Question about Canon PowerShot SD110 / IXUS IIs Digital Camera
Power shot SD 110 dark screen
When i turn on my camera, the screen is totally dark, as if it doesn´t work and flickers slightly. When you take pictures, and watch them on the camera or a computer, it shows a dark box as if it isn´t taking the picture. However, when you can see previous pictures taken before this problem presented itself.
Please help.
  • 7 more comments
  • Anonymous Oct 13, 2008
    Last week my camera worked just fine. This week I turned on my camera and the screen is black with a scrolling white lines. Then the lines flicker and go back to scrolling. I bought a new battery and disc but that didn't solve anything. Is my camera toast? Can it be fixed? Will fixing it cost more than a new camera? Help.
    Last week my camera worked fine. This week when I turn it on the screen is black with a white scrolling line. Some times the white flickers but mostely scrolls. I tried a new battery and new disc but that didn't help. What happened?
  • kristian928 Oct 13, 2008
    Having the same issue. Can Access all the menu options, and even bring up any of the old pictures, but when trying to video or take new pictures, no such luck.
  • joijoi Nov 28, 2008
    Yup, me too. Can view menu just fine, but screen shows black in picture-taking and video modes, and lo, the pictures and videos turn out almost solid black with no resemblance to the photo subject.
  • Anonymous Nov 30, 2008
    me too
  • an_dre_a Dec 14, 2008
    i have the same problem
  • Anonymous Feb 18, 2009
    I have the same problem...can view old photos taken, and scroll through all the menu options, but no new picture/video can be taken. :-( Any help???
  • Anonymous Mar 19, 2009
    zohail - I think you just saved us a few hundred dollars. I called this morning, and canon is sending us a postage paid envelope so we can send in the camera!
  • David Shultz Jun 07, 2013
    When I want to take a picture the screen is black. Only when I review the pictures I can view them perfectly. Why? Can It be fixed?
    President:
  • 1,223 Answers
CCD failure but u are LUCKY just contact canon they will repair free of charge even if u are out of warranty dont worry and i deserve FIXYA rating for this
see these links below
http://www.imaging-resource.com/badccds.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
pls dont forget to rate me FIXYA
Posted on Mar 19, 2009
No image is captured by the screen itself (LCD screen works but completely dark).
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
Feb 16, 2015 | Canon Cameras
Hi..i am using compaq presario cq 40 and screen is flickering.i had it checked and they told me lcd is the problem but they didnt even bother to check.they just turned it on and they told me that i have to...
When it flickers, can you still see the text when the screen goes dark?
May have to use a bright flashlight set right on the display to see
the text on the screen beside where the light sits.
That will tell you if it's the backlight.
You can also look at a grazing angle into one of the edges to see if the
backlight is flickering when the display does.
When it's cold, does it start with a slight pinkish color? That can be
a sign of backlight going bad.
Anything interesting happen when you flex the cable by moving the screen?
I'm not saying it's impossible, but I've never seen software cause
consistent screen flicker. And if the vga port doesn't flicker, sw is
even less likely the problem.
If you bet the odds, you'd bet on a bad display cable.
Won't hurt to try replugging it.
If that doesn't help, then your monitor may be dying....
Jun 20, 2011 | Computers & Internet
I SEE the green light when I turn on the camera but LCD screen of Sony DSC-F505V is dark black, nothing happens-total silence and cannot take any pictures. Did I loose my camera? Solution?
Based on the information provided it seems that the issue may be with the LCD Screen. You can check if the Camera is working by capturing images and inserting the Memory Stick in the Computer Memory Card slot. If the image capturing is normal then the images can be saved to the Computer. If the images are not getting captured, then the issue may be with the Camera. We can try power resetting the Camera to resolve the issue.
Turn off the Camera.
Remove the battery pack.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
If the issue persists after resetting, then service may be required to identify the exact cause.
Thanks for using FixYa.
Jan 19, 2011 | Sony Cyber-Shot DSC-F505V Digital Camera
Dark on lcd screen when turn on. no display or picture.
A stuck shutter is another common failure mode for digital cameras, especially the S2 IS. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Also pay attention to the blurb there about Canon possibly fixing this for free (for the S2 IS only).
May 08, 2010 | Canon PowerShot S3 IS Digital Camera
Dark fuzzy/flickering screen - Cannon PowerShot A75
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jan 25, 2009 | Canon PowerShot A75 Digital Camera
When I turn on my sony dsc-t1 image is dark and horizontal lines
contacted sony and they said they are having same issues with many sony dsc-t1 cameras and they are fixing it for free. just have to pay shipping cost and they repair it for free. something internaly I guess.
Jan 02, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony Cyber Shot DSC-p8
This sounds like it might be a defective CCD imager. If so, Sony should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/11/sony-konica-minolta-cameras.html
Cyber-shot DSC-F717, F88, P10, M1, P12, P2, P31, P32, P51, P52, P7, P71, P72, P8, P92, T1, T11, T3, T33, U10, U20, U30, U40, U50, U60, V1
CD Mavica MVC-CD250, CD400, CD500, and FD Mavica MVC-FD100, FD200
Feb 09, 2008 | Sony Cyber-Shot DSC-P8 Digital Camera
Sony KP61V75
How old is this set please?
Jan 03, 2008 | Televison & Video
Sony Cyber-shot DSC-N1 8.1 Megapixel
http://www.dcresource.com/reviews/sony/dsc_n1-review/ Hi there, just fixed mine. Had the same problem. Click on link above. Leisa1
Jan 20, 2007 | Sony Cyber-shot DSC-N1 Digital Camera
Canon PowerShot SD110 / IXUS IIs Digital Camera Logo
247 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
