Question about Panasonic Computers & Internet
I have replaced the hard drive on a panasonic t2 laptop and the power now is problematic. When you turn off the laptop, you need to pop out the battery, reseat it then turn the device back on. Any ideas is there something that I need to reset for the device to work properly?
  • ctrai1 Jun 30, 2008
    Thanks for the reply - I have tried to change the battery - still does the same thing. The only thing that works is to take out battery and reseat then start up again. Sometimes it doesn't even shut all the way down - have to hold the power button until all the lights go out.
    Genius:
  • 2,028 Answers
A common problem with laptop batteries is that develop a dead short and will not allow the machine to start. Try replacing the battery.
Posted on Jun 30, 2008
  • Ryan Rogers
    Ryan Rogers Jun 30, 2008
    Also, if the machine will start and run properly without the battery, then that is the indicator that it's the battery and not the machine.
    Guru:
  • 1,894 Answers
The process you are doing now is itself a reset only.
i think this is a battery issue.
did you try a different battery?
The western digital T2 keeps blinking.
what blinks , be precise?
what part number drive, 1000 made.
what system is it IN.
what OS?
is this really a relic 2.5" laptop T2 drive
or did you mean a new 2TB drive SATA?
is it sata or Pata ? drive.? the p/n will tell me that.
all drives blink for activity. but that is with eye, looking at it, directly.
some controlers blink
some MOBO blink for same.
Oct 04, 2013 | Western Digital Computers & Internet
How to interface the hard disk with another computer for checking problem with which software?
Welcome to FixYa!
i hope there isn't any problem in your hard disk .
lets say if you have
hard drive 1 with problem
hard drive 2 without problem .
actually if you boot from hard drive 2 and the hard disk1 that you have trouble in , then you cant identify the problem.but only read the data from hard disk 1
O/S faults can only be identified while you are in the O/S. so my suggestion is
please tell us that what do you want to do with your hard disk. and whats the problem
Post a comment here and ill let you know .!
Apr 23, 2011 | Fujitsu (MHF2043AT) 4.3 GB ATA-33 Hard...
My Seagate Momentus 5400.3 80GB is not getting detected and message pop up as USB not recogonized. Kindly do the needful
The disk-drive inside the enclosure is problematic.
Open the enclosure, to get the model-number and serial-number from the label on the disk-drive.
Then, access Seagate's web-site, to check the warranty-status of the drive. If the warranty still is valid, they will replace it, at minimal cost to you.
If the warranty has expired, purchase a new, compatible, disk-drive, and transplant it into the enclosure, to "resuscitate" your device.
Oct 30, 2010 | Seagate Momentus 5400.3 Hard Drive
Missing system file
Yer with an external hard drive or a flash drive stick, copy the OS cd on to the drive then set the bios to boot from USB or OTHER DEVICE.
Jan 16, 2010 | Panasonic Toughbook T2 Notebook
Where is button to turn on wireless internet connection
see the operating instruction manual here :
http://dl.owneriq.net/d/d94ab07b-788b-41ca-8def-00135155738c.pdf
or read below :
For instructions on settings for wireless LAN and cautions during use, select [start]-
[Reference Manual], and refer to "Wireless LAN".
Before using a wireless LAN, turn the wireless LAN on using the following method (at
the time of purchase, the wireless LAN is set to [Off]).
Double-click on the taskbar.
2 Select your wireless LAN adaptor and select [General].
3 Select [On] for [Switch radio].
4 Select [OK].
The icon will turn to or ��
Oct 04, 2009 | Panasonic Toughbook T2 Notebook
Laptop fell to the floor and when it powers up a message pops up and says Operating system can not be found. What does that mean?
One of two possibilities:
1. Your hard drive popped out of place and needs to be reseated. Remove and re-insert the hard drive.
2. Or, more probable, the jolt of the fall caused damage to your hard drive and you will need to replace it.
Jun 28, 2009 | HP Computers & Internet
Power off
That is because of the invention of power saving modes, where a single touch puts it in sleep mode and a 4+ second touch turns it off.
Check the bios to see if there is an option under the power saving section. You may be able to change this function to suit you.
Jun 10, 2009 | Panasonic Toughbook T2 Notebook
Shuts off every 5 minutes after being turned on...
Well, I actually figured out what was wrong with mine.  It was actually my hard drive which was causing the reboot. It was still under warranty, so I had it replaced.
Sep 22, 2007 | ASUS T2 P4P8T WO/CD/MDM FM AGP8X GETH WIFI...
Computers & Internet Logo
37 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
