Question about Sony KDS-60A2000 60" HDTV
No picture, but sound - Lamp shuts off and on intermittingly
Recently, the projection lamp on my KDS-60A2000 began to shut itself off then turn back on for no apparent reason. This problem is not source specific. It occurred while watching basic cable TV, DVD and gaming.
The sound is still there, but the picture.
What is causing this to occur? Do I need to replace the lamp?
Tim from Royersford, PA
  • 5 more comments
  • rbshevlin Aug 08, 2008
    I'm having the same issue with my KDS-60A2000. Is this indicative of the lamp stsrting to go or does it point more towards an issue with the lamp controller board? I cal Sony and they were no help at all (had me do a power rest and when that did work they told me to have it serviced).
  • TheGhost23 Aug 12, 2008
    I am also having the same problem....it's really freaking aggravating..Anyone have any ideas?
  • Anonymous Aug 31, 2008
    when it first comes on,it has picture,then it goes out but sound is still there.it does this for about 10-15 time, then picture stays on with no problems,until you turn it off and back on.can,t see how it could be a lamp.
  • Anonymous Sep 07, 2008
    I am having the same problem was watching tv on basic cable, picture went out, but I still have sound, turn the tv off then back on, first the green light was blinking, then the lamp light starting blinking red, does this mean my lamp has went out?
  • Anonymous Nov 04, 2008
    Yes, I'm having the same issues. The picture just goes black for 5-6 seconds but the sound still comes through. It happens over & over again every 2-3 minutes. It is really annoying. I tried using the online tech support and after an hour chat, they told me to reset the tv. They were of NO assistance.
    I'm really beginning to question whether or not to purchase any more Sony products. I've had numerous problems with Sony products such as a digital camera, PS3 (on my 3rd replacement), and now my HDTV. Their support is just horrible. It's like they they just don't even care.....
    If anyone knows how to correct this, please post.
    Thanks !
  • jshaw65 Nov 24, 2008
    Same problem but what is the fix????
  • RM30 Dec 04, 2008
    same problem with KDS-60A2000. 6008 hours on bulb--but picture not dimmer when it's on
Just wanted to let you know that I have solved this problem on my set, I couldn't find a straight answer anywhere so I took the plunge and purchased a new lamp for about $140 on electrified.com and it did the trick!!! Good luck to you!!
Posted on Jan 11, 2009
  • 24 Answers
Replace lamp and reset timer in customer menu.Common problem with SOny.
Posted on Jan 10, 2009
Anyone find a solution to this problem? I am having the same issues with my KDS-50A2000.
Posted on Sep 05, 2008
Sony KDS-60A2000 - no sound.
If you are lucky, a new lamp will restore the sound as well otherwise you may require a new ballast unit as when the lamps explode, the supply board sometimes destroys itself.
Mar 19, 2014 | Sony KDS-60A2000 60" HDTV
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
Aug 04, 2012 | Sony KDS-R60XBR2 Television
Sony kds-60a2000 power light flashes 5 times, no picture
5 flashes - Lamp Driver - (lamp driver faulty)
This is the error code that usually means the ballast (it is the power supply for the lamp) is bad.
SD TECH
Apr 20, 2012 | Sony KDS-60A2000 60" HDTV
How to reset sony tv KDS.60A2000 after replacing lamp so the warning doesn't keep coming on
With the set turned off:
RESETTING THE LAMP TIME
When replacing the lamp, use the following to reset the lamp time.
1. If the Self-Diagnostic screen is already displayed, proceed to step 4.
If not, Power off (Set to Standby mode).
2. Press DISPLAY Channel 5 Sound Volume -
POWER
3. To access the Lamp reset, press 5 until the TIME category displays.
4. Press 1 until the RSET item displays.
Mar 01, 2012 | Sony KDS-60A2000 60" HDTV
My sony is turning on and off when I turn it on. The picture and sound appear and disappear. What is wrong and do you have the part..
The most common cause of picture disappearing and returning in a Sony LCD Rear Projection TV is a faulty bulb. Replacing the bulb is the first step in troubleshooting this type of problem in KDS-60A2000 and all other Sony Rear Projection LCD TVs.
Sony Lamp Gallery
shows all Models and Lamps for Sony Rear Projection LCD TVs. KDS-60A2000 uses XL-5200U Lamp.
easyab
May 06, 2011 | Sony KDS-60A2000 60" HDTV
STANDBY INDICATOR LIGHT BLINKS 15 TIMES WHEN TV IS TURN ON NO PICTURE OR SOUND
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator.But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.
Dec 05, 2010 | Sony KDS-60A2000 60" HDTV
My Green power LED is flashing continuously.. no
Ur power supply board is dead,need a new one.
Sep 30, 2009 | Sony KDS-60A2000 60" HDTV
Sony rear projection tv picture going on and off
change the lamp is is too weak to operate properly.
Sep 20, 2009 | Sony KDS-60A2000 60" HDTV
Sony Lamp Cycles Off and On
Bad lamp>replace lamp and reset timer in customer menu .Common problem with SOny.
Nov 24, 2008 | Sony KDS-60A2000 60" HDTV
Sony KDS-60A2000 60" HDTV Logo
314 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
