DVD player/recorder will not accept a disk when inserted. The only way is to unplug it. It can not be turned off with the switch. Once in, it plays fine. It is a DRC8320N Combo unit.
  • chucke002 Jun 30, 2008
    Not really. I just spent $10 for advice telling me to do what I was going to to anyway!
  • 6,487 Answers
There should be some parts of this DVD player that needs replacement better check it with the manufacturer for the replacement and repair of this unit...
Hope that helps........
Posted on Jun 29, 2008
  • 13,433 Answers
Seems like a hardware problem - I recommend you get it warranty repaired if you still have warranty on it.
When I insert a blank DVD+R to copy a VHS, It reads the disk, says "Unknown Disk" and ejects it. How do I record if I can't keep a disk in the machine?
What speed of disk did you use? On my older machine if I use faster than 4X it will not accept the disk. Check out your disk an see if the record speed is to fast for the machine.
Jan 29, 2015 | GoVideo VR3930 DVD Player/VCR
Samsung DVD-VR330 unit will not accept a brand new blank DVD-RW disc---machine says 'load' for 20 seconds, before saying 'open', which it does.
The DVD-RW will work at random, some brands will wok better than others. Memprex, Sony, Maxell are 3 I can use sometimes. Once the disk is accepted it must be formatted. Click that and if accepted, first do a record for say 2 minutes to see if ti works.
If it works don't take it out until you're ready to finalize it.
That's mostly so the disk will be readable in other players, should it not want to go back in, you probably lost the record.
Don't write on the back, use a card and keep it in the cover.
Sometimes I can use those disk's in PC for data.
regards
Jan 03, 2013 | Samsung DVD-VR330 VCR and DVD Recorder
When i insert a blank disk i get cannot format disk message
sorry that you getting this message......... but the ch-dvd 300 is not a recording machine........it only plays recorded DVDs
May 08, 2011 | Cyberhome CH-DVD 300 DVD Player
I cant get my dvd player to accept the disk...it keeps saying no disk
A few small things to try. Turn off unit, unplug for 5 minutes, plug back in, turn unit on.
There is a product called a cd/dvd lens cleaning disc. Worth the investment to have around.
Apr 28, 2010 | Cyberhome DVR 1600 DVD Recorder
CyberHome DVD 1600 won't record to Sony disk
I believe the recorder is bad, it should be able to accept all brands and types of disks. You might want to try another brand and type of disk just to make sure, if it does not work, the recorder is bad. Good luck to you!
Jan 03, 2010 | Cyberhome DVR 1600 DVD Recorder
It says "Disk error" on any disk. It won't read disk
turn off and, unplug your DVD recorder remove the six screws holding on the top tilt the back of the top up disengage the front of the top and set it aside look for a small laser tag this will point to a 1/4 inch glass lense this is the laser taking rubbing alcohol on a q-tip gently clean the lense with a twirling circular motion
Apr 28, 2009 | RCA DRC8300N DVD Recorder/VCR
Front load DVD player will not accept the disk.
Invest in a new DVD player...it will be much simpler, will cost roughly the same amount AND save you the hassle of finding someone to repair the broken drive gear (cog) on the insertion/eject roller (if all else is known to be working). You will find it on the left side of the DVD bay connected to a tiny white worm gear and even smaller reduction gear. If you are handy with a precision hobby mill, you can easily turn a replacement gear out in relatively short order with only the tedious tasks of disassembly and reassembly of the shaft end to deal with. Be certain to unplug and discharge the capacitors in the machine before messing about the inside of the player (UNplug player and press the I/O, "on button," twice). One sturdy knife blade, one standard philips head and one small philips head screwdriver will be all you need for disassembly. If you are capable of opening the chasis and the DVD housing, you will be capable of removing the speed nut from the shaft of the insertion/eject roller and of deciding from there what you should do. Good luck.
Mar 31, 2009 | LG LDA511 DVD Player
Vcr to dvd recording
As i recall, +r's will only format in dvd vr, the unit does not like high speed recording disks. switch to dvd drive - insert blank disk - if no format screen - goto (on remote) setup - onscreen menu - system setup - disc setup - new disk format - hit center button in ring on remote to change to vr or move up to reformat as vr. once disk is formatted, use record speed button on remote to set record speed 1,2,4,6 hr then switch to tape deck with tape in and stopped at begining, on remote hit dubbing, it will ask you confirm dubbing vhs-dvd .... toggle over to yes & hit center button... away you should go... c245 is a copyguarded tape.
Oct 09, 2007 | Sansui VRDVD4005 DVD Player/VCR
Panasonic DMR-ES15
Just unplug it and let it sit for half an hour. Then try playing the lens cleaner disc, the problem would be fixed....
Sep 10, 2007 | Panasonic DMR-ES10 DVD Recorder
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
