Question about Toshiba Computers & Internet
I am having a problem with my Toshiba Satellite A135 Laptop. It will not boot up and it says Media test Failure check cable. Does this mean my hard drive went out?
    President:
  • Toshiba Master
  • 1,314 Answers
Most likely, yes. First check the cabling and make sure the cables are tight on the hard drive and the motherboard. If they are, then your hard drive is bad.
Posted on Jun 29, 2008
Problem with my Laptop
Maybe its a hard disk problem or a software issue. Do you have a boot disk? Try this Download Hirens BootCD 15 2 HBCD Fan Discussion Platform , that's a good tool to format disks and other things.
Mar 01, 2014 | Toshiba Satellite A135-S2276 Notebook
Pxe-e61
PXE-E61 ERROR
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an USB mass storage device and you cannot open the various folders and fileson this drive, then this confirms the hard drive is faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Aug 06, 2012 | Toshiba Satellite A135-S4527 Notebook
Toshiba satellite pro l450-13q PXE-E61 media test failure check cable
This indicates hard drive issues, or windows files have been corrupted. If you have a backup disk try and load windows, no change! have the hard drive tested for possible replacement.
Jul 08, 2012 | Toshiba Satellite Computers & Internet
When i start my lapt top i get black screen that reads intel undi,pxe-2.1 (build 082) for real tek rtl8101e/8102e pci-e enthernet controller v1.07 (080320)pxe-e61 media test failure,check cable pxe-mof...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Dec 07, 2010 | Toshiba Satellite Laptop
I keep getting intel undi pxe-2.1(build 0892) copyright (c) 1997-2000 intel corporation for realtek rtl8100/8101e fast ethernet network adapter v1.02 (060510) pxe-e61 media test failure check cable...
Your laptop is trying to boot via LAN(network). Possible the HDD is not being detected by your system that is why it could not boot to windows. Try to boot up without the ethernet (your internet cable) connected to it and see if it works. If not, you may have a bad HDD.
Hope this helps.
Dec 19, 2009 | Toshiba Satellite A135-S2276 Notebook
Black screen says PXE-E61 Media test failure, check cable, Operating System not found. I hear wierd sounds from the computer.
Sounds like it could be a bad hard drive. With your laptop turned off, take out the hard drive and put it back in and make sure its nice and snug.
Then go ahead and turn on the laptop and see if you can boot back up into windows.
If you can't get into windows and you get the same message then boot up the laptop and go into the BIOS by pressing F2. When you get into the BIOS look and see if your BIOS is recognizing the hard drive, if it's not seeing the hard drive then that means your hard drive is bad and would need to be replaced.
If your hard drive is showing up then that means you have corrupt system files and you'll need to restore your laptop back to factory defaults with your recovery cd's.
May 23, 2009 | Toshiba Satellite M45-S169 Notebook
Boot failure
y first guess is that something is wrong with your motherboard. Start with checking that. Then if that is ok, check your hard drive because it may have gotten corrupt or even crashed. If that is ok, try reformatting your hard drive and reinstalling your operating system. Hope this helps.
Sep 13, 2008 | Toshiba Satellite A135-S4527 Notebook
My Toshiba Satellite A135 is having a bad problem. it will not boot up. It says Media test failure check cable.. Does this mean my hard drive went out?
This message is primarily seen when the PC is attempting to boot from a network, and that network connection is no longer present. The error message would read PXE-E61: Media test failure / Check computer. Is this your message?
If it is, you need to go into the BIOS, and make sure that the sequence is 1) CD-ROM 2) HDD 3) FDD (if you have a floppy) 4) LAN (if you choose to leave the LAN there). Otherwise, switch option 1 and option 2. If the problem is the hard drive, however, putting the CD-ROM first will allow you to boot from your Windows CD.
Please post back if you need further help, otherwise thank you for using and rating FixYa!
Jun 29, 2008 | Toshiba Computers & Internet
A135 toshiba problem
did you try a system restore back to the day before and see if that helps you out. Let me Know if not you can go into the device manager and update your AC"97 Realtek drivers see if that works Ok try that to Let Me Know Please. And Happy Holidays
Dec 16, 2007 | Toshiba Satellite A45-S250 Notebook
PXE-E61: media test failure, check cable.
Save your self a lot of reading, do this first.
Check in BIOS rom for start up sequence and check if there is an asterist (!) in front of the hdd. If there is, it’s disabled. Select the hdd and press shift key plus “1′ This removes the ! and you can then use the hdd to re-format or….
Dec 15, 2007 | Toshiba Satellite A105-S4004 Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
