Question about Zenith P42W46X 42 in. Plasma EDTV
Picture on big screen
My family just got an older model big screen zenith tv and the pitcture shows up with a lot of red in it. Is there an easy way to fix this problem.
    Problem Solver:
Chances are, if it's an older set, componants have changed value through use over time, which also includes the picture tubes and associated driver circuits. The way to compensate for this color drift is through adjustments. Either turn the red down a little, or turn the blue and/or green UP. Be carefull though as there are potentially dangerous voltages in and around the circuit boards and picture tubes.
Posted on Jul 31, 2008
Zenith 50" plasma TV model Z50PT320 has no picture no sound just flicker screen with lot s of fuzzz
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary
Feb 12, 2017 | Zenith Televison & Video
How can i find out more information about older zenith t.v. ?
IF you have the serial number you should find the model number.
The model number is essential for getting more information. One trick is to put 'old Zenith TV images' in Google. You will get lots of pictures. Find the pictures of yours and some will have the model number stated. From there you can do search on that model number. You should be able to locate manuals, etc.
Jun 29, 2014 | Zenith Televison & Video
I have an older Zenith 32", the picture is does
If you are using a cable box, there should be a setting to change your "aspect ratio". Some offer options such as fit to screen, zoom, wide, etc. see if you can change this setting from the remote. Without knowing what model cable box you have I acn't get more qpecific, but try this first.
Mar 14, 2011 | Zenith C32F33 32" TV
There is no picture and no sound but the volume
Unplug the cable box for an hour,replug it back in.Should get the cable box to reboot to updated the softwares.Might work than,tv seem to have picture,somethings on the screen,words mean ur tv still works.
Mar 24, 2010 | Zenith R56W36 56" Rear Projection...
27 inch Zenith TV Vertical too big
If you are using a DTV coverter box, you may have changed the aspect ratio with your remote control. look for a button marked "aspect" or "picture size" use that to change size.
If you have a cable box, you may have a similar button.
Or you may find a picture size adjustment on your TV remote.
If you do not have "aspect" button on your remote try going to set up menu and look for picture size.
Older TVs used to have a vertical size adjustment at the back. look in the manual.
If none of the above, you have a biiger problem with the TV internal parts needing attention
Mar 03, 2010 | Zenith C27A24T 27" TV
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
BOW PICTURE AND HUE GREENS REDS AND BLUES LIKE SHADOWS
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Aug 06, 2009 | Televison & Video
Zenith 32" TV Chirping Noise No Picture
Components in Power supply are bad most likely a 35v 100ufd capacitor if not then your Flyback transformer is bad
Jun 09, 2009 | Zenith IQB32B42W 32" TV
Red picture with a Zenith big screen
Here is some info I found on your TV:
That resistor is located on the CRT board of each gun. Ususally if an image is predominantly one color then that color gun has a bad 120k resistor on it's crt board.
Dec 19, 2007 | Televison & Video
Zenith P42W46X 42 in. Plasma EDTV Logo
315 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
