Candy CE124 washing machine
I have found the element on my Candy CE124 is faulty, can you please tell me how to remove/replace it - can this be done entirely from the rear?
Tricity bendix washing machine will not complete cycle aw1201, its starts the cycle then goes straight to the end
Posted on Jan 24, 2010
Grand o 282
Seems that you need to check if the door switch is faulty or there is fault or loose connection on the switch. Remove and check for the switch action, replace if faulty.
Nov 21, 2013 | Candy Washing Machines
I think I have a coin between inner and outer drum CE124. Do I need to remove it or just put up with it clanking on spin?
I would not try to remove it if I were you,, best to leave it alone as it should eventually find it's way into the pump filter.
Nov 22, 2010 | Candy CNW136 Front Load Washer/Dryer
Candy Eclypsa CE124/1 drum does not move on any cycle, even spin cycle.
It sounds like the motor brushes have failed. Quite a common fault and not too complicated to fix.
Oct 25, 2010 | Washing Machines
My candy fan oven has no heat when turned on
If the fan is working o/k, then it is going to be a faulty oven element, fitting a new one should solve the problem.
Mar 29, 2010 | Candy Ovens
How do a change the element on a candy oven , can't get to the old element
You have to gain access to the element by removing the outer rear panel of oven, if it is built in, then this means removing it from the housing.
Once you have removed the cover, and possibly the top panel, you will see how the element is fitted.
It is a fairly straight forward repair to do.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Candy F248P Electric Single Oven
Candy Nova CN126T - No hot water
hi This control panel switch regulates the temperature of the water in the tub. It also plays a role in controlling the fill cycle. If you suspect this switch is faulty, remove it and take it to a professional service person for testing (the test takes special equipment). Or, hook a test wire across the switch terminals; if water flows, the switch is faulty. If the switch is faulty, replace it with a new one of the same type. Connect the new switch the same way the old one was connected.
If there's a problem with both water temperature and tub filling cycles, both the temperature switch and the timer may be faulty. Test both components and replace them as necessary. Procedures for testing the timer can be found below.
Sep 13, 2008 | Candy CN126 Front Load Washer
Heating element Candy DQW150 Where is it please?
i think you amy have 2 faults. the elements for wash and dry are completely separate.
Apr 18, 2008 | Candy DQW150 Front Load Washer / Dryer
CANDY AQUAVIVA WASHER/DRYER
its either the motor or element gone, remove the back of the machine and remove the wires from each component mentioned. try the element first , MAKE SURE U TAPE UP THE REMOVED WIRES BEFORE TURNING THE MACHINE BACK ON , U WILL GET A SHOCK IF U DONT!!!. if it does not trip , then the element is gone. like wise do the same to the motor. just one more item to check is where the mains cable enters the inside of the machine. good luck
Jan 22, 2008 | Candy AQW130 Front Load Washer / Dryer
Buttons on CE124 candy eclypsa not working
the on/off switch sounds faulty they can get hot and jam, with the button stuck in you cant open the door, the switch will have to be replaced
Jan 18, 2007 | Candy CN126 Front Load Washer
Washing Machines Logo
110 people viewed this question
Top Washing Machines Experts
