I have an epson color 880 printer, and my yellow color does not print. The hole seems to be clogged. What can I do?
  • Anonymous Nov 29, 2008
    yellow will not print
  • 691 Answers
See my past post regarding intensive head cleaning. This should help to get you going again:
http://www.fixya.com/support/t138226-printer_not_printing
Posted on Jun 29, 2008
Can i use this printer to print to paper tranfer?
Epson Stylus Color 880 InkJet Printer can print on different kinds of media, including "Iron-on Transfers".
See this brochure for details.
Sep 06, 2010 | Epson Stylus 880 InkJet Color Printer
My Epson color printer 880, prints erratic and very small print in a light black and sometimes blue color
Did you use Epson Genuine Cartridges? Brother Genuine Cartirdges????
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE
BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
Dec 17, 2009 | Epson Stylus 880 InkJet Color Printer
INK JET PRINTER NOT PRINTING RED - GREEN HUE ALL OVER
the mixture of red is a combination of magenta and yellow ink or toner, if either one of these color is out of quantity or not working, chances are you will not get the right color. hope this helps.
Nov 19, 2009 | Epson Stylus C88 InkJet Photo Printer
Despite print head and nozzle cleaning, and a new epson color cartridge my Epson Stylus color 880 wont print in color. I've ran the software utility for head and nozzle cleaning as well as using the...
In desperation tried another new cartridge and it worked perfectly first time: I suspect the first was faulty so off to retailer for refund ASAP. At 30+GBP they dont come cheap!
Oct 22, 2009 | Epson Stylus 880 InkJet Color Printer
Epson 880 not printing in color
Was gone for the weekend.
Yes, the grayscale option gives you black and white or black tank printing only.
If you go to start menu, control panel, printers, right click your printer there is the option to print test page. In the upper left should be the windows logo in color. If you don't have that and you know you've removed the protective tape for the bottom of the color cartridges and when doing the nozzle checks "you have color?", then you probably need to reinstall your printer driver.
Is your printer connected via a USB cable, a thin cable with a flat connector at the PC and a square connector at the printer. Then, let me know. Send me your printer model from the back of the printer model sticker and I'll send you the instructions and a link to the current driver as well as a program link to download a system registry clean up utility that's free to use and can clean up from an uninstall of your printer.
Regards,
Worldvet
Aug 09, 2008 | Epson Stylus 880 InkJet Color Printer
Found the answer. For some reason, my computer accepted a Mac driver. It called the printer Epson Stylus COLOR 880 (M). I went back to the original installation disk; thereafter, I had two printers, one without M, one with M, and deleted the M printer. All is working fine now.
Color light will not go out
remove the cartridge close the printer, then again turn on printer and put the cartridge back effectively..
Jun 18, 2008 | Epson Stylus 880 InkJet Color Printer
Epson won't print and all lights flash
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
Mar 15, 2008 | Epson Stylus 880 InkJet Color Printer
Yellow will not print at all, black and other colors print OK, cleaning print head does not solve the problem
Probably a printing cartridge problem
I had the same problem and fixed it by replacing the ink cartridge
Dec 01, 2007 | Epson Stylus 880 InkJet Color Printer
100 people viewed this question
jasbo
jasbo
