Question about Samsung Televison & Video
We have an HL-T5676S HDTV that we purchased in Sept. last year. We have Comcast Cable w/ the HD box. We also have several game systems we play on the TV. They are a Wii, XBOX 360 and a PS2. We also have a Toshiba HD DVD player, model HD-A3KU that is connected to the TV. All the components are seperately connected, in other words none of them are routed through the cable box but connect directly to the TV. The problem we're having is there are very disinct horizontal lines covering the screen top to bottom and side to side. They started about 2 months ago and have been intermitent. The picture is barely visible through the lines. We purchased the TV through Best Buy. Initially, when we contacted Best Buys' service department they suggested unplugging all the external components. This made the lines go away for a short time but they came back and then unplugging the components no longer solved the problem. We have unpugged the TV and let it sit for a few minutes and then plugged it back in again with no change in the picture. We even left the TV on for about two days straight and the lines finally went away but soon returned. At that time we made a service appointment but the earliest one was 2 weeks away. By the time the appointment day arrived, the lines were gone. Now it's 3 weeks later and the lines are back with no change after unplugging all components except the cable box. We have scheduled another service call but, again, it's almost 2 weeks away and we don"t have the use of our TV. Is this a problem with the TV or something to do with one of our components? We'd like to solve this problem once and for all. Any light you could shed on this problem would be greatly appreciated.
  • 3 more comments
  • dacbird Jun 29, 2008
    Firstly, no, there are no speakers next to the TV. And I agree this is something for the pros if it involves replacement parts. The TV is still covered under our service aggreement through Best Buy. I was hoping it was something that we were able to do on our end before the service call that's 2 weeks away.
    I'm having trouble seeing all of the responses for some reason. Please be patient with me while I try to access them. Thanks.
    I wonder what's the chances that the "Geek Squad" is gonna find this problem?
    We'll do. Thanks for all your help.
  • dacbird Jun 30, 2008
    I tried leaving a "problem fixed" rating as you suggested but when I roll my cursor over the "rate" bullet in the text I get a pop-up ad for an online trading website. It makes leaving a rating impossible (for me anyway) and I can't make it go away so I hit the icon with the 4 blue squares on it. Hope this gets the job done. I didn't know if you were aware of this situation or not. Seems a little contrary to leaving a positive comment to your efforts to resolve my problem. Thank you again for your help. I really do appreciate it.
    Master:
  • 848 Answers
Check the contacts on the PCB or yoke connectors or isolation / connectivity problems inside the yoke
Posted on Jun 29, 2008
  • gopinath pasupathy Jun 29, 2008
    the problem for horizontal lines maybe
    1. Power is failing to the horizontal output transistor - this could be due to a low voltage power supply problem, bad connection, etc.
    2. Base drive to the horizontal output transistor is failing - could be a fault in the horizontal oscillator or bad connection.
    3. Problem with the flyback transformer or its secondary loads (flyback may provide other power voltages).
    4. X-ray protection is activating - either due to excess HV or due to a fault in the X-ray protection circuitry.
  • Samsung Master
  • 6,487 Answers
Replaced a capacitor at the back of the main board, next to the rear rca inputs. It is labeled 10uf 100v.Here are a couple of photos of the part.
http://farm4.static.flickr.com/3215/2337629026_eaa30cfa18.jpg?v=0
http://farm3.static.flickr.com/2411/2337627420_b45bbf1a74.jpg?v=0
Hope that helps.............
  • Mark Gil
    Mark Gil Jun 29, 2008
    If you're really think that it will be hard for you to repair this I really suggest you to let a professional do the job for you..
  • Mark Gil
    Mark Gil Jun 30, 2008
    You're very welcome ....
    Sergeant:
  • 243 Answers
Is there anything magnetic near the tv thats interfering, You dont have like 15" unshielded cirwin vegas right next to the tv do you?
  • 4 more comments
  • Nathan Ayers
    Nathan Ayers Jun 29, 2008
    But from what i read it could be a capacitor set for your samsung they are here the two stk set.
    if not you can order the ic replacement for this tv the kits are sold here.
    also
    another good link is electronix they also sell the capacitors and IC's
    and repair kits for your model. They have lots of good capacitation
    meters for a good price check it out here.
  • Nathan Ayers
    heres a better link for the IC's.
    note this is a complicated fix so it is best left to professionals but if you have confidence in de-soldering the old IC's on a PCB board and soldering the new ones go for it.
  • Nathan Ayers
    Interesting There is a few problems it could be from the IC's that are
    used for convergence and horizontal hold and vertical hold. could just
    need a manual alignment but youd want to change these capacitors. theres
    a capacitor at the back of the main board, next to the rear RCA inputs. Labeled 10uf 100v. heres what it may look like
    photo 1
    photo 2
    which you can purchase here through electronix.com i order through them for all my repairs of this nature.
