Question about Vacuums
Broken belt, motor wont turn - Vacuums
  • Anonymous Sep 08, 2008
    how do I change the belt?
    Have taken bottom off, but don't know where to put the belt
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=721048
Generic problem for all Vacuums
Broken belt, motor won’t turn
Posted by msmclovin on Jun 29, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. If the motor shaft won’t turn then you may have a bad motor or a stick carbon brush, but if it is just the belt the replace the belt with a genuine belt because the average belt change id every 4 to 6 months for the best cleaning and to store the extra belts in a Ziploc bag in the refrigerator. But you question does not tell me what brand name and model # it is so I have a hard time to diagnose the problem for you so my explanation if just a generic one and should work for you but next time please note the brand name and model #. If you have further problems please feel free to contact your local vacuum cleaner dealer in your area or call the Kirby cust serv dept listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 30, 2008
Brush wont move and its not the belt
If the belt is not broken, most likely the brush roller needs replacing. If the brush roller turns freely then it is likely the pulley on the motor that drives the belt.
Oct 03, 2014 | Proteam ProForce® 1500XP Bagged Vacuum
Air driven turbo brush
Is this the Lightning model? How old is it? You may have to just replace the belt.
Also, the front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
Nov 27, 2011 | Fantom Vacums Vacuums
The roler in my vacuum wont turn
Hi, sounds like you have a broken or stretched belt.Most belts can be accessed from the bottom. If not your belt it could be a stuck bearing or even the motor. More likley the belt though. Chris
Feb 21, 2011 | Kenmore Progressive Direct Drive 30912...
Motor turns on, but brush won't turn. belt is not broken
Sometimes hair and debris get in the end of the rollers and keep them from turning. Also, the bearings can become corroded and stick. Try removing the rollers and check for any debris and remove it. If the bearings are stuck, you can spray some lubricant or WD40 or them and try to free them up. On occasion the belt can come off of the motor. You can turn the unit over and see if the belt is moving over the roller. Good luck and let us know how you made out.
Mar 04, 2010 | Bissell 3920 Bagless Upright Vacuum
Belt and brushes turn free by hand will not work when turned on
So, your belts are attached and aren't broken or slipping. Well if that's so, then it sounds like the motor driving the belt to spin the brush roller is shot. Take it to a local vacuum shop and have it inspected for this problem.
Aug 13, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Riccar 1700 power nozzle wont turn on
Make sure the 'Power brush' switch on the contol panel on the hose is depressed. Check the circuit breaker on the power nozzle; it will either be a button or a breaker that looks like a rocker switch, try to reset it.
Is the power nozzle motor running but the brush just isn't turning? If so you may have a broken belt. Not a likely solution since the belt is a lifetime belt, but still remotely possible.
Apr 23, 2009 | Riccar RC1100 Compact Vacuum
My vacumn wont pick up from the bottom but the hose works fine. I emptied the bag and the green light is on.
Either the glide plate at the bottom is blocked or the belt is broken
Please leave feedback
Thanks
Rob
Feb 12, 2009 | Bissell 3522 PowerForce Bagged Upright...
Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
May 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Vacuums Logo
231 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
