2003 Jaguar X-Type Logo
Posted on Dec 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 2005 x-type 2.0L V6 wont start. i parked it yesterday and prior parking it, it had lit the red battery warning light for about 20Kms of my trip. this morning when trying to start it wont start. please help.
Anonymous
Level 2:
Sergeant:
  • Expert 194 Answers
  • Posted on Dec 11, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
194
Questions
Helped
85016
Points
606
Replace the battery
Red lightning bolt warning light is on, also generator symbol is showing
Check your alternator voltage need to be 13.7 to 14.3 volt engine running
Cobalt wont start
some vehicles have a safety switch that if low on oil it will not start
Jeep cherokee 2005 wont turn over, auto & wont come out of park,
Sorry, but it is recommended to go to a service and make a diagnose. Seems that the automatic transmission has a fault.
1helpful
Parking Brake Warning Light On Cluster Wont Turn OFF
the red brake warning lamp will illuminate if a: there is a base brake problem (low fluid) check the fluid leve if low find out now where it is going, low or worn out pads/shoes, or B: the e brake pedal is not ruturing all the way up, try pulling on the release handle while pulling the pedal up, if that fixes it find out why the pedal is falling probably needs a new ebrake pedal or new cables
I have 99 frontier 4x4 v6 with atp light on engien wont get over 1500 rpms
ATP = Automatic Transmission Park Warning Light.
The light indicates that the automatic transmission parking function is not engage.
Shift the transfer control shift lever into the 2H, 4H or 4L position when the warning lights comes ON. __________________
Hi there; I've just started getting a "parking
The most basic check for this is - is your battery up to 100% efficiency. the handbrake module is notorious for faults with low voltage or voltage dips. Next is to check that the brake pads and cables are free and in good condition (pads not worn too far down) as these can cause fault indications. The fact that the park-brake still works and does not jam on or off would indicate that the major components are still working and may just need some attention and recalibrating. T o try a recalibration of the park brake - disconnect your battery for 10 Min's (make sure you have your radio code as this will be needed on reconnect) when battery reconnected follow the instructions on your driver display panel and see if this improves your problem. hope this helps - good luck.
Red warning squared circle with a exclamation mark in middle
Brake or Parking brake warning light. Any braking issues, Is the parking brake egaged (even just slightly)
Dec 03, 2009 • 2005 BMW X5
3helpful
2answers
Transmission locked in park..override switch does not work
There is a fuse that runs that Check your owners manual to find the right fuse
Top Jaguar Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Jaguar Expert? Answer questions, earn points and help others
