JVC KD-85 Cassette Deck Stops in Seconds in play, REW., & FF
Above noted deck, JVC KD-85 cassette deck, that I purchased brand new in 1980, just recently developed this problem that when I attempt to play a tape, it runs for a few seconds (up to 3 sec.) and then stops as someone hit the stop button.
It has the same issue when rewinding or FF with full load, up to near 1/2 tape capacity.
Also, upon insertion of tape, when the sensor pin is activated, a high pitch, a squeaky high pitch but very low noise can be heard.
All visible components, heads, capstan, pinch roller,...have always been cleaned regularly.
Do I need a new belt, a new motor, ...?
I thank you in advance
  • 1,512 Answers
Hineovision1
The deck will need new belts and idler drives cleaned and serviced, and perhaps some idler tyres replaced. You can get a belt kit from these guys. replacing them is not such a difficult job if you have some mechanical aptitude. Just take it slowly, and focus on getting the transport out of the unit.
I am more than happy to answer any other questions you may have aboutit, please get back to me here, or use the ASK function to go straightto me :) If you are still unsure, have problems, or we need to look atthe situation more deeply, then before you give a rating for thisadvice, hit the ASK buttonThanks for using FixYa, If you consider the advice I have given you assound, a FixYa rating is a great reward for my efforts to help you.Cheers.
regards
robotek
Posted on Jul 08, 2008
Tape deck wont play only makes noise
The drive system is not functioning. Could be belts
Oct 19, 2012 | Sony Audio Players & Recorders
RE:JVC CASSETTE DECK MODEL # KD-D4J,PROBLEM, TRANSPORT JAMMED WITH CASSETTE INSIDE,ALL BUTTONS/CONTROLS INOPERATIVE? OPENED UNIT AND MANAGED TO REMOVE CASSETTE ,DID NOT USE UNIT AGAIN. THIS PROBLEM...
it sounds like your tape heads are worn they will strip your cassettes every time and give you very poor sound reproduction it can be repaired but costly to be honest you would be better off with a new deck and it will be cheaper all round.
Mar 27, 2011 | JVC Audio Players & Recorders
Playing a tape on Deck B stops after a few seconds. Tried over and it stops again after a few seconds of play.
Either tape is tight, run it ff the rev all the way back, or transport is failing , motor , belt , pulley etc,
check tape or try another one in deck b, how is deck a
Sep 21, 2009 | Onkyo TARW255 Single Dual Cassette Deck
Hi, My Pioneer CTF-7272 Cassette Deck has stopped playing. Rewind works fine, but FF and Play will run for about 5 seconds and then the tape just stops. Any info on this problem is greaty appreciated....
check the belt whether it is broken or loose. if so replace the belt.
I hope this will solve your issue.
Good luck
If my solution proves useful please rank it.
Regards
Arjun.
Mar 27, 2009 | Pioneer CT-W205R Single Dual Cassette Deck
Onkyo TA-207 3-head cassette deck
The gearing and rubber parts involved in FF or REW vs. play are different. This unit should be overhauled and all of the rubber parts replaced.
Dan
May 28, 2008 | Audio Players & Recorders
Cassette Tape stuck
Try pushing the eject button while pusshing the power button. Mine was doing the same and that is how I was able to eject the tape.
Good luck
sam
Jan 01, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Problem with deck B on Pioneer CT-W205R
Better tape decks, like Pioneer, may use a different mechanism for record/play than FF & REW. So it sounds like a belt or mechanical link for the REC/PLAY has failed.
Dec 20, 2007 | Pioneer CT-W205R Single Dual Cassette Deck
Cassette tapes
try firmly banging the cassette onto a table top(with reels flat) a few times, then ff right through and rew a couple of times. this will layer the tape more evenly and hopefully allow the mechanism to play it. the takeup reel or autostop mechanism may be failing if the deck does not have enough torque to carry the tape and may require belts replaced or dried grease removed in the transport.
Dec 07, 2007 | Tascam 202MKII Single Dual Cassette Deck
NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Dec 06, 2007 | Audio Players & Recorders
901 people viewed this question
 Grubhead
Grubhead
