Question about LG WD-12126RD Front Load Washer / Dryer
2001 Gibson Washing Machine - Front Loader
Has a knocking noise in the spin cycle in the last couple of weeks. Can you help? Tub turns smoothly by hand - no bearing noises when turning by hand. Slight forward to aft play in drum.
BZi1958@aol.com
  • BZi1958 Jul 01, 2008
    The kind of knocking sounds like a constant clanking like something is rotating and hitting something. Can you help?
    BZi1958@aol.com
    Solution #1
    posted on Jun 29, 2008
    Midwest-tech
    Rank: Wiz
    Rating: 83%, 28 votes
    What kind of knocking is it. Can you describe where its located is it the drum off track is it from the transmission? what does it sound like something hitting metal? a constant clanking like something is rotating and hitting something?
    The checking I did I just don't think it's a bearing. The sound is more of a knock - knock - knock when it is spinning. There is no noticeable play; the only play noticed is 1/16 to 1/8 inch front to back when pushing and pulling on the back pulley.
    BZi1958@aol.com
    posted by BZi1958 on Jun 29, 2008
    Report abuse
    BZi1958@aol.com
    Comment by BZi1958, posted on Jul 01, 2008
    The kind of knocking sounds like a constant clanking like something is rotating and hitting something. Can you help? BZi1958@aol.com Solution #1 posted on Jun 29, 2008
    Midwest-tech
    Rank: Wiz
    Solution #1
    marked
    Rank: Wiz
    Rating: 80%, 71 votes
    This can be a symptom of drum bearing wear. A quick check for wear is to see if the inner drum moves up and down relative to the fixed outer drum. It should only move a minute amount. If it moves more than a millimetre or two, it is probably worn bearings.
    You can obtain bearing kits for most makes. See this very useful link specific to an AEG model, but it is a good general reference: http://www.eveshamsquash.co.uk/appliance...
    Also see an excellent article by Chris Tran on Hoptpoint WMA series bearing replacement, at http://www.christran.net/washingmachine1...
    If it is making unusual noises while washing too, check there is not a bra wire or similar object trapped half way into one of the drum holes. A high pitched whine is sometimes caused by the motor bearings (but most brush/commutator motors whine a bit anyway on higher speeds, it is normal). Oil sparingly so as not to contaminate the carbon brushes.
    Hope that helps...........
  • 6,487 Answers
You can obtain bearing kits for most makes. See this very useful link specific to an AEG model, but it is a good general reference: http://www.eveshamsquash.co.uk/appliances/aeg_bearing.html
Also see an excellent article by Chris Tran on Hoptpoint WMA series bearing replacement, at http://www.christran.net/washingmachine1.htm
Posted on Jun 29, 2008
    Sergeant:
  • 243 Answers
  • Nathan Ayers
    Nathan Ayers Jul 01, 2008
    It sounds like it may be the motor coupling. can you tell me if there is a belt or a coupling between the motor and transmission?
    Genius:
  • 3,422 Answers
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
  • Priya darshan Jun 29, 2008
    Here are few more troubleshooting steps:
    Please click on blue links for more info.
    • General
      tips
    • Balance the load
    • Level
      the machine
    • Inspect the water pump for a blockage
    • Inspect the coupling
    • Inspect the transmission
    • Adjust the drive belt tension
    • Check the motor bearings
    • Check the drum brakes
Washer is a Samsung WWF337AAW-XAC. Just prior to the spin cycle we hear a rattling or grating noise and then it rattles throughout the spin cycle. It will sometimes rattle at the end of the rinse cycle but...
hi Rick.
Reasons a washer will make noise during spin mode:
1. Main tub bearing faulty
2. Main drive pulley
3. Motor coupling worn
4. Bad clutch
5. Worn out drive belt
6. Clogged or damaged drain pump
7. Transmission is worn out
8. Shock absorber (front loader washers)
9. Springs or dampening straps (top load washers)
10. Agitator directional cogs aka "agitator dogs" (top load washers
When the washer spins, it rides on a bearing that allows the tub to move freely with zero resistance. If this bearing is worn out, a loud noise will be heard when the washer spins. A good way to tell if your washer problem is the main tub bearing will be that the washer noise will get worse or louder as time goes on. This means the bearing is becoming more worn out and close to complete failure. The bearing in your washing machine is a circular metal object that has many small little metal balls inside. These small metal balls inside the bearing sit in a track and move when the washer is spinning. If the tub bearing begins to wear out, usually the small metal balls inside can fall out one by one causing the noise you hear. (If your washing machine is a front load washer, open the door and turn the drum by hand. If you hear a rubbing sound or the drum spins uneven, then the main tub bearing is most likely bad and needs replaced.)