    Also here is a look at how to change the IC if it is blown
    photo 3 of ic replacement
    photo 4 of ic replacement
    hope this helps you.
    Thanks Nate.
  • Nathan Ayers
    No if i were you what i would tell them is to take a capacitation meter and test what ive showed you. Tell the service technician to tell you wether or not there faulty regardless if its happening. They may just need to be reseated on the board. But give him the information i have laid out for you.
  • Nathan Ayers
    slim to none. Geek squad wow i dont even think they require a certification. just people that have general knowledge. That will be funny let me know how it goes.
  • Nathan Ayers
    They send it out for service just like before they had geek squad. You should have inhome service where they pick it up and take it. Then most circuit city and best buy have replacement tv for like 5 dollars or something that you can use while its out of a floor model thats comparable to your own.
Lip sync
Vizio HDTV- Lips out of sync
Anyone with a new Vizio E601i-A3 60" or 70" HDTV that is having audio "Lips out of sync problems" with a cable or satellite box.
On Comcast cable boxes (or others), here's what you need to do: FIND MENU for AUDIO or HDMI setup on CABLE BOX or Satellite Box.
FOR COMCAST
1. Turn on TV and have Cable box Turned OFF.
2. Press MENU on COMCAST REMOTE.
3. Go to AUDIO Setting OR HDMI Setting. (On cable or Sat. BOX)
4. Change setting from Auto to L-PCM. (Turn off cable box to exit)
This should resolve any "out of sync" lips to picture after commercials on HD channels.
*This is a handshaking issue from the cable box to the Vizio E601i-A3
Dec 08, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
I have a Samsung HL-R5067W DLP HDTV. I have HD cable from Comcast. My TV plays the HD signal flawlessly. The non HD channels have columns and rows of colors on the screen. The picture can sort of be made...
this could be 1 of 2 things--either the light engine or the digital board--i'm betting on the board because hd cable is good--light eng/cost prohibitve--board maybe !!
Jul 22, 2009 | Samsung DLP HL-P5663W 56" TV
Connecting my comcast hd cable to my pioneer elite hd 1130
you will need the other cables. Hd tv won't work with the old school hookups. rca jacks' can sort out those frequencies
Jan 28, 2009 | Pioneer Elite PRO-1140HD 50 in. Plasma...
No power to TV. Will not turn on.
replace the power supply about 60.00 dollars from viewsonic
Jan 15, 2009 | ViewSonic N3251w 32 in. LCD HDTV
Am i getting hdtv with just cable feed?
Depending on your cable provider, some of the HD channels may be present. If so, these are ususally located in the upper channel numbers. It sounds like you are receiving some of the HD lineup. A cable box will probably allow you to view more HD channels including the premium HD channels if you subscribe to them. You should not be noticing a delay with the HD channels only. If this is what you are experiencing without a cable box, then it would be an issue with the HD tuner built into your TV set. LG customer service can let you know if there are any software updates available for yourmodel that can resolve this. Additionally, if you are getting your sound from an Home Theater system then you will notice an echo if using the TV's built in speakers at the same time. This is sometimes mistaken as an audio delay. If you are using a home theater system, be sure to disable the speakers that are built into your system.
Jan 04, 2009 | LG 37LG30 37 in. LCD HDTV
NO SOUND FOR TV BUT I HAVE SOUND ON DVD
the bose has to be hooked up to the cable box output and video 1 on the bose. This is the only way it will work
Nov 14, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Have hd cable box to hdtv, need cable remote to control hdtv- no code
It can be solved, but you have to buy a universal remote, and not use the comcast remote.
http://www.iconnectdots.com/ctd/2007/05/targets_trutech.html
Oct 03, 2008 | TruTech PLV16190 Television
Sc-pt660 + 46pz85u = NO SOUND!
Don't worry about sending the TV audio to the Panasonic. Just send a digital audio signal from the cable box to the Panasonic.
DVD - Panasonic connected via HDMI
TV - Panasonic connected via HDI
cable connected to cable box and TV. But you will not really be using the cable connection to the TV (TV Tuner) since you will want HD feed from cable box through HDMI input on TV.
You aren't concerned about feeding the TV speakers because your audio will always come from the home theatre.
Note that some components don't feed audio through HDMI, in which case you will need to use optical digital audio.
Sep 08, 2008 | Panasonic Home Theater System System
HDTV
Shouldn't have to, but HD through the wall connector may be an issue if you are wanting that. I don't know for sure. Almost all tv's made in the last 1 year - 2 years have digital tuners built in
Jun 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
53 people viewed this question
Henry  Thomas
Henry Thomas
