Question about Mitsubishi WD-52631 52" Projection HDTV
Wd 57731 First had issue with air flow message on screen. had problem resolved under warranty. Just yesterday 6/28/08, had trouble code 66. Technician replaced burnt out bulb controling screen. Now tv will turn on for a minute or two, then shut down with the red lamp light indicator lit up. Checked for trouble code and #34 popped up. What is this code?
  • Mitsubishi Master
  • 8,617 Answers
Thats a lamp abnormality, sound like the two 3300uf caps on the PWB PCB need replacing
Posted on Jun 30, 2008
Affinity error code 10 what it mean
Hello Jose, thank you for your post!
If you are receiving an error code E10, it typically indicates that your washer is experiencing an issue with the fill time. Here are some basic troubleshooting tips to help resolve this issue:
·Is the incoming water flow normal? If it is, does the fill water continue to enter your washer? If yes, disconnect power from your washer. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
·If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
·If you have checked all of the above, your washer may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
Hope this helps! - Z
Aug 02, 2014 | Frigidaire Washing Machines
Low flow message on balboa 500z system
The low flow message on any Balboa means that you are having an issue with the flow of water through your heating unit. This can be caused by a few things.
  • Low water levels
  • Dirty filters
  • Something is impeding your water flow
Top up your water level and make sure it is where it needs to be, clean your filters or replace them, and check that nothing is impeding your water flow at the skimmer or water intakes.
Here is a link to water flow issues.
F2 Error Code Trouble Shooting
Dec 24, 2013 | Intex 2500 Gal Easy Set Swimming Pool...
I have a code 66 motor runs rough and idles up and down check engine light when sshift in 1st gear bucks and jerks stalls out
Code 66: Mass Air Flow sensor circuit below minimum voltage.
I recommend you replace the MAF sensor
Apr 27, 2011 | Ford Mustang Cars & Trucks
Kenmore dryer will only work on no heat cycle...any other heat cycle will give pf code. md number 417.84092500
The Kenmore H5T is an electric clothes dryer meant for residential use and manufactured by the Kenmore Company, which manufactures a wide variety of appliances for the home, including refrigerators, dishwashers, microwaves, stoves, and clothes washers and dryers. While most Kenmore clothes dryers work well with only basic care and maintenance, certain problems, such as the dryer not heating, occasionally occur. Troubleshooting this issue may solve the problem without the help of a service technician.
instruction
  • Ensure that the dryer is properly connected to a working grounded power supply. Confirm that the power cord is plugged firmly into the dryer and the power outlet. Reset household fuses or circuit breakers if necessary.
  • 2 Remove the lint screen from the bottom front of the dryer. Pull off all lint so that the filter screen is clean, and replace the lint screen in the dryer.
  • Run the dryer for 5 minutes on a normal cycle and hold your hand under the outside exhaust hood to feel for air movement. If there is no air movement, turn off the dryer and unplug the unit. Disconnect the exhaust vent and clean out any possible obstructions, such as excess lint. Reconnect and confirm that the vent is not kinked or crushed and preventing proper heated air flow.
  • Ensure the dryer is not in a room or outside with ambient temperatures below 45 degrees Fahrenheit. The dryer will be unable to heat properly if the ambient temperature is too low.
  • Avoid overloading the dryer with too many clothes, which will limit proper heat and air flow in the dryer. Make sure the dryer is not set on an "Air Only" dry cycle, which does not provide heat.
  • Contact an authorized service technician if the preceding steps do not resolve the problem.
  • Dec 20, 2010 | Kenmore Dryers
    Hi, I have a Konica Bizhub C451. There is a trouble code C-3824.Any advice to resolve the issue? Thanks Chris
    Chris,
    Turn off main power inside front cover insure that the sub power switch is pushed in on right side of the control panel. Hold down the Utility/counter button and turn on the machine hold down until screen shows trouble reset touch trouble reset go OK. Power off then wait 10 seconds power on. If the code comes back do not attempt another reset you are resetting the code for the fusing unit (The hot Part) It can catch on fire and that would ruin a perfectly good day! Have a technician look at it Good chance fusing unit needs replacing
    Nov 03, 2010 | Konica Office Equipment & Supplies
    Error message F-28 and F-21 on an He2 Plus Washing machine Under warrantee
    "F28" is a Serial Communications error code. This is an interruption in communicaitons between the Central Control Unit (CCU) and Motor Control Unit (MCU, or the interconnecting wiring between the two.
