Do you have spark and fuel pressure? Check the inertia switch? You might try a spray of starting fluid. If it tries to start you would know that the engine has spark, but the injectors could be working without fuel pressure and starting fluid would show you it is a fuel pressure problem if the engine fires with starting fluid.
How many miles on the car? Have you checked the fuel pressure when it doesn't want to start? Do that first and then move on from there. To quickly test fuel pressure with no special equip get a can of starting fluid from the auto parts store, when it fails to start spray the fluid into the air intake of the engine well it is cranking, if it fires up then the fuel pump is likely not running on for some reason. This can be electrical in nature or just a failed electric fuel pump
check fuel pressure, should be 40 psi.
try 2 things
spray starting fluid in air intake to see if it will stay running. It's fue then.
Try turning key to on nd wait 5 seconds for system to build pressure and pump to shut off. Turn key off, wait for relay clcik noise or 10 seconds. then turn key to ON again and wait 5 seconds to build pressure again. Then start engine. If it starts better, you have a bad check valve in the fuel pump or a bad pressure regulator on the fuel rail (unlikely).
i would check the fuel filter if thats not it then it will most likely be the fuel pressure regulator make sure the vacuum line didnt fall off of it if that checks out then id say its your pump good luck i hope this helps
when it does this spray starting fluid into the air intake of the engine at the air cleaner and see if itr starts, if it does you have a sticking fuel pump..
Check for spark. Also listen for the fuel pump to kick on or spray starting fluid in the throttle body to see if it starts. If the fuel pump isn't kicking on then its your fuel pump and its located in the tank
Spray starting fluid near the carburator if equipped. It may be a leaking main gasket under the carb.If you spray and the engine turns off. It is a vacuum leak. meaning the main gasket under the carburator .
