Question about LG Refrigerators
The ref/freezer temp control goes from 1 to 5. Is one or 5 the coldest?
  • 828 Answers
Yes, the highest number would be the highest level of cooling. Normally you would set the controls to mid-range and adjust from that point to your satisfaction.
Posted on Jun 29, 2008
Freezer works fine but fridge side stays at about 45 degrees
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Jan 10, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Freezer compartment of refrigerator not freezing
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Ge profile buttom freezer cold refrigerator hot
Dec 17, 2008 | GE Profile Arctica Stainless Steel Top...
Fridge not working, freezer is
First, I think it’s important to know that the Ref area has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting up to the Ref side?
If you want mor info to DIY check out: ronbuice.com
Dec 16, 2008 | GE GBS22HCP Bottom Freezer Refrigerator
Refrigerator side is freezing contents
If your settings are right then the cold control switch is the problem
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Consul gas fridge .freezer working fridge not.
Dec 15, 2008 | Refrigerators
Refrigerator/freezer not staying cool
If there is no frost on the freezer side it may be low on coolant.
Dec 03, 2008 | Admiral 26 cu. ft. Side-By-Side...
No cold air coming into the fridg
You can melt this ice manually for a temp fix but the defrost system needs to be checked. Turn it off, take everything out of the freezer, use a hair dryer to warm the back wall. Do this for as long as you can without anything thawing then put it back in, turn it on and you will be good for a couple of days.
Nov 21, 2008 | Jenn-Air JCD2389G Side by Side...
Frigerator is freezing.
Now, why is too much cold air getting over to the Ref side?
1. The little door is open too much.
2. The cold control is bad causing the compressor to run too much.
Nov 13, 2008 | Frigidaire FRS26R4A Side by Side...
Warm refrigerator
You can manually defrost for a temp fix. Turn it off, take everything out of the freezer, use a hair dryer to warm the back wall. Do this for as long as you can before anything starts to thaw. Put everything back in, turn it on and this should last a couple of days.
Oct 28, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
163 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
