Question about Fuji FinePix F650 Digital Camera
Fuji F650 Zoom Error
I have a fuji F650 that was working great,I took a couple of pictures downloaded them to my computer.Then I put the camera in it's case and set it aside.The next day I got the camera out and turned it on and it shows on the screen "ZOOM ERROR". The lens won't come out,I tried recharging the batttery,I even bought a new battery and still the same problem.
I connected the canera to my computer with the USB cable hoping it might tell me something,but no luck.
I contacted Fuji and asked for help,if there was anything I could try myself,they were no help at all.
Can you help me?
  • 6 more comments
  • Steve3604 Jun 29, 2008
    I forgot to say I had already tried the blowing with air.
    If I hold the camera next to my ear when I push the power switch it sounds like it doesn't even try to move the lens,there is a couple of clicks then nothing.
  • Steve3604 Jun 30, 2008
    Can anybody think of something else to try,I am disabled and on a very small budget so it would be hard to pay a bunch of money to fix it.
    Thanks for any suggestions!
  • Steve3604 Jul 02, 2008
    Yes I know it is the lens That is what I said the lens won't come out or go in.
    You said it is "because the lens".
    That is where you stop,The lens what?
  • Anonymous Mar 11, 2014
    hp compaq dc 5100
    heat direction
    Stuck in landscape
    after loads of laundry are done i can see water dripping back into the washing machine and i have to drain and spin water out....it contiues to happen and i have to repeat that a couple times a day
    my astra mk1v will not tick over changed the bit by the air filter still not ticking over
  • 2,071 Answers
The lens is in misalingment track, before you do alignment take out the batteries.Just pull the lens barrel out to extension while pulling wind the barrel sideways slightly ,until you hear a click it take a try of two times..Then reset the camera ,if resetting finish .then look if zoom error is gone ,try this option it maybe help...
Posted on Jul 02, 2008
    Master:
  • 638 Answers
You can fix it on your own just open the camera and see whether some thing is obstructing your lens to move .just take all the screw out which are connecting the two parts of your units body seprate the body gently and slowly,and there you can see inside that any dust particles is there between the small gears if there just clean that.if it is the internal problem this is the solution if it is technical error you have to take it to the service centre for sure.
feel free for further assistance rate the solution as fixya if this helps you solve your problem.
thanks
  • hemant somaiya
    hemant somaiya Jul 07, 2008
    there is no option .u will hve to get it repaired through a technician.
    Master:
  • 382 Answers
If you are using a memory card please try to remove it also the battery along with the memory card and then try then which might be providing you better result..be gentle so that you dont void warranty..thank you!!..
    Genius:
  • 2,028 Answers
I had the same problem with a Nikon. Turned out to be one of the gears that controls the zoom lens. The gear jammed and in turn burned out the small motor. I watched the guy tear down the camera and believe me, this is something a camera shop will have to do. I'll tear down laptops all day long, but there's no way I'll ever tear into a camera, the pieces are unbelievably small.
Posted on Jul 01, 2008
  • 282 Answers
This kind of problem has been posted already here
but with a different model version,basically your camera needs to be repaired.Theres a problem with the interaction of the lens for zooming and the software/firmware of your cam.
Posted on Jun 29, 2008
    Sergeant:
  • 243 Answers
Then it is possibly off track and or jammed. You can attempt to open it yourself and free it. But you could take it to a camera repair shop and have it serviced they might be able to do it for a decent price if its not to hard.
  • 6,487 Answers
Try this gently grab the lens, pull it out as far as it will go until fully extended. While keeping it extended turn the lens to the right until you hear a click.
Once you hear the click, release the lens and turn the power button on and then back off again. This should take care of the problem. A word of warning.
ALWAYS make sure your fingers do not touch the front of the lens when you power on the camera. Even the slightest bit of obstruction seems to make the problem reoccur. Another note. I had tried this several times until I finally heard the click, so please don't give up on it, just keep trying.
This will work and it will save you a lot of time and money having it fixed.
Hope that helps..........
  • Mark Gil
    Mark Gil Jun 30, 2008
    Did you already try my suggestion??
