Question about Watches
I just replace the battey on a g shock dw 9050 and i cant set the time i shows the time but at the top it flashes TYO
  • 109 Answers
Did you ground the battery? If not you need to open up the watch and find the ground and take a tweezer and touch the top of the battery and the ground.You should be able to move on from there, if not are your buttons making contact with the movement?
Posted on Jun 29, 2008
Casio g shock dw 9050
Use the manual. Read the section about changing the Time Zone. TYO is for Tokyo. To download the manual you need the module number, a 4-digit code on the back of the watch.
world casio com CASIO
Jan 29, 2014 | Watches
I dont know how to set it to 12 hour. for my Casio G-shock 1289 DW-6900CB
Press the "adjust button" until display flashes.By pressing "mode" button
go to 12/24h setting.Press the lower left button to switch between 12/24h.
When finished press the "adjust"button again.
Jan 21, 2011 | Casio G-Shock GW500A-1V Wrist Watch
I bought my son a watch for Christmas and there were no instructions that came with it and for the life of me I cant figure out how to set the watch of the time and date.PLEASE HELP thank you Deb
Hi dibbles624,
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
Jan 03, 2011 | Timex 1440 Nylon watch
Casio g shock dw-9052 how to change from military time to standard time
You can get instructions from the Casio web site which will tell you how to set your watch..
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Feb 22, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
Setb time for casio g-shock
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps.
R/
David
Dec 05, 2009 | Casio DW-5600E-1VCT Wrist Watch
Spring poppedout on dw 6900 g shock. need a
This happened to mine, couldn't get a spring anywhere. But managed to fix it by using a staple which I cut to size, Works fine now.
Oct 23, 2009 | Casio G-Shock G7000D-8V Wrist Watch
I cant get my Casio DW-5600 to go into adjust mode ???????
in time mode just press left up button untill seconds will start to flash.... then check manual on this link bellow
http://support.casio.com/storage/en/manual/pdf/EN/009/qw1545.pdf
May 07, 2009 | Casio DW-5600E-1VCT Wrist Watch
Battery replacement for a G-shock.
The reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, as well. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Mar 24, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Set watch
I have a G Shock DW-004 made in 1997. I had this same problem, and I tried everything to change TO military time and back to standard time. I just read the bit to try and was about to do it. I pressed the top left button to get the time to flash, and hit the light button by accident (the one with the big G on it) and VIOLA! It changed to military time. So in my model, anyway, the G light button (under the display on the edge of the watch body) changed the time to military from standard and back again, when the time is flashing.
Feb 21, 2008 | Watches
Watches Logo
445 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
