I have to hold the keys down unusually hard to get them to type and the fingertouch mouse is not controlling correctly
  • gatorgail Jul 01, 2008
    solution seems to have worked.
    Thank you so much.
  • 13,433 Answers
This can either be a problem in your software or hardware, but as the keys do get pressed eventually, I suspect there is a problem in your windows. I would recommend using your recovery cd/dvds or reinstalling your windows.
If this doesn't solve the problem it may be hardware and would require a diagnosis / checkup and possibly repairs.
Let me know how it turns out.
Thanks,
Ekse
Posted on Jun 29, 2008
My email has changed its font size that I can hardly read it. Where do I go to enlarge the email size so I can read my emails
Try to hold down the Ctrl key and rotate the mouse wheel on top of the mouse. The arrow keys will also do it while holding control key.
Mar 31, 2015 | Dell Computers & Internet
How to shrink desktop screen to normal size on mac
Hold down the Control key on the keyboard, and scroll with the mouse wheel (or scroll ball if you have a Magic Mouse).
Nov 07, 2014 | Apple 24" iMac Desktop
How to open unlock mouse pad
Click the Windows "Start" button in the bottom-left corner of your desktop.
Scroll up and click "Control Panel."
Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner.
Click the "Enter" button and then click the "Mouse" link.
Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have.
If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button.
If you are under the touch pad tab, click the enable button.
Click the "Apply" button and then click the "OK" button
or
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box.
Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
Sep 22, 2012 | Computers & Internet
I have a ProBook 4520s. I am trying to do print screen by preesing the fn and insert keys. Its not copying. The machine is 5days old.
Most cases, when you try to get a screen shot of your computer by using print screen, it only adds it to the clipboard.
1. Hold "Fn" key and press "Insert(prt scrn)".
2. Hold the Windows key and press "R".
3. In the dialog box, type "mspaint", without the quotations.
4. Once paint opens, hold ctrl (Control) and press "V".
The image of your screen should paste into paint.
May 23, 2011 | HEWLETT-PACKARD HP ProBook 4520s Notebook
Need help with keypad and mouse not responsive. While visiting my my 78 year old dad he took it upon himself to try to turn off my notebook acer aspire 3000 while I was away from it. He said he just...
make sure you have the correct mouse selected control panel mouse hardware
might have to uninstall the drivers then reinstall the drivers
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Dec 05, 2010 | Acer Aspire 3000 Notebook
How do you set the time on the Logitech keyboard MX3200
Please do the following:
1. Make sure that the time and date are shown on the LCD. If necessary, press (FN + F9) until the time and date are shown on LCD.
2. Press (FN + F10). You are now in 'Set mode' - you can exit this at any time by pressing the Esc key.
3. Set the correct hour by either typing the numbers on the numeric pad or using the cursor up and down keys, followed by Tab or Enter.
4. Set the correct minutes by either typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
5. Choose either 12-hour clock or 24-hour clock by pressing the cursor up or down keys to switch between the options. Then press Tab or Enter.
6. Set the correct month either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
7. Set the correct day either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
Jan 18, 2010 | Logitech Cordless Desktop MX3200 Laser...
Font size decreased accidently "somehow"
Hold down the Ctrl key and move the mouse wheel. That should adjust the font size for you.
Nov 24, 2009 | Logitech Cordless Mouse
Microsoft Wireless Laser Mouse 6000 v2.0 x key stuck
This seems to be a "systemic" fault with this product.
Throw it away, buy a replacement and forget Microsoft!
Nov 09, 2008 | Microsoft Wireless Laser Mouse 6000 v2.0
Highlighting
you may have turned on click-lock. You can disable this feature in Control Panel, under Accessibility Options. Click Lock helps people who have a hard time holding the mouse button while dragging the mouse across the screen by holding the mouse button for them
Oct 02, 2007 | GE Wireless Optical Mouse
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
