Question about Epson Stylus CX7800 All-In-One InkJet Printer
Keeps printing old information
I can not remove this information...even when I push the stop/clear settings button......won't except knew information from the computer but continues to print old information
  • Epson Master
  • 541 Answers
You have a back log of prints
Posted on Nov 17, 2008
I PUSH THE START BUTTON THE GAME KEEPS ROTATING SCORING POINTS AND WON'T STOP
You might want to repost this in a different section, even video games.
Jul 26, 2012 | Cars & Trucks
Only prints first job - can't delete from que
Please try this approach instead:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
I hope this information has been helpful.
Dec 20, 2011 | Lexmark X6170 All-In-One InkJet Printer
Hi. I noticed you said you knew the Casio TE2000 cash register and hoped you could help me. I bought a second hand TE2000 with a manual and I want to clear the memory and change the trader name and message...
Turn key to Program mode2 SUBTOTAL
132 SUBTOTALNow type the characters for the first line of the receipt 00 (double zero button)CASH (maybe labelled CA/AT)232 SUBTOTALNow type characters for second line00CASH332 SUBTOTALNow type characters for third line00 CASH432 SUBTOTALNow type characters for fourth line00 CASHSUBTOTALTurn the key back to REG mode.
There is a good reason why they don't want you to clear the whole memory. You will lose country, tax, monetary settings plus lots of dealer settings. It is best to edit the old program to suit your new business. It will be much easier and quicker. To reset the report, turn to Z mode and press CASH. That will clear out the last daily report. The only thing you can't clear is the grand total. That is a security issue, so it always keeps adding, but you don't need it. Your other figures will be correct each day. Some machines allow you to turn the GT printing off if it annoys you.
If anyone needs more information, the Casio TE-2000 manual is here:http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2000_users_and_programming_manual.html
Oct 07, 2011 | Casio Parts Cash Register PC Desktop
How do I turn off protocol monitor on sharp fax model fo-235
Had exact same problem on UX 177. You need to clear the memory. On the UX 177 unplug machine, press and hold down the COPY button then press and hold down the STOP button. Keeping these two buttons pressed plug machine in. It should display message "clear memory ?" let go of the COPY and STOP buttons and press the START button. Will then display message "memory cleared". This will also wipe out all other programming but it is the only way to stop protocol report. Then reprogram all your settings.
That stopped protocol report printing after each fax. On some machines it may be the stop and start button the need to be held down on startup. It also seems to make a difference which button you push first even though machine is unplugged.
This problem returns after a power failure so if you have a lot of numbers programmed in you might want to get an inexpensive uninterruptible power supply or plug fax into UPS for computer if you have one.
Mar 03, 2011 | Sharp Office Equipment & Supplies
After I press the Stop/Delete button...the ''resume '' (button which never has lit up), doesn't light up when I push it, and if I push ''print'' to print something new,it keeps reprinting the pages I have...
Have you tried resetting the print jobs in the system monitor screen? Or try just powering off the copier completely with the main power switch. Depending on the Canon model you have to clear the print/copy job from the sysem monitor screen.
Oct 18, 2009 | Canon Office Equipment & Supplies
Printing issue
If command was with computer and you print mode of the printer, do stop by way of the removing the task sent on printer, from panel printers nominated printer afterwards remove problem, but if in mode of copying, push all reset buttom unset or removing the mode of the printer and translation on copying
Sep 13, 2009 | Canon ImageRUNNER 330s Copier
Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Printer won't stop printing garbage
Try and re-install your printer drivers...first remove the drivers and delete the printer...then re-install.
Dec 03, 2008 | HP DeskJet 812c InkJet Printer
Prints without a command
it might be because of two reasons,
one is , check ur printer buffer, it might be restarting some old prints..
but, the prob might be the second as explained below
u might have installed some software , which might be running in the backround, and in tat , if some button or key is being assigned to print screen, then, when ever ur pressing tat key by mistake, or unknownling, the problem is occuring, so check ur backround softwares...or even installed softwares..
Pls, let me know, i f it works...
Jul 16, 2008 | HP Officejet 5610 All-In-One InkJet...
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Epson Stylus CX7800 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
