Question about Canon PowerShot A80 Digital Camera
Powershot A80 problem: green and red lights around subject
Subject has outline of green and or red and distorted shapes. tried resetting to default to no avail.
  • Swedie Jul 03, 2008
    Viewfinder shows purple and black distorted image that is not recognizable as an image. The problem started with discolored photos and has degenerated to no image, just noise. Tried new batteries, turning display off (results in similar picture as would be viewed on screen). Tried various different settings and smacking it. Nothing works. Thanks, Marie
Hello
Recharging the batteries seemed to solve it. Although I had not received the low battery warnning and this phenomenon had not occurred at other times when the batteries were low, it seems to have fixed the problem.
Thanks.
Posted on Jun 30, 2008
How to restore defaults?
sir you didn't mention that you need you camera to restore or your camera driver to restore well i will tell you 2 things number one you can restore by using recovery disk if you don't have download it from this link
http://www.user-guides.co.uk/download/powershot/powershota80/powershot-a80-reset-factory-settings.html
number to if you have your camera manual see it if there are any option and try to restore. if you don't have it download it from this link
http://www.marietta.edu/~mcshaffd/macro/revman/PSA80CUG-EN.pdf
Oct 11, 2010 | Canon PowerShot A80 Digital Camera
Distorted color on A80 screen
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jun 30, 2009 | Canon PowerShot A80 Digital Camera
Purple lines and more
Jun 09, 2009 | Canon PowerShot A75 Digital Camera
When I turn on my PowerShot A80 the view screen is distorted or blank. When I snap a picture it comes out black. I can still review pictures that I have already taken with no problem. I have put in new...
May 27, 2009 | Canon PowerShot A80 Digital Camera
Projection lights don't line up
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Flaw on LCD monitor
This is normal. It may be distracting, but what it is is light. If you notice, it happens when there are bright spots, lights, reflections. These distortions will show up in video so try to avoid aiming at bright things while in video mode. Another type of flicker will happen mostly in florescent light.
Before CCD image sensors, video camera used tubes and aiming them at the sun or bright objects would burn the tubes permanently so cameras have come a long way, but by the nature of cameras being devices that record light, it is hard to eliminate that effect altogether (similar to red eye...just can't be a perfect science due to human nature of having blood vessels in the back of their eyes that when bright light is shined into them, their pupils open and the red color is reflected and shows up as red eye...this is best fixed in a photo editing program. It is hard to totally prevent, but changing angles and not shooting directly head on at subject helps). But I digress...
If it is really distracting for you, here is the one thing I found helpful; recompose the shot slightly by moving yourself, the camera, the angle (doesn't have to be dramatically different, but try to have the sun or light source behind the camera). As you move around, continue to push the shutter halfway down (each time not continuously) to bring subject into focus (getting your green box or boxes that indicate proper focus). Sometimes the lines will disappear if you change your shot even very slightly.
Hope this Helps!
May 31, 2008 | Canon PowerShot A720 IS Digital Camera
Blurred and distorted view of the subject
Its possible that there is a CCD issue with your camera. I've been reading more and more people are having CCD issues with the S1-IS. The CCD is the part of the camera that captures the image, and usually they distort or do some funky things with the pictures. Its entirely possible they would knock something out of focus.
Nov 13, 2007 | Canon PowerShot S1 IS Digital Camera
Focus problems
There are settings in the menu to turn on the AIAF did you buy it used? maybe the settings need to be reset. If you have the manual there is a sequence you have to do to reset the camera to default settings. One thing to note this may or maynot be yoru problem. If the lighting is low and you have the correct settings the little box in the center will turn green. If they are not the box will turn yellow and beep a few times then give you a red number to indicate how much under exposed the image will be. When you need more light you should turn the flash on this is indicated by a lightning bolt on the display. If it is on then the image display will be corrected and then get brighter showing you an estimate of what it thinks the image will look like. Hope this helps
Sep 14, 2005 | Canon PowerShot A95 Digital Camera
Camera As Webcam
For those interested... It is possible to use a Powershot camera as a webcam thou it requires 2 softwares: 1)PSremote 2)Softcam Basically I used psremote to create a viewfinder on the screen and den use Softcam as a virtual video capture device to capture the image on the "viewfinder". I tried and tested on MSN and it works. For software or more indepth instructions, feel free to email me at ryanwhoo@hotmail.com with the subject "Powershot Webcam". p/s: I'm using a Powershot A80. Juz tot u might like to have more uses for ur camera...
Aug 31, 2005 | Canon PowerShot A80 Digital Camera
Canon PowerShot A80 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
