blender
Krups Type Blender 577
Mine did the same thing. I am ordering a new one from America for around $5.
http://www.abtecparts.com/index.htm
I am in Australia and they deliver worldwide.
Caz
Jun 12, 2008 | Krups 572 Power Xtreme VI Work Top Blender
How to replace the rubber drive in Krups 572?
it's not easy. you will need a set of pliers, a flathead screwdriver, and a phillips screwdriver. first, remove the 4 rubber plugs from the bottom of the blender (just work them out with your fingers). second, use the phillips screwdriver to unscrew the 4 screws that were under the ruber plugs. the blender should come apart. right in the bottom center on the inside of the blender you should see a steel rod with a groove in it. this rod will run all the way to the top and be connected to the rubber gear drive on top. get a firm grip on the rubber gear drive with your pliers. place the flathead screwdriver into the groove of the steel rod and unscrew. it will be very tight, but eventually, it will give. you will most likely destroy the old rubber gear drive in the process, but the idea is to replace that one anyway. good luck!
Q. Mosley
Jun 09, 2007 | Krups 572 Power Xtreme VI Work Top Blender
Back to Basics 600 Smoothie Plus Work Top Blender Logo
166 people viewed this question
Top Back to Basics Blenders Experts
Mike
Are you a Back to Basics Blender Expert? Answer questions, earn points and help others
