Question about Microwave Ovens
After connecting the water pump on caravanand turning it on and opening taps the green light stays on .the water then comes out of taps and also gushes out of the drain plug on outside cowl.no red light comes on to tell us there is a fault.could you please tell me what the problem could be and how to fix it many thanks jim.
  • Microwave Ovens Master
  • 9,098 Answers
You may get better response of you post this in a more appropriate category.
Posted on Jul 01, 2008
I have a Russell Hobbs RHM2018 microwave oven with grill and the turntable will not stop going round and the light stays on until I unplug it? Once plugged back in it carries on in the same way? If I
The switch for the turntable does not disengage anymore. Could be a relais, could be an electronic switch. When opening the door, a second switch, in series with the other one, connected to the turntable motor disengages, stopping the motor. The light is switched on, because you opened the microwave. Perhaps you never noticed this, but it is the normal way that should work.
Aug 31, 2014 | Microwave Ovens
We are not getting water to our toilet. When you step on the flush pedal the pump does not kick on and no water comes. We have water to all other taps and shower
There is a valve that is probably stuck....when the water empties from the cistern the float will lower with the water as it flushes...this opens the valve to allow new water in, when the float rises to the required level it shuts the valve. there is no pump just check clean or replace the valve. Alex.
May 19, 2011 | Microwave Ovens
I have a mixer tap in the kitchen sink. The hot water tap runs fine but I am not getting any cold water. I also have a bath downstairs and the cold water tap there is fine
You will have to turn off your water mains and strip your mixer tap. It is possible that the seal (if it is an older tap with a rubber seal) has become stuck or the threaded part that turns it has gone faulty. If it is a modern tap with ceramic seals, check the operation of the mechanism and see why the ceramic seal is not being opened.
Mar 26, 2011 | Microwave Ovens
Machine goes thru all the wash cycle but gets to last min and keeps spinning then comes up with f11
Not knowing what sort of machine you have, one of these should help.
F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
F11 - Pump cannot be activated - Book a washing machine repair.
F11 - Heater timed out. The heater has not reached the required level. Book a dishwasher repair.
F11 - No pump connection - Book a tumble dryer repair.
Mar 17, 2011 | Microwave Ovens
How to install led display
Disconnect from any power source. Remove the outer case. Press to open the door and just beneath the open button there is a self tapping screw holding the front unit down and in the slots. Remove the screw. Remove the plugs making a note of where they all came from! (A mobile phone camera is very handy for this job).
The panel assembly will come away from the chassis now.
Unscrew the display panel and disconnect.
Fit and connect the new panel, re fit the assembly and connect the plugs, refering to your drawing/photo.
Replace the screw after fiddling around for a while getting the mechanism in the correct place.
Fit the outer case and test with 1/2 litre of water. Measure the temperature of the water in the beaker. Heat on full microwave power for 1 minute. Check the temperature.
For your machine the temperature rise should exceed 9 degrees Celcius. If it does, you have a safe microwave cooker.
Hope this helps.
Feb 17, 2011 | Sharp R-360E Microwave Oven
I have a bosh dishwasher that has not drained of water and the tap light is red on the indicator board
Hello there:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
If the motor isn't turning or working, the unit won't drain. Some dishwashers are susceptible to getting stuck if you don't run them regularly. I you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Jul 08, 2010 | Microwave Ovens
Microwave has a short if you tap it then it comes on for a sec then lights go out again. We opened it up but can not see any loose connections. It did however come on and stay on when last screw was taken...
sounds like your safety door interlock microswitch is mis-adjusted,it is made to blow the fuse if you open the door during operation,if they get loose or mis-adjusted this will happen
Sep 30, 2009 | Microwave Ovens
Rv water pump
Get under the RV while the pump is running (be safe, chalk the wheels, make shure it is stable), then look for the running pump location. Once found, shut the pump, get back inside and find the compartiment where it is located (usually behind a panel that does not open by hand) use a screw drive to open it. Find the pump and ensure that you verfy the valves and all accessible fittings. To do that use soapy water, apply it on the fittings and valves. If you happend to see bubles forming that means that the pump is sucking air from that area and does not make a 100 percent seal which will falsly lead the shutdown of your pump. Also refer to your pump manual for proper placement of your service valves. Hope it helped!
Aug 28, 2008 | Hotpoint RVM1435 Microwave Oven
1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Aug 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
69 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
