Question about Husqvarna Husky 165
Is there a bar oil adjustment on my 36 cc husqvarna chain saw. Where might is be? Cheers paul
  • Anonymous Mar 16, 2014
    adjust oil to bar and chain on a 455 rancher
    Problem Solver:
  • 11 Answers
If there is one it'll be underneath the saw just behind the clutch cover/side plate. Though some of the smaller cc / hobby saws don't have an oil adjustment screw. happy hunting
Posted on Sep 21, 2009
I need to adjust the sewing speed is going really slow
1. Loosen your hand pulley by removing a small screw that is on the outside edge and take your pulley off. The pulley also has to be rotated to unscrew it. Check the belt to insure the belt is aligned and push down to see if it is too tight. The motor can be loosened to adjust for tightness and alignment. If the belt is cracked it should be replaced. Try to also oil all moving parts including the needle bar while you're at it. Also, oil the race that is under the bobbin with one drop of oil. If that doesn't correct the problem you should try another foot control.
Nov 28, 2013 | Husqvarna Husky 145
Trying to find an owners instruction manual for Husqvarna E. series 450 , 16 in gas chain saw.
Umm. Husqvarna makes both sewing machines and chain saws (good ones). But this needs to be posted in a category other than sewing machines. I would suggest "Home & Garden/Patio & Garden" as the most likely one I could find for you. Good luck.
Jan 26, 2011 | Husqvarna Sewing Machines
Hi,, my husque 141 dont seam to reach top end speed? it was ok till I cleans air filter
I am afraid you have confused sewing machines with chain saws!
One stitches fabric and the other makes a lot of noise and heaps of saw dust and wood chips.
Search the topics where the big boys play!
Mar 10, 2010 | Husqvarna Designer I
Chain saw probles
chain oil tank is pressurised...release pressure before storing...but it will still drip some
Mar 09, 2010 | Husqvarna Designer I
Hi, I have a huskylock 905 NOT computerized and it's making a "clunking" noise while sewing and then the "D" thread breaks. I've re-threaded many times, changed thread, changed needles, adjusted tention...
Sounds like the D needle is hitting something in the loopers and an adjustment needs to be made. The adjustments are ever so slightly. It could be that the needle bar is twisted causing the D needle to hit. It could be the looper is not within the specs for proper operation, etc. Suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page -
Good luck.
Nov 18, 2009 | Husqvarna Huskylock Computerized 905
Looking for spare parts for husqvarna electric chain saw. .Casing needing to be replaced.
Submitted to sewing machine category. Resubmit if still an issue.
Oct 02, 2009 | Husqvarna Designer I
Local Parts ?
Sounds like a chainsaw issue.........this is a sewing machine forum, suggest a re-post in a different category to get a sensible response quickly.
Sep 09, 2009 | Husqvarna Husky 165
Viking 936 uneven stitches with loops
Sounds like either the loopers need adjusting or there is a twist in the needle bar. These are all things that have to be done by a certified husqvarna viking service technician via an authorized HV dealer. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page -
Good luck.
Apr 07, 2009 | Husqvarna Huskylock Computerized 936
Husqvarna chainsaw repair
Usually empty fuel, use hook to pull out line , remove filter. Remove air filter cover and airfilter ,now you should be able to see line. Most just pull of carby and go through tank, some you may have to take screws out of av mounts in back of tank to see hole to put it back in.cheers hope this helps if where a stihl i could tell exactly.
Oct 29, 2008 | Husqvarna Husky 165
My Husqvarna 142 chain saw, new out of the box, starts and runs well enough but left to idle it continually stalls. Any ideas?
The carb needs to be adjusted. Look for 2 adjustments label High(H) and Low(L). Low is the one that you want. Start you chainsaw and let it warm up and turn the L adjustment a until you are able to let it idle on its own. Hope this helps.
Jul 07, 2008 | Husqvarna Husky 165
Sewing Machines Logo
100 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
