Question about LG Televison & Video
I have a hdd/dvd recorder model rh7880/rh7500 set timer recording to record onto dvd, machine switched itself on as normal but did not start to record and froze up.cannot get anything to respond either from the remote control or the front panel of the machine.Only way to switch machine off is at the wall socket.Any ideas ???
Recorder wasn't under warranty, so opened the unit up removed the dvd - rw disc ,which was corrupted as it turns out, put the machine back together switched it on and it worked perfectly.I have since tested it by recording both on to dvd,hdd and used the dubbing format and have had no problems.In the future I would recommend bying only top quality discs as it seems a dodgy one was responsible.
Posted on Jun 30, 2008
LG HDD RECORDING WONT STOP
Did you try to contact LG support?
Nov 19, 2015 | LG RH1999H DVD Recorder/HDD Recorder
Attempted to burn a DVD
The lens for reader is a common issue and causes those errors. Get inside the box, take off the two screws on the DVD drive cover and (delicately) remove dust from the lens and surroundings. You should use delicate brushes and air blast, but I got some soft tissue and gently wiped.
I hope this helps
May 29, 2010 | Televison & Video
My LG DVD RECORDER, MODEL RH7500 won't play DVDs.
Check the model specifications for your device. Some players will only accept DVD-R and not DVD+R or not DVD+RW discs. I know it all seems the same, and it's very frustrating, but many companies restrict the type of discs they will allow. My player does +R but not -R. It should still be able to read DVD discs that you made yourself, but they will be of a different type.
Nov 03, 2009 | Televison & Video
My LG LRH-880 HDD/DVD recorder sometimes stops recording by itself, before the end of the programming and even if there is enough disk space left.
Somehow, my HDD/DVD recorder recorded correctly 2 times last night, even if I did not do anything specific to fix. I will keep an eye on new occurences of this problem, but it appears at the moment that the issue disappeared by itself.
Sep 13, 2008 | LG Televison & Video
Timer recorder n/w
the recorder must be off, otherwise timed recording doesn't work
Aug 29, 2008 | LG RH177 DVD Recorder/HDD Recorder
Hi, Have just purchased Samsung DVD HDD recorder (DVD-SH855). Everything works great except the timer recording. When i schedule a recording, the system wont start recording. The recording light flashes...
I had the same issue. It turns out that the recorder has to be switched off otherwise it won't record. The unit will power itself on at the scheduled time and record your program. It doesn't make any sense to me why this would be a requirement but it solved the problem for me.
Jul 06, 2008 | Televison & Video
Can't record onto disc
press dub on your remote, it will open the menu choose your programme you want record then click on hdd to disc.
Mar 02, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
LG RH177 Recording
once you have set timer record, you must then put machine in standby mode,once in standby mode you will have a little timer display in panel,should then come on when time to record
Aug 13, 2007 | LG RH177 DVD Recorder/HDD Recorder
Televison & Video Logo
117 people viewed this question
Computer Repairing
Computer Repairing
