Question about Toshiba Computers & Internet
My Toshiba Satellite A135 is having a bad problem. it will not boot up. It says Media test failure check cable.. Does this mean my hard drive went out?
  • SouthernBabe Jul 02, 2008
    Thank you . you were very helpful, although it did not show a hdd so my hard drive most have went out. Thank you
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
This message is primarily seen when the PC is attempting to boot from a network, and that network connection is no longer present. The error message would read PXE-E61: Media test failure / Check computer. Is this your message?
If it is, you need to go into the BIOS, and make sure that the sequence is 1) CD-ROM 2) HDD 3) FDD (if you have a floppy) 4) LAN (if you choose to leave the LAN there). Otherwise, switch option 1 and option 2. If the problem is the hard drive, however, putting the CD-ROM first will allow you to boot from your Windows CD.
Please post back if you need further help, otherwise thank you for using and rating FixYa!
Posted on Jun 29, 2008
  • Cheryl Whalen Jul 03, 2008
    Unfortunately, this does happen with hard drives, and it is the worst thing for those of us who are so dependent on our day-to-day technology! I would encourage you, though, before you take a drastic step, such as tossing it out the window :-), to contact Toshiba's support online to ask them to walk you through a diagnostic. They have special utilities available which can help them to truly ascertain the state of your drive, and they may also be able to help with a replacement, perhaps a discount of some sort, since this machine is not that old! Best of luck, and thank you much for your kind response!
    smartsolve
Toshiba satellite pro l450-13q PXE-E61 media test failure check cable
This indicates hard drive issues, or windows files have been corrupted. If you have a backup disk try and load windows, no change! have the hard drive tested for possible replacement.
Jul 08, 2012 | Toshiba Satellite Computers & Internet
Toshiba satellite L455D-S5976 PXE-E61 media test failure...brand new hard drive What do I do???
You need to boot from an installation CD for the operating system, or the Toshiba restore set. New hard drives are completely blank when you purchase them. The computer is looking for something to boot from and cant find it, so it trys to boot from ethernet. Check your bios set up for boot order and boot devices. You might try disabling boot from network.
Hope this helps
May 04, 2012 | Toshiba Satellite L455D-S5976 Notebook
Downloaded The Recovery CD's Went To Boot Up Laptop, Realtek Fast Ethernet Network Atdapter come's Up, Then Media Test Failure,Check Cable. Keep's Repeating, Even When I Shut It Down & Reboot It.
Hello sir, hi, this error could be several, so check this one by one:
  1. make sure your pc boots on the hard drive, not floppy, or other boot devices.
  2. If you are setting up windows boot from the CD drive.
  3. check your HARD DRIVE, this may be due to failure, format it using a low level format utility like disk manager.
  4. re-seat Hard Drive cables. use another cable if necessary.
Sep 16, 2010 | Toshiba Satellite A205-S5879 Laptop
I have a dell and when i turn it on it says media test failure check cable and it says operating system not found
Sounds like the hard drive might be bad. Press F2 when you first turn on the laptop to go into the BIOS. Look in there and see if the hard drive is listed in there. If it is then that means that the operating system is corrupted and you'll need to reinstall windows.
If the hard drive is not recognized in the BIOS, then that means that the hard drive is bad and would need to be replaced.
Dec 10, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite 1805 s204 "media test failure, check cable"....
Did you install the windows system etc? If not boot from the system restore cd and it should work. If it will not boot from the cd-rom then more damage was done then was apparent and the unit would require factory qualified repair. Be sure of the cost before committing to repair since on laptops sometimes it is cheaper to replace the repair. Good Luck
Jul 21, 2009 | Toshiba Satellite A100-S8111TD Notebook
Black screen says PXE-E61 Media test failure, check cable, Operating System not found. I hear wierd sounds from the computer.
Sounds like it could be a bad hard drive. With your laptop turned off, take out the hard drive and put it back in and make sure its nice and snug.
Then go ahead and turn on the laptop and see if you can boot back up into windows.
If you can't get into windows and you get the same message then boot up the laptop and go into the BIOS by pressing F2. When you get into the BIOS look and see if your BIOS is recognizing the hard drive, if it's not seeing the hard drive then that means your hard drive is bad and would need to be replaced.
If your hard drive is showing up then that means you have corrupt system files and you'll need to restore your laptop back to factory defaults with your recovery cd's.
May 23, 2009 | Toshiba Satellite M45-S169 Notebook
Boot failure
y first guess is that something is wrong with your motherboard. Start with checking that. Then if that is ok, check your hard drive because it may have gotten corrupt or even crashed. If that is ok, try reformatting your hard drive and reinstalling your operating system. Hope this helps.
Sep 13, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba satellite 1115-S103 I can't boot up
It seems like your computer is booting from the network. This means that it is not detecting the Hard Drive. This error shows up when the hard drive is already busted or is not working anymore. You'll need to call toshiba for repairs or just get a brand new hard drive and install it yourself. It's pretty simple.
Aug 26, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Toshiba
welcome to fixya
In the bios, set the NIC entry to "ON (PXE off)" and remove the option of PXE boot from the boot sequence. Make sure all IDE devices are set to cable select (hard drives, CDROM, CD-RW etc) and that only those devices you have present are set to AUTO in the bios.
this should fix the problem have a good day
Jul 13, 2008 | Toshiba Satellite A135-S2386 Notebook
I am having a problem with my Toshiba Satellite A135 Laptop. It will not boot up and it says Media test Failure check cable. Does this mean my hard drive went out?
Most likely, yes. First check the cabling and make sure the cables are tight on the hard drive and the motherboard. If they are, then your hard drive is bad.
Jun 29, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
88 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
