My amp was working fine, then 1 day it went out. I jiggled the power cable and it would come on for a few minutes, but now I am not getting any power at all?
Checked both sides of the main (60w) fuse with a multimeter and found that it wasnt receiving power ofter the battery. Looked like the seals went bad and moisture somehow got into it, replaced it and it works fine now.
Posted on Jun 30, 2008
Getting no Signal to the tv from the Xbox. Was working fine then it went out. Unplugged it power wise and it ran a few minutes then went out again
This may be due to a faulty A/V cable. If you can, try another cable (HDMI for Xbox slim models). It'd be cheaper to purchase another cable and see if that's the issue first.
Oct 27, 2013 | Microsoft Xbox 360 Console
Hi. I have a Marshal MG10CD amp. It was working fine, till a few days ago, when it suddenly stopped functioning. The amp gets power supply, as you can hear static when switched on, however, when the...
Check for a dry/cracked solder joint where the 1/4 inch phono input jack connects to the printed circuit board. Solid state Marshalls are renowned for this.
Feb 23, 2011 | Marshall MG10CD 10 Watt Combo Amplifier
For the last few days my 2000 Saturn LS has been having issues when I try to start the car. When I put turn the key all the electricity dies. Popping the hood and jiggling the battery restores the...
if you can jiggle the battery cable, its loose. or dirty,tighten the cable ends...tight. You may need to disconnect the battery and make sure that the ends are clean and bright.
Dec 08, 2010 | 2000 Saturn SL
Prior to past few days printer worked fine. Now it prints a few postcards then gives a print buffer message on printer screen and from there on it prints gobbledy gook. Now it won't even print a test...
Sounds like you cover all the bases. I just wonder if you reset the unit via the service mode?
resetting the printer should have cleared the memory.
Hold down select and return while powering on machine, hold until self test comes up on display then press go, this will get you into service mode.
Run the memory diagnostics.
Nov 23, 2010 | Lexmark T642 Laser Printer
2004 Vue, both engine lights on and no power.
high five you fixed it. thats what i like to call a WAG diagnostic... Wild *** Guess
Oct 02, 2009 | 2004 Saturn VUE
Panasonic CT-27G34A screen jiggles/glitches up and down slightly
Sounds like dried up cap either in vertical circuit or power supply.
Apr 27, 2008 | Panasonic CT-27G34 27" TV
EMERSON EWL3706 37 IN. WONT STAY ON
had same problenm with mine it was a fuse that blew. took repairman 5 minutes to fix charged $136.00
Feb 07, 2008 | Emerson EWL3706 37 in. LCD Television
Falty Amplifier?
It sounds like the output transistors have shorted. This is VERY common. If you want to try to troubleshoot the problem, I'd need to see photos of the inside of the amp. You'll need a multimeter to check the transistors.
Before opening the amp, remove it from the power source.
Since the resolution is severely limited here, send the photos to me directly (babin_perry@yahoo.com). If you're going to send multiple photos, please zip them and send one file.
Dec 21, 2007 | Legacy BLUE 4 X 250W CAR AMP Car Audio...
Sony DCR-HC40 Battery Charging Problem Hi Mates - I did purchase a Sony DCR-HC40 camcorder around an year back and it was working superb till few days back. As of date, i am facing a problem where...
Had the same thing happen to me. Went out and bought a new battery and it, too, does not charge. Apparently something messed up with the in-camera charging system. It will charge for several minutes (charge light illuminated) and then the charge light goes dark. Battery gage shows that there is virtually no time left on either battery (old or new). Anyone have any ideas other than a trip back to Sony?
Sep 14, 2005 | Sony Handycam DCR-HC40 Mini DV Digital...
23 people viewed this question
 Grubhead
Grubhead
