Question about Sony STR-D965 Receiver
Sony STR-D965 Weak output from left channel
I have a Sony STR-D965 and output from the left channel is faint even at high volumes. Minimal sound is heard from the channel. Same problem using either speakers A or B input. I attempted changing the speakers, adjusting the balance, various surround modes. I have not opened the unit. Any ideas? Where should I start?
  • 15 Answers
SOURCE: Sony STR-DE945 5.1 Channels Receiver
Hi, Happened across this forum looking for some remote info. Had a similar problem with my 945...main speaker outputs started to click off & on, no rhyme or reason. Found that the solder joints on the speaker output relays were cold (poor soldering). Actually happend twice, two different relays. Took me a while to find it, reflowed the solder, that solved the problem, over two years ago now. Are you able to dig into the receiver? Do you have a (good) soldering iron and some solder? If not take it to elec. shop and tell them to look for cold joints on the relays.
Posted on May 11, 2007
  • 92 Answers
SOURCE: Sony STR-DE635, Sound from left surround speaker but not right
first turn the actual volume up on that channel on the reciver then make sure your speaker wires in the rear are using the same lenght each
Posted on May 20, 2009
  • 5 Answers
SOURCE: Sony STR-K670P Surround Reciever. No output from
This is a common problem that a lot of people have with this system. The problem is in the connection of the Left and Right Speakers to the receiver. I had this problem too.
What you need to do is actually open up the receiver using a screwdriver. Once it is opened up you will see a circuit board and lots of wires. Look for the red and blue wire that should be pretty easily visible. Cut each one, then strip the ends some, and reattach the ends but to the opposite color- make sure to solder it as well. On some models they messed up the connections and it got switched. Once you do this, the left and right speakers should work great. Hope this helped!!
Posted on Sep 22, 2010
rommelalilin
  • 2178 Answers
SOURCE: Cannot hear rear channel on Sony STR-DTE325
First off, you want to correctly isolate what or which channels are/is bad. Use one good known speaker. Connect that speaker, one channel at a time, and test that channel with a fixed volume level (don't adjust the volume when you check each channel). Isolate the low level channels and make note of it. Note: each channel has their own amplifier. Once you've isolated the bad channels, take it to a repair shop and tell them the bad channels. They will then locate the circuit and narrow down the search to fine the problem - it's usually a bad solder connection. If it blows fuses - more likely a shorted transistor. In your case it's a bad solder connection.
Posted on Dec 22, 2010
  • 6771 Answers
SOURCE: str-gx800es sony receiver problem- right
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Posted on Jan 10, 2011
No Output from any channel
ok i got it now may be you are putting the codes in wrong pin thats why happening this problem.
Dec 18, 2007 | Sony STR-DE525
Speaker Imedance Matching - Sony STR DE 997 receiver with 120Watts - 8 ohms output with Benz 6 ohms..Tower Speakers
hi pawanh75,
thanks in advance for a very informative setup that you have.
Here are some of possible mods , only if you like and can DIY
( or have someone to help you )
• Using a 6 ohms impedance for an 8 ohm impedance amp clearly
denotes that it heats up the output stages.
(please forgive my very technical words)
• One way to lessen the heat is to install a blower .
Use a 220V blower on top of the receiver.
( air should be in going up direction ).
• Before I proceed further please indicate if having the speaker
connected and having a zero volume , and just letting the receiver
in an "On" state deliverately produce heat on the receiver, or just
when the volume is at medium to high level.
If it s running hot at zero level with speaker , please post.
If it is running hot even without speaker, post also
• It may also helps , if you have a powered subwoofer ( for the low's),
and set settings on your receiver to "small"
Let me know what you find to help you further.
Sep 11, 2012 | Sony STR-DE997 7.1 Channels Receiver
Sony STR-D965 display flashes protector. how do i fix?
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Feb 25, 2011 | Sony STR-D965 Receiver
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
Jan 10, 2011 | Sony STR-GX800ES Receiver
Sony amp TA-F417R no sound, when device on temp it may work
My first suspect would be the output relays. These can get corroded over time and the classic symptom is that you get no sound at low volume levels and high volume levels will kick in the sound. There may be other issues as well such as poor solder connections. If you don't have any experience with this type of gear, have this checked by a service center. The cost should be minimal.
Dan
Jul 17, 2009 | Sony STR-DE595 5-Channel Amplifier
No sound out of left speaker
did the left channel work when u switched speakers, if so then the left speaker or wiring is a fault.if not then the output circuits on the amp are blown or the fuse is blown some amps have internal fuses in the output to protect the output transistors. unplug the power cord and take the cover off, look to see if u can find any fuses and check these for continuity u can hold these up to the light and u should see a fine filiment in one piece and not broken. these fuses sometimes blow just from age and use at high volume like a regular light bulb.If the fuse is blown replace with the same value else the output transistors will need to be replaced most likley along with the drivers.
May 19, 2009 | Sony STR-DE135 Receiver
May 18, 2009 | Sony STR-DE635 Receiver
I have low volume on two channels of my STR DE975 receiver
I been replied you in chat thread, please check and feel free to ask any question.
Aug 20, 2008 | Sony STR-DE975 Receiver
64 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
