Question about KitchenAid Microwave Ovens
Error Code F2.H2 on Micowave vent a hood - KitchenAid Microwave Ovens
  • William Miller
    William Miller May 11, 2010
    I sent Whirlpool a message asking about this error code, but my message was deleted without being read. Nice...
    There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille.
    It may contain a chart explaining the trouble codes.
    If you find it, and it does, feel free to send me a scan of it or let me know what it says this code means.
    That way I can help you and others.
    Thank you.
  • William Miller
    This may be a sensor or keypad failure, but please reply back with your model number so we can help you.
4 Suggested Answers
MicrowaveSvc
  • 9086 Answers
SOURCE: Frigidaire PLMV169CD Micowave Hood Vent fan Hums but won't run
The starting capacitor will be on the circuit board. You need to remove the control panel to see it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
I am beginning to suspect that you have a failing relay on the control cirucit board. It may have arced and gotten carbon deposits on the contacts, reducing the conductivity. This means less current flow and reduced or non-existent fan action.
After you've checked all this, feel free to contact me about a possible repair. We could have you send us the control panel assembly and the new hood fan so we can analyze and repair it. The second link above takes you to our site.
Posted on Dec 01, 2007
MicrowaveSvc
  • 9086 Answers
SOURCE: Whirlpool Microvave Vent Model GH7208XRQ
It's better to reply back instead of starting a new thread.
Unplugging it for a while and then plugging it back in is how you reset it.
I put in a message to Whirlpool technical to see if they can tell me what this code is. I'll reply back when I find out.
Posted on Mar 30, 2008
  • 949 Answers
SOURCE: error message on a whirlpool microwave oven
The F2 H2 error code refers to a faulty hood/light switch. This is a combonation board located just behind the buttons on the left panel. The part number for the switch board is 8206049. Since the screws holding this left panel on are only accessable with the door of the microwave removed, I would recommend this repair to be done by a profressional repair person.
Posted on Apr 18, 2010
Testimonial: "Quick, straight to the point answer - great!"
Error code F2
Per the tech sheets (page 8), "F2" error code means "Keyboard failure". Recommended by the manufacturer to replace the touch panel first and, if it would not solve the problem, then the control board has to be replaced too. Not the best recommendation but we have to follow it.
- The part number for the touch panel (aka a membrane switch) is AP3130765
- The part number for the control board AP3130764
Here are the break down diagrams for the Kitchen Aid microwave Model KHMS155LSS4
Gene.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Read more: http://forum.appliancepartspros.com/microwave-repair/19054-kitchen-aid-microwave-error-code-f2.html#ixzz3bRus7JKM
May 28, 2015 | Microwave Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Whirlpool ADG 4956 - problem F2
Hi, here is the answer for f2 "F2 - error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
Apr 24, 2011 | Whirlpool Microwave Ovens
Error code F2
The error code "F2" that appears on your KitchenAid microwave refers to a keyboard failure/short on the front button panel or loose keypad connector
Attempt the following to clear error:
Check keypad connector for firm connection.
Press "Cancel" after the error code is noted, if error code returns after 60 seconds, replace keypad ( also called touch pad or membrane switch ).
Best of Luck with the microwave.
Jan 26, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
What does F2 mean?
The error code F2 on your GE microwave indicates "Shorted thermal sensor", this condition will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking.
. It takes a minimum of 5 minutes of convection run time before this code will be
displayed. More information on this error code, as well as other error codes, can be found at
http://www.applianceaid.com/micro_faultcodes.html#gemicro
Best of Luck with your microwave.
Jan 25, 2011 | GE Microwave Ovens
5E (SE) error showing on my samsung C106FL micowave oven (2 years old). None of the other keypad buttons are working. I unplugged the oven & re-plugged next morning but still saem result. Pls help.
The "SE" error indicates a shorted membrane keypad.
You can find support from Samsung in India here.
Dec 18, 2010 | Samsung MC5694 Microwave Oven
Error message on a whirlpool microwave oven ''F2 H2 Hood Keys scanning''
Apr 18, 2010 | Microwave Ovens
Mar 19, 2008 | Microwave Ovens
Nov 30, 2007 | Whirlpool MH1150XMQ Microwave Oven
Microwave Ovens Logo
375 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
