Question about Electrolux Central Vacuum
Central vacuum motor
Circuit breaker attached to a board inside the vacuum shroud " clicks" rather than motor starting ?
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=113662&thid=720877
Central vacuum motor. Posted by knise on Jun 29, 2008 Circuit breaker attached to a board inside the vacuum shroud “clicks" rather than motor starting?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have a bad replay switch on the inside of the Electrolux Central Vacuum and it needs replacing. They are not too bad as per the cost if you are mechanically able but B4 you attempt to do that I would have it checked by a local vacuum cleaner central vacuum service tech just in case. I will give you the website and the factory phone number for the Electrolux listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 03, 2008
RESET ELECTROLUX 1590
I assume you're referring to the 1590 Aerus Electrolux Central vacuum? if so,and you're sure it's not a "breaker" issue at your breaker box and the reset doesn't work, chances are either the relay board inside needs replaced or more often, the motor itself if it's over 15 yrs. old. This is normal for motor replacement. I do replace them for my customers. Hope that helps!
Jun 23, 2014 | Electrolux Vacuums
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
Vaccum was being used and suddenly stopped. checked the filter, circuit breaker, and pressed restart button. still does not come on
To test the vacuum motor and circuit card, detach low voltage wires from vacuum. Using insulated needle-nose pliers, place points of pliers in each wiring connector. This should start and run the motor as long as the pliers are in place. If it does, the problem is elsewhere, If the motor doesn't run, either the motor, circuit board, or internal wiring is bad. It needs to be taken to an authorized Aerus Electrolux store for repair/s.
If the motor runs, the problem exists in the hose and attachments. Broken wiring, switches, and worn or loose wand connections could be the problem. If you are unable to test the hose and wiring for continuity, take the whole machine to the nearest Aerus Electrolux store for a free diagnosis.
http://www.aerushome.com/storelocator/
Jan 06, 2011 | Electrolux Central Vacuum
System quit working green light on
depending on the year of your machine, assuming it is the serenity blue, it may be the circuit board on the unit itself. The manual switch "should" start the machine, but if not it will be the circuit board inside the main unit.
however....
if your unit is the green one, it may be the motor inside the unit and/or the circuit board. Hard to say. I do not think that it is the motor as the circuit breaker should have popped out if it was the motor.
Regardless of the colour of the unit, if it is 5-7 years old or less, the unit should still be under warranty. home service calls and labour to install the motor would not be covered.
Good luck.
Nov 19, 2010 | Beam Industries 2775 Serenity Plus Central...
Vacuum starts up on its own. The only way to stop it is to unplug it, why is this happening?
The motor can only be switched on this way for 2 reasons. The circuit board inside the canister is bad or somewhere in the wiring in the house or in an outlet, a connection has been made in the low volt wiring, triggering the relay on the circuit board. If you unplug the low volt wiring from the canister and the problem goes away, then the problem is in the house, if the vac still turns on when the low volt wiring is disconnected then the problem is the circuit board inside the vac.
Oct 15, 2009 | Electrolux Central Vacuum
Beam Central Vac Breaker Pops
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=797869
Generic problem for all Vacuums
Posted by tinateggart1 on Jul 17, 2008
The breaker on our beam model 167 central vac popped while in use. Every time I try and restart it, it immediately pops again. What's the problem? Circuit board? Motor? Overheating?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Chances are it is the relay switch on the inside of the Beam Central Vac, if it was a motor, it would not turn on @ all. If it was a circuit board, it may or may not be turned on, but if it will turn on and then pop your circuit breaker than it probably is the relay switch. Please, check with your local Beam vacuum cleaner dealer in your area or contact the Beam website or cust serv @ the phone number listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
Electrolux central vac problems
I work on many types of units. If you electric floor brush runs but you have no suction then there is possibly a problem with the relay board that allows you to turn on the suction from the hose handle. This is a low voltage (24 V) switching loop circuit that will cause the 120 V motor in the unit to run.
Inside the wall valve are two brass pins. NOTE: there are 120V valves installed on some systems known as a Super Valve. A shock hazared exists if you work on that type of valve. That being said. In the round portion of the valve you can use a garage hose that has a 360 deg. chrome ring to test the valve. The ring completes the circuit causing the unit to power up and suction at the end of the hose. If the suction is weak, there is a colg in the pipe. If you hear no airflow, the relay inside the unit did not energize or the motor is bad.
To test: go to the unit and turn the switch on the side to "manual" if the unit turns on the motor should be ok. DO NOT RUN THE UNIT without and open valve. In some brands dammage to your motor will occure.
If the unit did not run, look for a small button near the switch. This is a circuit breaker for the motor. If it is poped out and you hear a "click" when you press it in there is most likely motor problems and someone should be contacted for repair.
Hope this helps!!
VR
Mar 07, 2008 | Electrolux Central Vacuum
Central vacuum
Check the motor brushes, they may be worn down and not making contact with the armature. There may also be relays and one could be bad.
Mar 03, 2008 | Electrolux Central Vacuum
Vacuum won't turn on!!
Some of these have a relay or circuit board down by the main motor that may have gone bad. Could have a problem with the circuit board in the hose handle, Could have a problem with the motor. Will jusy have to have opened up and checked. Go to Sears.com, click on parts, put in your complete model number, a parts list and picture will come up, maybe that will help you.
Feb 16, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuums Logo
152 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
