My Plaroid DVD writer is not booting up on power supply.
  • 3 Answers
I dont understand the use of link to give you solution...
I can give you solution for a much discounted price or 15.45 USD.
Pl. let me know if interested.
Posted on Jun 30, 2008
I am facing the same problem with the LG DVD writer...my PC get shut down when a DVD is inserted in the writer.....what will be the solution????? from the reference power supply may be not able to...
1. To solve hang on boot
Move the CDROM behind the hard drive on the boot order
2. To solve freezes on drive reads
Update the driver from manufacturer
or
Change the windows read ahead method
http://support.microsoft.com/?kbid=132882
But again, sounds like need new CDROM drive.
So there you have it, a couple of different ideas on how to try to debug the problem and a likely solution that we all agree on: replace the drive.
Good luck to you!
Nov 08, 2010 | LG (GDR-8162BI) (GDR8162BI) Internal DVD...
My tv is plaroid 46"
Right now only the standby 5vdc power supply is working, you will need to do in-depth troubleshooting, visual inspections and voltage checking.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Oct 29, 2010 | Polaroid TLA-01515B LCD TV
When i plug my dvd writer to the power supply it keeps causing my computer to shut down and start back up then shut down again
It has gone faulty and is causing a power overload and this causes the PC to shut down, so it will not be damaged. Either the power supply Inside the DVD is faulty or the DVD, is.
Feb 27, 2010 | E-Machines eMachines Desktop PC
Usb dvd writer can install xp?
Yes you can use a usb external cd/dvd-rom to any operating system as long as the bios allows you to, most bios's have the capability.
When the external usb drive has been connected power up the mechine, in post it should tell what to press to enter your boot menu without entering your bios and choose usb drive to boot.
Jan 22, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Replaced IDE DVD writer with a SATA DVD writer. Powered up XP Pro system, but no drive letter shows up. There is power to the DVD drive, but the OS does not see it. No BIOS updates available from EPoX.
Check your bios settings. If you already have two SATA hard disk drives in your system the bios should also list your SATA DVD writer as third in the list. Make sure the bios list the DVD writer. Remember all SATA drives including SATA DVD drives are all seen as Masters. Check your Boot order settings as well. If windows sill does not list a drive letter for your SATA DVD click, Start/Run and type: diskmgmt.msc in the run window. Assign a drive letter to the drive manually.
Cheers!
Mike
Oct 22, 2009 | EPoX EP-4PDA3I-3 Motherboard
Dvd/cd writer, and dvd rom drive does not work
Check if you have both cables attached to the CD/DVD drive. There are usually 2 that needs to be connected: the SATA or IDE (that ribbon-like connector that goes right to the motherboard), and the power supply (a connector that has 4 colored lines going to the power box). Make sure they are snug, and if necessary, try changing them with others that are known to work (there should be lots of spares). If the CD/DVD light blinks or powers on upon boot, it means power line is OK, but data cable connection is bad.
Sep 06, 2008 | HP Pavilion (PN153AAR) PC Desktop
No signal, Gateway 506GR
Start by disconnecting the new DVD writer and verify all power supply connections are not shorted.
May 01, 2008 | Gateway 506GR PC Desktop
Blank dvd crashes pc
the drive may be bad the burner software may be corrupted you power supply may be bad (line-in to DVD writer) The IDE (ribbon) cable may be loose
Sep 19, 2007 | Computers & Internet
Won't do anything
take out the plug and let the set stand for about 30 mins.if that does not work take it to a tech for repairs.the problem is in the power supply or the motor.good luck.
Apr 04, 2007 | iLO DVDR04
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
