Question about RCA TruFlat 27F520T 27" TV
Programming I have lost my remote comtrol and need to get the TV to channel 3 which is not a regulat station in my area. How do I do this?
On the front panel hit the menu button. us the channel button to go down to setup. From there you can manually change the channel.
Posted on Oct 22, 2008
  • RCA Master
  • 1,689 Answers
You need the original remote to change anything in the menus of the set. With a universal remote, you can manualy change the channels, but you cannot sequence them or change any of the setups to have them work automaticaly.
All TV manufactures are like this.
Call the authorized service rep, and order a new remote, or find the original if you want to be able to use your set properly. Don't accept a universal remote, because this will not properly resolve your issue.
Jerry G.
Posted on Jun 29, 2008
Programming channels for TV viewing?
You can often find the digital channel numbers for your local stations in a guide like or . Alternately, check if the local stations websites offer a link to their schedule. This will usually list the channel/channel digital identity. Another source for the digital channel numbers are the antenna choice/position/direction guides. Look at or . gives the direction and signal strength for all channel transmitters in your general area. is much more conservative and will only give the strongest stations in your area. That conservative list assumes an external antenna and clear path between the transmitter and your antenna.
In my area, the analog channel 7 became digital channel 7-1 . However, the channels 12 and 16 now transmit at 43-1 and 46-1 . However, after letting the TV do the auto-search, they are 12-1 and 16-1 when I type in the channel numbers on my remote.
I hope this helps. I might be able to provide a list of your local digital channels if you add a comment with your general location.
Mar 04, 2018 | Panasonic TH-42PC77U TV
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2, stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
My TV remote comtrol will not work when I try. I need the code.
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Codes for orion TV are
Jul 27, 2010 | Brookstone 538744 Remote Control
Programming RCA converter box remote control with Phil/Mag TV---
Good day,
You should have the instruction guide. If not look below. It's there but look closely for the guide itself and how to increase it's size to readable.
Check on the back of the TV to see if there is a 3 and 4 setting, If so, set to 3.
With nothing connected to the tv, and using the tv's remote, scan for channels. It should come up with only channel 3.
Then using the remote with advanced options, set the the input to either antenna or auto.
Connect the antenna cable to input on the converter box. Using the supplied cable connect the output from the converter box to
the TV. Turn the TV on first, followed by the converter box.
Then follow the instructions.
Not really easy so you'll have to fight your way thru it.
Finding the right setting for the antenna will probably take the most time, requiring a station scan after each adjustment.
Dec 28, 2009 | RCA Televison & Video
I have lost the manuel and remote for my GE49GW948
Best thing to do is to buy a universal remote - preferably RCA/GE brand since it will work without programming.
You should also be able to get to the autoprogram function of the TV by using the front panel buttons.
Oct 19, 2009 | GE 46GW 948 46" Rear Projection Television
Programming a channel without the remote
autoprogram,or use channel 3 from the vcr.,and run the dvd into the vcr which can be set on channel 4 on the back on alot of them
Aug 22, 2009 | Proscan 32LA30Q Television
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
How to set the telelvision to use a dvd,
On the remote ther is a tv/av button. Turn the DVD on and press play and the press that buttom on the tv remote and you will see your dvd playing. Have a good day.
Aug 04, 2008 | Philips Magnavox 27MS343S 27" TV
Akai VSG285 video - I can't tune any TV stations thru to the VCR?
This sounds like a hookup or programming problem.
The typical hookup is cable/satellite box output to VCR antenna/RF input, then VCR antenna/RF output to television input. Since you are able to watch pre-recorded tapes, the latter is already correct. There are other ways to connect, using the audio/video outputs of VCR to audio/video inputs of the TV. Older or low end TV sets may not have these connections.
If by chance you are using an outdoor antenna (not cable or satellite) then the antenna connects to VCR antenna/RF input and VCR output as above. You will also need to program the VCR into the stations- most late VCRs will scan for active channels, and program themselves to those channels.
I'm not sure of the capabilities of newer cable & sat boxes, but generally, you had to tune that box to the channel you wanted to record. The VCR is set to channel 3 or 4 depending on the output of the cable box.
Lastly, most VCRs of the last 10+ years require the remote to setup advanced functions, such as timed record, date & channel setup functions. The buttons on the VCR itself only do very basic functions, Stop/Play/Rewind/F-forward/Eject etc.
If you don't have the orig. remote, some universal remotes may be able to do advanced programming functions.
Apr 09, 2008 | Televison & Video
Programming my rca universal remote for basic cable the stations wont turn
I can only suggest that you Double check you have the connections correctly set ie. coax ariel to ,(dvd /digi box reciever ect...)
Also check again (& i know this is state the obvious)
your tv manual. IF you havent a manual do a google search for your tv (make & model) & search for a manual.
Ive have had a simmular experience when programming channels to a Vid-Recorder & when i finished the channels dissapeared.
I realised I didnt have the video set to the correct channel with the tv usually channel 9 or the highest channel on the tv.
So i waisted a good half hour for nothing.
Dec 09, 2007 | RCA Universal Remote Control
RCA TruFlat  27F520T 27" TV Logo
85 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
