Back to:
Tags:
Electric Fans
Generic problem for all Electric Fans
Huntington Bay Ceiling Fan W/lights & Remote... (by 2 users)
posted by vonjon2 on Jun 29, 2008
nothing will come on. It worked fine the night befor but now nothing works. I put a new battery in the remote & still nothing. I have power to the wall switch. The fan is less than one yr. old.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by waf3r, posted on Jul 11, 2008
sharper image spire fan (SI868). Squeaking noises when highest power was turned on. Today fan started turning itself off after 2 seconds of being turned on. Now it won't turn on period.
Solution #1
posted on Aug 03, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I had a similar issue with my fans. The fix I came up with was my remote was faulty. An easy fix because I had 2 fans with the same remote.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Huntington Bay Ceiling Fan W/lights & Remote operated. # HD 361054:
I don't want to Accept this solution
Can you Help with these Electric Fans problems?
Hampton Bay 24002 Ceiling Fan
I can't find what size bulb I need and have taken one of...
Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
I just hooked up my new hampton bay fan and installed the...
Electric Fans
This is the best fan ever, you can't purchase one like it...
Aloha Housewares (93645) Ceiling Fan
i have a 42in ceiling fan and the switch broke i've tryed...
Hampton Bay 24750 Huntington III Ceiling...
I'm purchasing 2 model 24750 hampton Bay fans. I need the...
Loading problems.
Repair Service
Find Electric Fan Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
