Question about Toshiba Satellite A105 Notebook
Hard drive Need to change hard disk drive on a Toshiba satellite 1110
    Problem Solver:
  • 11 Answers
Go to Toshiba website and see tech specs/manual/put in ask IRIS block-replace hardrive, will ask for your make/model and a pic will be displayed explaining location--remember there is a disclaimer so check to see if under a warranty first, also you have the recovery CD handy, do a backup for crucial items you need.
Posted on Jun 29, 2008
Hello, What cable or adaptor do I need to transfer all data from the hard disk of my Toshiba Satellite Pro A200 to my new laptop via USB port? Thanks.
You won't be able to transfer hard drive data by plugging one computer into another via USB. In order to transfer data, you will need to remove the hard drive from the Toshiba Satellite Pro, use an external hard drive enclosure, and attach that to your new computer with any USB cable.
The hard drive can be taken out by removing screws on the bottom of your laptop. The drive can be found in the bottom left of this picture: http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Here is an example of the exclosure you would need: http://www.newegg.com/Product/Product.aspx?Item=N82E16817816013
Mar 14, 2011 | Computers & Internet
How do I remove the hard drive in Toshiba SatellitePro A10 EN? (Removing the plastic cover exposes only the end of the hard drive. I'm reluctant to just start pulling on it!
  • The original Toshiba Satellite Pro A10 HDD is fitted into a Toshiba Satellite Pro A10 Hard Disk Drive cradle - Toshiba Satellite Pro A10 HDD caddy.
      • Gently remove the cradle from the laptop, yes pull on it
      • Unscrew the original Toshiba Satellite Pro A10 Hard Disk Drive & remove it from the cradle.
      • Screw the new Toshiba Satellite Pro A10 Hard Disk Drive into the cradle & refit the cradle into the laptop.
      • Re-install XP or Vista
          Aug 21, 2010 | Toshiba Satellite A10 Notebook
          Hello. i have the toshiba satellite a200-28n and would like to replace the harddisks at 5400 to 7200 rpm.the types of disk are two mk2046gsx 200 gb each one.what harddisk can i choose for...
          The maximum size hard disk you can install in your Toshiba depends upon the BIOS. The BIOS can support a hard disk up to a certain capacity. Check the specification of your model Toshiba to see the maximum hard drive it can support.
          An alternative -
          You can use an external USB hard drive and connect it to your Toshiba and not be restricted by the BIOS. You can use USB hard drive 500 Mb to more than 1 Tb.
          The other advantage of using an external USB hard drive is you do not need to install Windows, the device drivers and your programs on the new hard drive.
          Jun 11, 2010 | Toshiba Satellite A135-S2386 Notebook...
          Recovery Disc will not load OS on HD
          laptop panasonic toughbook bios password pro
          Apr 07, 2010 | Toshiba Satellite Pro L300 Notebook
          Hard disk capacity increase
          yeah you need to replace the old hard disk to new IDE 120GB hard disk.
          Jan 20, 2009 | Toshiba 100GB Laptop for Satellite 2400,...
          Hard drive
          These instructions should help.
          Toshiba® Satellite 100, 105, 110, 115, 200, 205, 210, 400, 405, 410, 420, 430 Series
          Hard Drive Installation Instructions
          1. Turn notebook upside-down.
          2. Remove the battery compartment cover.
          3. Remove the battery pack.
          4. Remove the 2 Phillips screws that mount the hard drive down.
          5. Slide the hard drive away from its connector and gently lift it out of the notebook.
          6. Remove the tray from the old hard drive and assemble it onto the new hard drive.
          7. Slide the new hard drive into its connector inside the notebook.
          8. Replace the 2 Phillips screws used to mount the hard drive into place.
          9. Replace the battery pack.
          10. Replace the battery compartment cover.
          Jul 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
          Hard drive
          I think as bigger drive as ya can afford say up to 80GB.. would be OK.. just make sure that the new drive is same type as old and ya be all good.
          Jul 28, 2008 | Toshiba Satellite A105 Notebook
          I need to replace my hard disk notebook with a bigger capacity hdd
          Toshiba is rather secretive with their documentation. It is hard to find. Google TOSHIBA SATELLITE A10 SERVICE MANUAL and check the available offerings.
          You now have a 5400 RPM, ATA 100 drive. You should not have any drive size restrictions. Shops are advertising many large drives as compatible.
          I suggest that you purchase only a 7200 RPM drive. The faster speed will perk your machine right up.
          I have not worked on Toshiba machines but suggest you have all restore disks and passwords at hand.
          Feb 18, 2008 | Toshiba Satellite A10 Notebook
          Toshiba Satellite A105 Notebook Logo
          114 people viewed this question
          Top Toshiba Computers & Internet Experts
          Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