    "F21" is a Long Drain error code. This is usually an indication that something is restricting the drainage system. Commonly, the drain pump reservoir, or inlet line running from the wash tub to the drain pump is clogged.
    Since your washer is currently still under warranty, I would strongly recommend you call for service and have a technician resolve these issues for you. Any attempts on your part to disassemble the washer and make any repairs may void your warranty.
    The "F28" error code in many cases is caused by a defective CCU which would need to be replaced. Replacement cost (if not covered by warranty) can exceed $200. The "F21" error code, in a worst case scenario can be caused by a drain pump failure. Replacement cost (without warranty) can exceed $150. If the washer is still under warranty, and if any of these parts are found to be defective, they should be replaced at NO cost to you. Honoring your warranty makes better sense in this case.
    For a full explanation of these error codes, you can refer to your tech sheet located inside the washer behind the lower toe panel. You will need to locate and remove the screws under the bottom front edge of the toe panel. Once removed, the panel will drop down, then come off. If the tech sheet isn't located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all error codes, test points, diagnostic procedures and helpful illustrations to assist in troubleshooting and repair of your washer.
    NOTE: Removing the toe panel to retrieve the tech sheet does NOT constitute disassembly and should NOT void any warranty coverage.
    If you have any questions/concerns, please post back and let me know. I hope you find this information helpful.
    Oct 06, 2010 | Kenmore HE2 Plus Front Load Washer
    2001 malibu shifts rough
    code p0113 means: IAT sensor high temp
    and the solution:
    The Intake air temp sensor is located inside the air flow meter and uses yellow and black wire and the black wire. IAT sensor circuit code P0113 indicating excessively high voltage or (Open Circuit) the ECM is either not seeing the correct voltages at terminals 66 and 80 under the dash at the ecm. It could be as simple as a broken wire under the insulation right at the air flow meter, Or a little worse a bad air flow meter. There are cheeper remanufactured Aair flow meters available at Nissan for your car around $150 instead of $400 like they used to be new.
    Jun 26, 2008 | 2001 Chevrolet Malibu
    Yellow spots are appearing in the upper right quadrant of the screen. After the set has been on for a couple of hours a second spot appears in nearly the dead center of the screen. This issue coincides...
    Try the new lamp as indicated by the blink codes. That may resolve the problem. If not, the problem is in the "light engine" portion of the set which should be covered under warranty.
    Keep us posted.
    Dan
    May 29, 2008 | Panasonic PT-52LCX65 44" HDTV
    I keep getting an error message- unable to clean....I just bought and installed new ink cartridges, and the machine is still having trouble - I cannot print at all now. There seems to be no way to clear...
    The waistinktank has to be replaced. DO NOT only reset the code but change the waistinktank! Otherwise ink will flow into the machine and will cause serious damages!!!!!!!! See link how to do that: http://www.fixya.com/support/t202485-cleaning
    Oct 05, 2007 | Brother MFC 420CN All-In-One InkJet...
    Error message
    Canon has a decent trouble shooting guide for this model: http://tinyurl.com/rgu6o Click on the Step-by-Step Troubleshooting link under Tech Support Unfortunately for this error code, all it says is this: Turn the machine off, and remove the power plug from the outlet. About ten minutes later, plug it in again, and turn the machine on. If the problem is not resolved, the machine may require servicing. Please contact your local Service Center.
    Sep 14, 2006 | Canon Pixma MP500 All-In-One InkJet...
    Mitsubishi WD-52631 52" Projection HDTV Logo
    264 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
