There is a Cassette Micron Filter 60696.If you have a HEPA cartridge filter you need EUREKA's HEPA part 61500.In earlier models there is a micron filter instead of a HEPA filter--for that you need EUREKA's Micron part 60801. But if you have that HEPA filter, the manual says you have to use the HEPA filter to achieve the closed HEPA filtration system again.
SOURCE: belt
Turn vac over, take out 4 to 5 screws and the top cover will come off. The belt is a cogged belt #72393 and goes between the brush roll motor and the brush roll.
SOURCE: download parts and operators manual
This owner's manual is available on the Eureka website. www.eureka.com Type in your model # down in the right corner, search & buy accessories.Click go, then choose either the 402A or 402A-1. It is the same owner manual for either one.
SOURCE: Eureka Boss Capture 8803AVZ Bagless Upright Vacuum
First you need to checkl and make sure the roller brush is not jammed up and the belts is not slipping due to the brush not turning
SOURCE: I need hepa filter specification for eureka
http://www.eureka.com/servlet/FindOwnersGuide
"You will find your model number on a metallic silver-colored rating plate. It’s usually located on the back or bottom of the cleaner. Here is an example of a rating plate: You will find your model number on a metallic silver-colored rating plate. It’s usually located on the back or bottom of the cleaner."
"Not all accessories, supplies, owner's guides or Eureka program details are available online. If you can't find what you're looking for, you can call 1-800-282-2886 for assistance. Our Service Representatives are available Monday through Friday, 8 a.m. to 7:30 p.m. Central Time, and Saturday and Sunday, 10 a.m. to 6:30 p.m. Central Time. Our Service Representatives will need your vacuum's model number, so please have it ready when you call."
SOURCE: Can't find manual needed to see why brushes don't
Hi
Please visit http://www.eureka.com/parts.jsp and enter 450 into the first box on the page where you put the model number. This will gve you two options, one is for the PDF user manual, the other for parts.
Alternatively if you are trying to get into the drive belt locate four screws, two at the front and two at the back on top of the hood. Once undone, the hood should pop off easily to reveal the brush roll and drive belt. If the belt is intact check that the dust channel is completely free of blockages.
Dont forget to rate thanks!
You could call the EUREKA people too at 1-800-282-2886.
Eureka Boss bagless
