Question about PNY 4GB USB 2.0 Flash Drive - Grey/Black
2gb usb 2.0 flash drive
I have windows ep and i want to pull off my documents from my files . after i have plugged my flash driveinto the usb port what do i need to do then
    Problem Solver:
  • 13 Answers
I hope someone has helped you by now! After you plug your flash drive into your computer USB 2 port, your flash drive should appear in "my computer" as a drive. You can rename that drive by clicking once on the drive and then right clicking your mouse and selecting "rename" and name it Your USB or something that reminds you its the USB Drive.
Whether you rename it or not, all you have to do once your computer has recognized the USB drive is to open the folder where your documents are kept and either "move" or "copy" them to the USB drive. Remember that "moving" the files will remove them from your computer and transfer them to the USB drive. Copying the files will leave a copy on your computer as it copies the file to your USB drive. You can also right click the file with your mouse and move the pointer over "Send To" and choose your USB drive from the list and it will Copy the file to your USB drive.
Posted on Nov 19, 2008
How to install a USB flash drive
Just plug your USB flash drive into the USB port of your computer or other USB-equipped device and drag the files you want to take with you into the folder that appears on your screen. Your files are instantly transferred to your USB flash drive. To transfer the items on your USB flash drive onto another computer, simply plug your USB flash drive into the computer that you want the files transferred to, open the folder that appears on your screen, and drag the desired files onto the computer's desktop.
1.) Insert Flash Drive into the USB Port of your computer.
-Where is my USB port? It is usually found in newer model computers in a hidden compartment on the front of the hard drive and in the back of the hard drive on older computers. The port for laptops is found on the side or back of the computer.
2.) Wait for the hardware to automatically install on your computer.
After the hardware is installed, it is ready to use!
3.) In most cases, an Options Window will automatically open. Select "Open folder to view files" Click "OK."
Jul 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Please can you send me detailed instructions on how to use a kingston usb memory stick
The memory stick becomes another drive, when plugged into the USB port. Some sticks have a write protect, which is a teeny tiny switch. If the switch is in the protect position, you can read but not write any data to the drive. Often the drive will be listed after all of your camera card ports.
To view the drive press and hold the Windows key and press the letter E. and then release both. The available drives should show up there.
Nov 17, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How can I retreive my files from a kingston 4GB DataTraveler
plug the 4kg data traveller it into a USB port open windows explorer open the data traveller select the files copy and paste into my documents on your computer
hope this helps
Aug 08, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My DameElec 2GB is not working on my XP Computer
try installing the flash drive once through add new hardware wizard from control panel. it might fix the problem for you. also plug the device directly into the usb slot present in the backside of the computer.
Jul 17, 2010 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
How to use a flash drive
It doesn't matter to which USB port you connect the flash stick.
It should appear as an additional disk in My Computer, with a total capacity close to the rated one. To identify which drive letter is it, observe the open My Computer window and plug (or unplug) the stick - it will be the drive that appears (or disappears respectively) from the screen.
How to use it? I prefer not to use any special backup software, which I find not very intuitive. I just make folders that make sense for me, and copy the files (that I want to back up or transfer to some other location) to these folders.
Dec 29, 2009 | Computers & Internet
How do I copy files from computer on to flash drive
First connect your flash drive to computer usb port.
Then open my computer you find your flash drive as removable storage.
Then open it and minimize.
Then select files which you want to copy then copy and then again maximize flash drive then paste files there.
Let me know if you need more assistance.
Thanks.
Oct 04, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
2GB USB Flash Drive
Hi. Here are the steps:
1. Plug your flash drive into a USB port on your computer.
2. If you use Windows, the flash drive will appear as an icon in the "My Computer" window, with a caption along the lines of "Removable Device" or "Flash Drive". Note: Please wait the first time you plug it in - Windows needs to "discover" the flash drive, and will essentially set itself up to recognize the device so that it's usable. If you use a Mac, the flash drive's icon will appear on your desktop with similar captioning mentioned above.
3. You can double-click on the icon to open the flash drive and see its contents. You can drag files from anywhere into that window, or over the flash drive's icon itself to copy files into it.
Mar 20, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Usb flash drive not recognized when plugged into hub
data is lost,
test with H2testW'
fix with PD V1.08 B3
good luck !
Jan 25, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Am I supposed to just put the memory stick in the usb port in the front of my cpu? How long does it take before it's done. This is the first time I've ever purchased this.
Most of these portable memory sticks are all plug and play. This simply means they are ready to be used whenever and wherever. Just plug in the drive to your USB port and drag files into the listed hard drive. Just remember, do not pull this stick out of the USB port without pressing "safely remove hardware" on your start bar. Failure to do this can result in frying your flash memory. Best of luck!
Jan 14, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Stopped working COMPLETELY!!!!
Had same problem.
I wiggled back and forth the part that goes into the USB port and the drive was recognized and I could copy my files onto my hard drive.
I had this problem with a different make USB flash drive and used the same procedure to get the files back.
I think that some connection inside the flash drive works loose after a while.
I am not going to trust these drives for files storage, but only to transfer files.
Jul 27, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
169 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
