Question about Sony Playstation 3 (PS3) Console
Ps3 fan doesnt work?
My ps3 got wet now the fan doesnt work and it overheats in like 5 min.
  • 4 more comments
  • miabllrs Jun 30, 2008
    hey my fan didnt get wet but it did stop working...do u kno where 2 get a replacement fan?
  • designer171 Nov 15, 2008
    my console is overheating.... fan works i check it out side i plug it to computer... so i dont know what's a problem..
  • Anonymous Jan 10, 2009
    HELLO
  • cynele Mar 10, 2009
    I have got a ps3 and i was playing it for a long period of time. I was playing it online and it started to freeze and blow out hot air. I think my fan/motor isnt working because it overheats reallyfast withn 10-15 mins. Does anyway one know how much it is in pounds to get a new fan ?
  • Anonymous May 19, 2009
    FML
  • chevellepurp
    chevellepurp Feb 08, 2013
    if you have ps3 slim with the light up power and eject buttons that look like this go to amazon.com and buy a ps3 xcm led fan and that should fix it once you install it. it cost 39.99
    Problem Solver:
  • 7 Answers
I have solution for all of you. You need to call sony at 1-800-345-7669. They will send you a box so you can place you unit in (ps3). If you got warrany on your ps3 they will ask you to send in a copy to varify that it is still in warrany. If it is then they will not charge you anything they will open up the system and see what the problem is either fix the ps3 or they will replace it with a refuribished one. Also you need to make sure that the warrany tag on the ps3 upper right side is still there or they will charge you 150 dollars. And if the serial on the back is removed they will not even service your unit. If you unit is not in warrany they will charge you 150 dollars. Wich is real good because they will dust the interior of it good luck everyone...
Posted on Mar 20, 2009
  • mickelmason
    mickelmason May 28, 2012
    but im in england
For me my ps3 (40g) was vertical and got a bit too hot for the cheap thermal paste sony uses. Once it heats up it leaks out from between the heatsink and cpu/gpu. It also happened to get in my fan. Solution; replace the fan. Disassembly can be found on youtube and is simple. Replacing the Fan is a snap and I recommend Arctic Silver 5 on your Cpu and Gpu to avoid having any more issues.
Posted on Aug 25, 2010
If you want to see PS3 get disassembled go to youtube and search Gilskey. he has videos of disassembly. if your PS3 has a warranty and you disassemble it, the warranty will be voided!!!!!!! you can buy replacement fans on ebay.
Posted on Dec 03, 2009
My fan is making a loud noise after i dropped it by mistake. how can I get the top off to correct it is it possible.
Posted on Jun 11, 2009
I carefully opened my ps3 as the fan had gotten stuck, the way the fan is designed, (Large 4 inch or so) required a reseat ( push the fan back down to the motor) The way it's designed is that if the ps3 tips from vertical over to horizonal rather roughly the fan becomes displaced, I gently pushed the fan back down and it was free as a bird again, max cool. I think if the system is tipped over frm vertical, too many times roughly tha fan would probably be worn out, so I'm shopping for a back up. A aftermark external would probably work too, But remember though the internal fan is a stepper motor, if the cpu thinks it's not rotating.. cool or not it will probably indicate failure and resume a shutdown condition... best of luck PS have a spare fan on hand...
Posted on Jul 11, 2008
My fan stop to, and worse is that i live in venezuela... if u know something let me knkow thanx
Posted on Jul 01, 2008
Fixed!
For PS3 , You can try Adapter FAN . Forme is working!
cool!!
ALex
Orlando Florida
pc1@techemail.com
Posted on Jul 03, 2010
    Problem Solver:
  • 7 Answers
First off, u shouldn't have gotten it wet!!! second of all im sure theres nothing u can do to make a fan start working again, either get a new ps3 or try buyin an external fan
Posted on Jun 29, 2008
Car heats up very quickly no end in site
there are a number of things that can cause a car/truck/suv to overheat! #1. bad thermostat. #2. partially clogged radiator. #3. faulty radiator cap. #4. bad clutch on fan,or bad electric fan,or bad fan relay. #5. blown head gasket. These are the most common among all types of vehicles,I did notice you said "quickly" overheats. If the car is totally cold and overheats within 3-5 min of starting up, that is a pretty good tell-tell sign of a blown head gasket. if it takes a while longer to overheat,check the other items i listed.( always start with easyer and cheeper items first and work your way up from there) hope this helps ya out....yz-maniac.
Nov 11, 2010 | 2001 Jeep Grand Cherokee
Playstation 3 turns off by itself
this could be your ps3 overheating due to your fans being blocked by dust, clean your ps3 with a damp cloth, not wet as this will damage your ps3 even more, if this doesnt work and your ps3 is still within warranty take it back and get it fixed for free, if you need more help dont hesitate in writing back
Apr 20, 2010 | Sony Playstation 3 (PS3) Console
Ps3 doesnt display on my tv on regular plug and shuts off after 2 mins
The PS3 combines the features of a game console and a Blu-ray player in one device but like many highly sophisticated devices it can easily overheat. An overheating PS3 displays an LED on the front called the "yellow light of death" and shuts itself off after a few minutes. Repairing a PS3 system so that it doesn't overheat can be done at home, although you will need to open up the case and add heat dissipation paste to the GPU and CPU chips inside of the case. But it costs you more rather you can send the unit to SONY.
Apr 04, 2010 | Sony Playstation 3 (PS3) Console
Loud noise coming from ps3 after short while
sounds like youmay have something stuck in the fan or in another moving part you may want to take it apart and clean it.
Nov 29, 2009 | Audio Players & Recorders
Ps3 overheat
Your PS3 might have a broken fan. If you are using an external fan that attaches to the PS3 than stop, fans like the Nyko Intercooler and Pelican cause more problems with ventillation and may cause the PS3 to overheat. If heat is an issue make sure the system has plenty of room to breath and point a small fan at the console. If thiat doesn't work call Sony customer sopport.
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
My playstion 3 will overheat and shut off after jus a few mins of playing ps3 games
it may be that you have used it too much or left it on for too long. send it too sony to get it fixed or buy a ps3 cooling fan to help
Sep 13, 2008 | Video Game Consoles & Games
Help?
Sounds like a blown fan.. new one is 15$ on ebay and about 15 min fix.. or ask sony.. or get an external cooler for 30$ at walmart...!!
Jun 29, 2008 | Sony Playstation 3 (PS3) Console
Help?
sounds like your cooling fan is not working... replace fan inside or place a fan blowing on back of unit for temporary use only
Jun 29, 2008 | Microsoft Xbox 360 Console
Sony Playstation 3 (PS3) Console Logo
14,654 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
