Philips 170n4 locked screen display that only comes on when menu button pushed, goes off when released, sceen brightness zero, auto locked also
Push "OK" button for more than 10 seconds
Posted on Apr 22, 2009
My monitor's brightness menu stays always popped up
check the button which get stuck up, clean it with electronic contact cleaner.you will need to remove the back cover to access the button panel.
Oct 15, 2012 | Philips 170S6FS 17" LCD Monitor
Just got the phone today, it was acting fine until I disconnected the charger. Now the back light goes out after a couple seconds every time I try to use it. The light comes back on when I press the...
Try changing your display time out to something longer. Select menu-> settings-> display -> screen timeout -> pick something longer.
You can also set your brightness to not automatic. Within the same display menu, select brightness and uncheck the automatic brightness box. See if that works.
Lewis
May 15, 2011 | Motorola Mobility CITRUS Smartphone
The sceen say`s osd lock out and also the menu screen for the monitor is stuck on . The menu+- and auto set buttons wont respond
Try unplugging it for 1-2 minutes & try again. If not & it's a crt monitor not lcd then toss it & buy a new monitor. If it's an lcd,check the maker's website for additional info.
May 12, 2010 | Computers & Internet
Cannot remove the brightness window that pops up on my Philips 190V monitor.
2 solutions (both worked in my case in different screens)
1 - Place a big clip (see photo) locking the [Auto] button before turning on the monitor. If you do so and the button stays pushed the menu will not appear.
2 - Unplug the monitor and pull out the [Up Arrow] button or the one that pops up the menu. A sharped knife and pliers will do. It sounds crazy but it worked in my case.
I'd recommend to try solution #1 first.
No warranties but it worked in my case.
flanagan!
Jan 19, 2010 | Philips 190V6FB 19" LCD Monitor
Philips 170S LCD - OSD locked and unable to remove display from screen, unable to adjust. Locked on Brightness setting which continually drops to 0. Any thoughts on how to fix?
It kind of sounds like one ore more of the buttons are stuck. Any chance something got spilt on them? Try pushing all the buttons repeatedly to see if any feel different or stuck.
Jul 01, 2009 | Philips 170S7FS 17" LCD Monitor
My aopen f2925 monitor has a green tint.
The solution: hidden menu within the main menu itself. Hold the Menu button down while pressing Power to power on, and release power button only when the screen comes up, still holding the menu button. The menu will appear and there will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. My green/yellow tint went away! Now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Apr 08, 2009 | AOpen F70PS 17" Flat Panel LCD Monitor
BRIGHTNESS window keeps appearing
try to clean the board and check for loose board solder! also check all tact switches!
May 30, 2008 | Computers & Internet
Osd main controls locked/unlocked pops up every 5 seconds
Press the Menu button ( marked OK) for one minute, or more, and a blue/red menu list should appear on screen.
Using the adjust button (immediately to the left of the OK button) by pressing the arrows at each end up or down as required you can enter the menu and select an action by scrolling.
At the end of the list of possible adjustments on the left of the screen (brightness, contrast, etc) is the Reset section.
On the righthand side of the screen is a flashing Yes No choice which automatically alternates.
The trick is to select the Reset choice on the left and while selected press the OK button when the Yes alternative on the right of the screen is flashing.
You VDU should then Reset and all will be well.
Mar 26, 2008 | Philips 190B6CB/27 19" LCD
Computers & Internet Logo
David Payne
David Payne
