HD-T5676S picture problems
We have stereo speakers in the room but they are at least 5-6 ft. away. Also, they have been there from the time we got the TV.
  • dacbird Jun 29, 2008
    I feel assured that you have the problem nailed down. I will pass along this information to the tech. Thank you for sharing your expertise.
  • 243 Answers
Interesting There is a few problems it could be from the IC's that are used for convergence and horizontal hold and vertical hold. could just need a manual alignment but youd want to change these capacitors. there a capacitor at the back of the main board, next to the rear rca inputs. Labeled 10uf 100v.Here are a couple of photos of the part.
photo 1
photo 2
Posted on Jun 29, 2008
  • 2 more comments
  • Nathan Ayers
    Nathan Ayers Jun 29, 2008
    which you can purchase here through i order through them for all my repairs of this nature.
  • Nathan Ayers
    Have you read through all my posts and comment's as i am 100 percent sure this is the problem. I believe you cannot see the responses unless you decline my help and choose to use another professional. but i am 100% confident in the solution i have provided to you, give this info to the repair man and have him check it with a capacitation meter.
  • Nathan Ayers
    not a problem glad i could help.
  • Nathan Ayers
    If you feel that way please feel free to rate my solution then on the original post of the problem as fixed. If you need any other assistance you can use the ask me feature and i will be glad to assist you as soon as i can.
What is the best way to set up my 5 inceling speaker system room size is 18x15 TV is centered on 15 ft wall 10ft ceiling ?
place your subwoofer approx 1m or 3 feet away from your media player, then one speaker below your TV, the other two in either corner in the front and the other two in either corner at the back of the room. try not to mount them too high, approx 3 feet off the ground or the same hight as your head when seated. this will give you the best sound quality. if the speaker is the front or back seem a little far you should be able to set the volume on each of them. if the back is further than the front then set the back speakers louder than the front ones or vis versa.
Nov 07, 2013 | Denon AVR-3806 Receiver
What gauge speaker wire use for yamaha R-v905 Receiver
The usual gauges range from 18 to 16 with one limiting factor being the ability of the receiver and speaker terminals to handle larger gauge wire
Jan 28, 2013 | Yamaha R-V905 Receiver
Speaker buttons don't function correctly
The Speaker A and Speaker B buttons select pairs of speakers. If you have connected a pair of speakers to the "SPEAKER A" terminals on the rear of your Onkyo receiver, you will hear stereo sound when the Speaker A button is pressed on the front panel. If, for some reason, you wanted to connect a second set of speakers in the same room or perhaps another room you would connect those speakers to the "SPEAKER B" terminals on the rear. Pressing both buttons on the front panel would send sound output to both sets of speakers
Jan 17, 2013 | Onkyo Quartz Synthesized Tuner Amplifier...
Lcd picture distorts when light in room is turned on. TV is on a HD entenna
This problem is most likely not from the HD antenna but from a power problem. WHen you turn on the light your drawing power away from the rest of the circuit most likely leading to an insufficient amount of power to run the TV causing the distortion.
Mar 01, 2011 | Televison & Video
In algebra formula,,,,carpeting cost $20.00 sq. yd you carpet a room that has a width of 15 ft, for $ 800.00 ,,what is the lenght of the room
Here is the Solution:
1. Convert 15 ft into yards. 1 yard = 3 feet
=> 15 ft = 5 yd
2. Find the area of the given room. The cost for given room is given, and cost for carpeting 1 sq. yd is given. So,
800/20 = 40 {i.e. 40 sq. yd (area of the given room)}
3. Now, Length * Width = Area
=> x * 5 = 40 [Taking Length = x yd]
=> x = 40/5
=> x = 8 yd
=> x = 8 * 3 ft
=> x = 24 ft
So, Length of the given room is 24 ft (8yd).
I hope this solved your problem (in time).
Sep 10, 2009 | SoftMath Algebrator - Algebra Homework...
Center speaker
When you turn on zone 2 you are in stereo mode. The center speaker and the rear speakers will not function in stereo mode.
Try turning on zone 2 and then switch the surround mode after that and see if it helps. If it turns the zone 2 speakers off when you do that, then your unit does not support what you want it to do. Center speakers only work in listening modes other than stereo.
Most A/V receivers are designed for watching movies and they did not take this use into consideration because zone 2 would normally be in another room such as the way you have yours set up. If somebody is watching a movie in one room they would not need to hear it in another room. You would think that the designers, who are very talented to be able to come up with these type of units, would have just a little more imagination on how people would be using the equipment. Go figure!
If your receiver has a 5 or 7 channel stereo mode, it may work then. You can try, but I don't think it will help.
I have even seen some receivers that have the center channel amp being used for the zone 2 output as well. It just switches what speaker output jacks it goes to with a couple of relays which makes it impossible to use the center and zone 2 at the same time.
I guess they are just being cheap by not putting another output channel in the unit and sharing the one they have.
Why would anybody want to use the center and the zone 2 at the same time???? Sad, isn't it.
Hard to believe that such a nice receiver would have such a rediculous limit designed right into it. But they really do design them like that.
Let me know if you need more help.
Aug 08, 2008 | Yamaha RX-V2300 Receiver
Philips cineos picture problem
Are there any magenetic devices like speakers or high amp stereo recievers next to the TV? These blotches could be because of electro-magnetic intereference. Try moving devices away (anything metallic or which has a magnet in it)
Jan 02, 2008 | Philips 42PF9996 42 in. HD-Ready LCD...
Green wave-like color distortion over reds
do you happen to have any speakers of any size within about 3 feet in any direction of the tv?? move them if so, I have large speakers about 5 feet from my tv at home and i still get some distortion once in a while with red and dark green streaks.
Aug 15, 2007 | Sony WEGA KD-34XBR970 34" TV
Televison & Video Logo
Top Televison & Video Experts
