Question about Kenmore 25.1 cu. ft. Side-By-Side Refrigerator with Rotating Dispenser System
Kenmore 58562890 Both refrigerator & freezer stopped cooling and went warm. I noticed a clicking sound that wasn't present before. I've been reading about similar problems and it seems to point to the compressor start relay. Is that something that can be done by a do-it-yourselfer, or will I have to call a repairman? Also, what is the ballpark figure for that repair? Thanks!
  • ahaaland Jun 29, 2008
    I was afraid of that! It is 10 years old and has worked beautifully--this is the first time we've had a problem with it. We've actually already bought a replacement but were hoping this was a cheap fix so we could keep it as a backup for drinks in the garage.
    Thank you so much for your advice!
  • 828 Answers
If it is only the relay that is bad a do it your selfer can do it BUT it may be a more serious problem such as the compressor which has failed. If the refrigerator is out of warranty I never recommend that a new compressor be put in. Replacement compressors are only covered by a 1 year warranty and if one compressor failed you could likely have the same problem down the line.
Posted on Jun 29, 2008
  • James Helmer
    James Helmer Jun 30, 2008
    Glad we could be of service.
Kenmore elite refrigerator, both are "luke warm"
Sounds like your start relay/capacitor is fubar. The clicking is caused by the Klixon shutting down power to the compressor when it does not start properly. When it cools it resupplies power only to overheat and click when it shuts down again.
Jun 12, 2017 | Refrigerators
Refrigerator is not cooling like it normally does. It seems like compressor is working and it is still cool to the touch, but frig temp is 62 and freezer temp is 28. took off back panels and cleaned dust...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 10, 2011 | Kenmore Refrigerators
I have a Jenn Air JCD2289AEW side by side refrigerator. The freezer has not been cooling properly for a few days. Now the refrigerator seems to be maybe less cool than it should be. I still get cold air...
heatman101
Jul 16, 2011 | Jenn-Air JCD2389G Side by Side...
Side by side fridge/freezer,both working and cooling just fine, problem is it is running non stop and there are ice crystals that had built up in the freezer and I noticed my food seemed to be begining to...
heatman101
May 10, 2011 | Kenmore Refrigerators
I have a Kenmore side by side fridge Model 51562101. We just noticed a burning type of smell coming from under the freezer side. My wire thinks the smell is more like a chemical smell. The fridge is...
Your compressor just went bad...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 15, 2011 | Kenmore 62832 / 62834 / 62839 Bottom...
Stopped cooling but the system appears to be running although we hear clicking sounds
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 21, 2010 | Kenmore 64802 Top Freezer Refrigerator
Kenmore bottom freezer refrigerator warming up
Hi
There is a definetely leak in the cooling gas.
Firstly... You will need to find from where the gas has leaked. It is usually on the compressor pipes..... but not always.
Secondly you are right about the Water Valve... it needs to be changed.
Regards
Berry
Feb 02, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Viking Refrigerator stopped cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 12, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Freezer only cool, fridge not cold as well
it sounds like the relay on the back of the unit may have gone bad.or the compressor has a leak in the line...call a tech out and have it checked...it may be cheaper to get a new fridge
Aug 22, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore 106.72102100 Not cooling URGENT!
behind the back panel that you pulled off is where the compressor is. on the left side of the compressor is where the relay/overload is plugged in. its gone bad. if you touch the compressor it will either be really really hot or room temp. unplug it let the compressor cool and replace the relay/overload to fix your problem
Nov 27, 2007 | Kenmore 65812
Kenmore 25.1 cu. ft. Side-By-Side Refrigerator with Rotating Dispenser System Logo
409 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
