Question about Motorola Mobility RAZR V3c Cellular Phone
Sim card for some reason my razr phone BT50 won't read my sim card even though it's inserted correctly
    Brigadier General:
  • 7,752 Answers
You need to take it to a mobile service center to ahve the board check.
Posted on Jun 29, 2008
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
We insert sim card in cellphone, even though the cell phone dispaly "please insert sim card"
It seems that your cell phone is having trouble reading the SIM card. You have two options. First you can attempt to clean the SIM contacts on your device. To do this simply apply a small amount of alcohol to a Q-tip and gently rub over the gold contacts where the sim card normally goes, this will help to remove any dirt build up and provide a better connection. Second, contact your service provider and request a new SIM card. Sometimes SIM cards can go bad similar to a memory card failing. A new SIM card maybe all you need.
Nov 24, 2009 | Motorola Mobility L6I Cellular Phone
My razor is instantly turning off and sayin insert sim card but the sim card is correctly in
Check whether there is any fluff, dust or grease on the SIM card contacts or on the contacts in the phone body. Also check that the SIM card is properly aligned and a reasonably tight fit in its housing
Jun 08, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Says insert sim card when there is one in it
"Insert SIM" message is normally displayed on phones when a SIM card is not inserted on power-on or it does not detect the SIM card inserted.
Likely Causes:
  1. No SIM card inserted or inserted SIM card is damaged
  2. Inserted SIM card not positioned well in such a way as to make contact with the corresponding contact bridges on phone.
  3. Phone locked to a specific network and can only work on other networks when the firmware version is "flashed", that is completely changed to an unlocked version.
  4. The phone might be faulty (try with another good SIM, if you still get thesame message and its not one of the above reasons... it might be a transciever problem or the phone's SIM card slot's pins might be defective).
cheers.
Apr 30, 2009 | Sony Ericsson Walkman® W880i Cellular...
Motorola Razr says insert SIM card when it's already in there
You May Have Fryd Ur Sim Card Did U Try Puttin It In Any Other Phones Besides The Other Model?
Jun 14, 2008 | Motorola Mobility RAZR V3
Phone problems
I have had a new orange sim card for my SonyE W850i, however the new sim card isnt connecting to the phone (i think). I have noticed that the new sim card has a smaller 'chip?' on it. Could this be the problem. I have tested both the phone and the sim card on phones/ sims and they seem to work fine, just not when they are together. It seems as though they are incompatible (the phone is an orange make so there should be no problems there). The phone sometimes reads 'insert sim'. athough other times it works ok but then for no reason it breaks down to 'insert sim' again.
Mar 09, 2008 | Sony Ericsson W850i Cellular Phone
LG Prada - can't detect my SIM
Try the SIM in another phone. SIM cards go bad.
If it doesnt work in the other phone it will have to be replaced. I
THis can also be caused if you set up a PIN code and it was entered in wrong too many times and you did not use the right PUK code to unlock it. THis will permanently damage a SIM card.
f it does work in another phone then your phone is no longer able to read SIM cards. Check with the manufacturer for warranty info.
Feb 05, 2008 | LG Prada KE850 Cellular Phone
INSERT SIM
It might be that there is some corrosion on the leads that connect to the SIM card. You can try using a soft pencil eraser on the leads to see if you can clean them up, being careful not to get any debris from it in the phone to avoid any future strange complications.
Jun 19, 2007 | Motorola Mobility RAZR V3
URGENT: INSERT SIM - UNABLE TO CHARGE
dear for not charging first check ur charger if ok then check and clean charging jeck. even not ok chen the status of solder of jeck if it is unsolder then sold it. even if not ok then check the charging fuse 0 ohams if meter shows continuty then ok other wise replace fuse. for inser sim card check connection from sill card ic(like combice resistor)
Mar 25, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3c Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
