Question about HP Computers & Internet
Networking XP and Vista
I can't get my Vista computer to recognize my xp...have loaded up software from Windows and done everything I can think of.
  • Aris C.
    Aris C. May 11, 2010
    Are you referring to file sharing here?
    Novelist:
  • 173 Answers
Since I won't be able to read your response, you can probably try these steps if it concern file sharing between your XP and Vista computer;
-Make sure that both machine have the same Workgroup Name.
-Turn off Firewall on both machine.
-Download the LLTD patch for Windows XP http://www.microsoft.com/downloads/details.aspx?FamilyId=4F01A31D-EE46-481E-BA11-37F485FA34EA&displaylang=en
- Make sure file and printer sharing is enabled for both machines.
- Restart the computer and check if they can now see each other wheb you view entire workgroup.
Hope this will solve your sharing problems.
Regards,
Posted on Jun 29, 2008
My Pavillion HP computer loaded with Windows Vista will not run the evision 123 software when I load it--it does recognize the port connection from the camera to the computer. I think the soft ware...
Unfortunately software you are trying to use is not written for Windows Vista, there is no alternative for it sorry :(
If its so much about using that software, I suggest you turn over to windows xp it will work there :)
thanks for contacting me, please rate my solution :)
Apr 13, 2011 | Computers & Internet
Dell insiprion 1545 audio driver for xp not installing. 1545 is designed for vista and am trying to load xp
Try installing the driver from the Dell WEB site.
You can download the drivers from Dell WEB site, thesupport download page. Make sure you select your model desktop or laptop,better still, type in the Service Tag number, it is printed on the label on thebottom of the laptop and on the back or sides of a desktop. (If the Service Taglabel is missing then go into the BIOS setting and on one of the BIOS pages,the Service Tag number will be displayed). This will open the page where thespecific drivers for your model computer are located. Also make sure you selectthe Windows XP or Vista version of the drivers for your Windows operatingsystem. Click on this link to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Jan 23, 2011 | Dell SigmaTel High Definition Audio CODEC
Sata drive is not recognized by os during new install
When installing XP or Vista you get the option to load third party drivers for unknown devices. I think it's F6 just after the start of any version of Windows, once you press this you will have to supply the drivers for the Windows installation. This will make Windows recognise the hdd from then on.
Aug 18, 2009 | Gateway MT6821 Notebook
Unable to check cartridge ink level on new computer.
i think the problem is on that software.pls check the software cd or DVd. if it is fully compatible with windows vista.
Jun 13, 2009 | HP OfficeJet 6310 All-in-One Printer...
Cannot run Fujifilm Software for FinePix with Windows Vista
1) If you right-click on the executable file, can you use the
"Compatibility" TAB to run it as an XP program?
2) Many XP device drivers will fail to install or execute properly
under windows VISTA, and I suspect it is the camera's USB
or Fire-wire (IEEE-1394) based device driver that is causing
the problem, not the main application.
Unfortunately there is NO easy solution for this,
except to get an upgraded software package (for Vista)
from the Camera Manufacturer.
3) There are also two possible work-around(s), but both require
some knowledge and software installation:
DUAL-BOOT
Install both Windows XP and Windows Vista on your
computer using two separate hard-drive partitions, and
a boot manager.
A partitioning tool like "Norton Partition Magic", formerly
"Power Quest" or "Acronis Tools" can be used to partition
the hard-drive non-distructively (your data is preserved):
a) Resize (shrink) the existing Windows partition.
b) Create a new partition for Windows XP (about 10 Gigs)
c) Install Windows XP-Pro onto the new partition,
d) Add both the XP and Vista partitions to the BOOT.INI
file on the boot drive.
Both windows XP and Vista do have multi-boot capability,
but the Windows XP boot manager may not recognize Vista,
in which case you may have to re-install or re-pair the Vista
installation. The Vista boot manager will recognize WinXP.
Running VISTA is generally a bad idea, because it is obscenely
slow and inefficient compared to XP, and because it is infected
Microsof't draconian and arrogant copy protection schemes,
known as DRM = Digital Rights Management.
Towards this end, Vista also insists that all installed multi-media
devices must be "Recording Industry" compliant and approved,
to make music and movie piracy more difficult. Many media
copying programs and CD-rippers will also refuse to run,
by design.
All this "Added Technology" is stealing your money, your
computer resources, your performance, and your right to
backup your media, at your expense, for the benefit of
the movie industry Mafia.
Use Vista only when you have to, boot to Windows XP for
most of your applications.
VIRTUAL MACHINE
Both Microsoft and VM-ware (as well as others) make
a software product called a Virtual-PC, which allows you
to emulate multiple operating systems under windows,
including older windows, MAC and Linux.
VMWare is by far the best, the most reliable and the
most flexible, at about $200 US.
Martin
May 07, 2008 | Computers & Internet
Hard drive driver problem
It is possible that your hard drive is a SATA and therefore not readily readable by 98, XP but surprised not even by Vista. In any case, since you would still prefer to run XP (due to other software compatibility issues), pls press F6 when prompted by the XP installer. Additionally, you would need to have ready in a floppy the appropriate SATA drivers for your motherboard. They maybe downloaded from the motherboard manufacturer's website or possibly in the installer/driver CD that came with the PC.
Other than the above, it is also possible that you may have some issues with the availability of XP drivers for the other devices for that computer specially if it is branded.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Computers & Internet
Lost my right as administrator
You have done big mistake that's why you are getting problem.
1)Regarding installation of win XP over windows vista.
You have to install first lower version and then higher version i.e. you should install first win xp and then windows vista. But vice-versa you can't do it.
So my suggestion is that format your c drive then install win XP
after installation win XP install win vista.
2) which operation system do you want to open .
You can remove it using windows tweak utility software wich is freely available on most of the website. Also you can manually edit it.
For manually do this.( i m not sure about windows vista it is available or not)
right click on my computer->click on Advanced Tab->setup and recovery framework click on settings->click on Edit button
You will see the boot.ini file. You can remove the windows XP line from that file.
Oct 22, 2007 | Acer Aspire T690 (AST690UP820A) PC...
Software won't work with vista
Uninstall Windows Vista. Do a fresh install of Windows XP Professional Sp2. Download XP drivers and install camera. Many software programs have trouble initializing in Windows Vista. Good luck!
Oct 12, 2007 | Microsoft LifeCam VX-6000 Webcam
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
