Question about Steinberg Cubase SX3 (502010600) for PC, Mac
2 tracks I have a alexis mixer or however you spell it. and it is soppose to be able to record 2 tracks at once and i can't figure out how to activate this in cubase sx. help please?
    Problem Solver:
  • 4 Answers
Press F4 to open device panel. there you must be able to select inputs and out puts fromyour alesis interface.
be in stereo or mono(check your alesis specifications to know how many mono and stereo inputs it has.
then when you create a new track on the right side of the sequencer window. you must see a input and uut put routing tab
so if you whant to record voice in one track select the inputs where your mic is plug
create a new track and select the other input
so for shure it will say alesis INPUT 1
alesis INPUT 2
alesis INPUT 3
and so on depending on how many inputs your devices haves.
you say it haves 2. but
are they 2 only in stereo
or two in mono
or one mono+one moni+one mono+mono
for a total of 4 inputs in mono mode and 2 in stereo mode.
i dont know witch device you have so i cant tell.
if you have any questions let me know
Posted on Jul 26, 2008
What is an Alexs dot used for?
Alexis (I assume you spelled it wrong) is one of the talk to boxes you see on tv, you ask it things and it answers if you have the service. follow the link if you are interested further. http://www.askalexis.io/
Dec 13, 2016 | Televison & Video
What makes an audio mixer better than a recorder?
a mixer has more inputs so you can control more tracks at once, and a mixer gives you better control over the sound overall
Jan 28, 2013 | Audio Players & Recorders
I can't seem to figure out how to record one track over another without a delay problem? I am using the behringer 1202 mixer into my computer. No problem recording but can't do multiple tracks. I'm new...
This is a common problem with digital recording. Simply put, it takes some time to convert analog (audio) to digital and then more time to convert it back. So, your playback track goes through conversion and introduces some delay. You don't hear this because you have no zero reference. Your recorded sound goes through the A/D converter and also incurs some delay. When you play them back together, you hear the difference in time from one track to another. Most pro recording programs have some method to minimize or cancel the delay like slipping the tracks so they all start together. Pro Tools just introduced a version that automatically does this. They have always had what it called "low latency" monitoring which attempts to keep the "shortest" digital/analog path so overdubs are close enough that we don't hear any issues. So, since you talk about the mixer but not the recording program, I can't tell you specifics but I'd look into the recording program for time alignment settings and options. If you have a manual for the recording program, try to look up latency.
Dec 08, 2010 | Behringer Rx 1202fx 12 Channel Line and...
Recording with cubase problem
Need to set it to stereo. There may be a switch on your mixer, and you will also need to change the settings in Cubase to record in stereo, not mono.
Jul 30, 2009 | Lexicon Omega Desktop Recording Studio...
Using the USB connection to send the stereo mix to a computer
You have to insert a track into Reaper "arm" it. If you can't figure it out, I'd suggest posting in the Peavey forums.
May 14, 2009 | Peavey 32fx USB 32 Channel Mixer
Don't know how to actually record
To record you need to first assign your input to a track, then arm the track for recording, and then press play + record at the same time.
1. So you would patch you mixer's output into an input on your DP01 (say input A). You can run some audio to set the level with the input level knob (located next to input A on the front panel).
2. Then to assign that input to a track simply press and hold the 'input A' button and then press the 'rec' button of the track you with to record on. The 'rec' button will flash rapidly to indicate that the input is assigned to the track.
(To assign the input to a different track you have to clear the input assignment from the first track and assign the input to a new track. To clear an assignment press the input assign key, A in this case, and the track it's assigned to will flash its 'rec' button. Hold down the input assign key and then press the flashing 'rec' button. The button will stop flashing and the input can then be assigned to another track by following step 2 again).
3. Next, to arm the track for recording simply press the 'rec' button for that track. The 'rec' button with flash slowly.
4. To begin recording press play + record together in the transport section and the 'rec' light for the armed track will stop flashing and light steadily. Press 'stop' to end recording.
This should get you started. The operation of the DP01 is actually pretty intuitive once you've gone through it a couple of times (which is one of the real strengths of the unit). You'll be multitracking like an expert in no time.
Cheers,
bd.
Nov 20, 2008 | Tascam DP01 All-In-One Recording Package...
Magix Audio Cleaning Lab 12
You certainly let the microphone or audio out volume during recording.
when you record from external source it is better to cut the volume master volume unchecking it in
the window mixer .
when no sound it amplifies itselfs and do a "larcene" I do not know how you spell it in english.
a mini effect like a micro doing that horrible noise when .. I thing you know what I mean.. :)
if not this, its a rca problem of quality of the cables, or the cables pass close to an adapter,
I've got this problem 'cos I have 2 mixtables chained and the cable was passing over the power
supply of one of my cpu.
Aug 04, 2008 | Magix Audio Cleaning Lab 2005 for PC
DJ EQUIPMENT
Lot of possibilities.
The DP-01 is like a mixer with built-in recording capabilies. You could plug your tunrntables into your DP-01 inputs, assign the inputs to tracks(channels) on the DP-01, and then output those tracks to two channels on your mixer (which would be connected to your PA.
Alternatively, you could plug the outs from your mixer into the DP-01 either by routing individual channels from the mixer into the DP-01 inputs, or outputting the mix into a single track (or into two tracks in stereo on your DP-01). Just assign the DP-01 inputs as usual to the tracks you want to record onto.
Those are just a couple of basic ideas. You could also route a DP-01 track (or the whole mix) back out the DP-01 send loop and through some external processors and then back to tracks on your DP-01, or you could do this through the mixer and then record the final result on the DP-01.
Jun 28, 2008 | Tascam DP01 All-In-One Recording Package...
I need more tracks!
Your preamp needs to have 1/4" output jacks which channel all of the mic inputs into these two outs. This isn't typically how a mic preamp is set up however. They often will have 2 ADAT outs which output all the inputs in stereo or some other configuration. You may have one that can do this, but if not you'll probably end up needing some kind of basic external mixer which can handle all of the individual outs from your preamp through the mixer's inputs and then you'd run the main outputs from your mixer into the two inputs on your Tascam DP-01.
Mar 31, 2008 | Tascam DP01 All-In-One Recording Package...
Multimix 8 USB
sounds like you ports on your computer got all messed up. you should call tech support on you computer and they can tell you how to fix it.
Jun 22, 2007 | Alesis Multimix 8 USB 8-Channel Mixer...
Steinberg Cubase SX3 (502010600) for PC, Mac Logo
108 people viewed this question
Top Steinberg Computers & Internet Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
 Grubhead
Grubhead
Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