Washing machine tub bearing
Washer has noise during spin cycle
The bearing may also be without lubrication. If the sound you hear is more of a squeaking noise than a grinding noise, it may mean the bearing needs to be lubricated with a mechanical grease. If the sound is more of a grinding noise, then this usually means the bearing is falling apart and will need to be replaced ASAP. If you suspect your washers main tub bearing is worn out, the repair process is one of the most difficult to perform yourself. A worn bearing can also damage the tub of the washer. This means the tub (inner or outer) may need to be replaced also.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to your washer) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose. To find out if the drive pulley is causing the noise, you will need to take the washer apart and inspect the pulley for signs of damage.
WASHER MOTOR PULLEY
The motor coupling could also be the cause of the loud noise. The motor coupling in your washer connects the washers transmission to the motor. It is made of plastic and built to break if the washer gets overloaded. This is so the motor and the transmission do not become damaged. The motor coupling is an easier repair and can be done by most people.
Washer Washing Machine Motor Drive Coupling Coupler
The clutch in a washing machine connects the inner wash tub to the transmission. The clutch lets the washer get to the proper spin RPM in a gradual way. If the clutch is worn it can make noise when the washer is spinning. A bad clutch needs to be removed and replaced to stop the noise.
Washing Machine Clutch
The belt in your washer can become worn and cause noise while spinning. If worn out, replace the belt. Replacing the drive belt on a washing machine is an easy task and can be ordered online for less.
Washing machine belt
The drain pump in your washer that drains the water out could be clogged or damaged. While in spin mode, your washer may drain out the water by using the drain pump. If the loud noise only happens at certain intervals during the spin cycle, it may be the drain pump. Usually this can be fixed by simply removing the drain pump and removing any debris that may be clogging it up causing the noise.
Drain Pump for Washing Machine
The next part of your washer that can be causing a loud noise is the transmission. If the transmission is bad, usually the cost to fix this outweighs the cost of a new washer.
If you have a front loading washing machine, they all have shock absorbers. The shock absorbers are used to center the tub movement while in the spin cycle. These shock absorbers are connected from the washer frame to the outer tub. If the shock absorbers in your front loader become weak the washer will make a loud banging sound during the spinning cycle.
Shock Absorber for washing machine
Top load washers usually have springs or dampening straps holding the tub centered. If a spring or strap falls off or becomes weak, a loud noise will be heard in spin mode. Simply replace the strap, spring, or springs to remedy this issue.
Washing machine suspension springs
Agitator directional cogs are used to operate the upper part of dual action agitators (Top load washers). They engage the cogs on the inner area of the agitator as it turns in one direction. They release when the agitator reverses its direction. This lets the top part of the agitator to ratchet in only one direction. The bottom part will agitate in both directions. The cogs are made of plastic and wear out with regular use. They will start slipping and make a grinding noise. Another way to be sure that this part is bad is if you notice the top portion of the agitator does not move in a smooth motion. Removing the top half of the agitator to see if the cogs are worn out.
Dec 08, 2017 | Washing Machines
Roper washing machine makes grinding noise on spin cycle but the tub doesn't turn
It sounds like you have a motor coupling that is broken. There are videos on YouTube to show you how to repair this. Search for "motor coupling repair on direct drive".
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
My front loader washing machine is make a banging sound during spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 16, 2011 | Kenmore Washing Machines
Kenmore front load washing machines knocks
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 25, 2010 | Kenmore HE2 Plus Front Load Washer
My Kenmore Front Loader washer machine is making a loud noise during the spin cycle
tub bearing more than likely.tub has a 10 yr warranty so call sears get the flat rate labor charge their offering then have them replace the tub
Jan 11, 2010 | Kenmore 43042 Front Load Washer
Leaking water in washing machine
Front loader or Top Loader? If front loader you probably put to much in and at spin cycle the tub hit the hose to the pump and possibly got knocked off?
Oct 16, 2009 | Washing Machines
Kenmore HE2 Plus Front Washer knocks very loud on spin cycle and a belt or something has been coming out in pieces for the last few weeks
I just took the back off my older kenmore front loader and discovered that the concrete counter weight had come off the drum and fallen to the bottom of the machine. Reattached it and knocking has stopped, lucky it didn't trash the machine as it is normally attached to the top of the drum.
Oct 13, 2009 | Kenmore HE2 Plus Front Load Washer
Washing machine - knocking sound at end of cycles
Hi there is it a top loader or front? If a front loading machine it might be the concrete block has come loose under the top cover.
Thanks J
Feb 26, 2008 | Whirlpool LSB6200KQ Top Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
LG WD-12126RD Front Load Washer / Dryer Logo
265 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