    Master:
  • 848 Answers
You may be having sensor problems thats why your lens are not coming out ..........the error message is displayed because of your lens
  • gopinath pasupathy Jul 03, 2008
    better take to near by service center
    to get your problem solved
    Genius:
  • 3,422 Answers
It does sound like your camera is defective. You'll need to call Fuji and arrange for a warranty repair through them.
  • Priya darshan Jun 29, 2008
    You can try this,it is recommended by fuji for zoom error:
    They said it could be fixed by leaving the batteries out of it for over 3 hour.If this doesn't work then switch over to 2500 mAh Nickel Metal Hydride rechargeable batteries.
    you will see a difference.Digital cameras with zoom lens need more power than what can be supplied by ordinary batteries..
    Please don't forget to rate or accept the solution.
  • 4,472 Answers
There is not much you can do. You can try and get the lens unstuck yourself and then it could possibly work like normal. Though in all likely hood. You need to have it serviced by a professional. If you need any help locating one let me know. If it is under warranty you would be best served going through Fuji.
Keep me updated.
Thanks,
Lee
  • Lee A.
    Lee A. Jun 30, 2008
    I am sorry there is not much you can do beyond getting it repaired. You may also consider replacing the camera as a comparable model is fairly cheap. You could then sell this one for parts online.
    Thanks,
    Lee
  • 405 Answers
Good Day,
The best advice I can give you for a situation like that is to get some canned compressed air and use it blow in and around the lens assembly. All it takes is a piece of sand or other debris in there it jams the lens assembly.
Hope this helps
  • Patrick McGee
    Patrick McGee Jun 30, 2008
    Provided is not due to a mechanical problem, Sometimes pushing down on the lens assembly while powering it on might work. Also try turning the lens assembly (in the direction it would zoom) as well while powering it on. If there is anything jamming it this may free it.
    Use my suggestion with care as it may cause further damage if you push too hard.
    I wish you the best of luck
F650 dropped
Open and check the breakages if any or dislocation of connectors..
Nov 02, 2013 | Fuji FinePix E900 Zoom Digital Camera
Zoom error
The lens mechanism is jammed or broken, the camera needs to be taken apart and inspected. I would suggest agains it, as these things may break easyly or you might not get it back together.
I can recommend a few repair places:
Sep 12, 2008 | Fuji FinePix F650 Digital Camera
Zoom error
The lens mechanism is jammed or broken, the camera needs to be taken apart and inspected. As these kind of  things may break easily oyou might not get it back together..... so try replacing it...
thank u rate me!!
Feb 10, 2009 | Fuji FinePix F650 Digital Camera
Zoom on fuji f650 stuck
Hi Sandra, Try power reset for your camera. Turn the camera on, and without turning the camera off, open the battery door and take the batteries out. Leave it for a minute or two. This helps camera get reset and helps correct the basic functionality and also zoom error. Hope it helps u otherwise u will have to take it to authorised repair center. Good Luck.
Dec 03, 2008 | Fuji FinePix S7000 Digital Camera
Zoom error fuju f650 camera
I had same problem but returned it to manufacturer & it was repaired under guarantee & returned to me within a week & has worked perfectly since
Aug 09, 2008 | Fuji FinePix F650 Digital Camera
Zoom error
I'm not sure if this will work as I have yet to try this for my self. But according to others who have had this problem pulling lens out while camera is off and then restarting camera works. If this does work please notify. Or just tell me what happens when this is done
Jul 12, 2008 | Fuji FinePix F650 Digital Camera
Fujifilm F650 Zoom Error
My camera stays open, will not shut, and when I turn it on the screen says "zoom error" and then turns off again
May 20, 2008 | Fuji FinePix F650 Digital Camera
Concerning fuji digital camera F650- how to fix it ..
These things are not servicable Simply replace it .
Jun 29, 2007 | Fuji FinePix F650 Digital Camera
Fuji 4700 zoom
there is some chance that it's not getting power for the shutter release. Either becuase of some internal error on the switch, the circuit isn't closed, or that the batteries aren't performing. Unless you're tired of this camera, you could try with new, maybe borrowed, NiMH bats. Good luck
Jun 09, 2006 | Fuji FinePix 4700 Zoom Digital Camera
Fuji FinePix F650 Digital Camera Logo
182 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
