Question about Sony VAIO VGN-S460 Notebook
Ihave a Sony VGN-s120 Notebook,after running the system recovery disk.The computer crashes and will not boot.
  • albertsonpho Jun 29, 2008
    Ihave tried two sets recovery CDs at least twice. The computer shows a blue screen for a split second. In safe mode I get a message system not fully installed
    President:
  • 1,257 Answers
What have you done recently that might cause this? have you installed any new hardware or software? did any message popup telling you that the drivers might be incompatible ?
Posted on Jun 29, 2008
    Genius:
  • 1,689 Answers
Well two things, if the OS still won't run after recovery and a format / reinstall OS is the only way, you may need to get your files first from the HDD, like pictures, videos, music and all that, then once you reinstall your OS, you'll get your files and place them the way they were before.
there are a lot of free-wares around that will do the job for you, like these: (and if they're not free, you still get to try the trial versions)
http://www.datadoctor.in/data-recovery-software/ntfs-data-recovery-software.html
http://www.driverecovery.in/
http://www.data-recovery-software.net/
or better off, you may go to download.com (from CNET, a trusted site for me personally) then get a data recovery software.
so good luck, get a software, get your files, reformat the HDD and reinstall your OS, then get the PC files back, and you're good to go.
    Sergeant:
  • 243 Answers
Yes this is a Fault of BSOD when doing a system recovery. Best way to go is to reinstall your operating system completely.
  • Sony Master
  • 6,487 Answers
I think you may need to to reinstall your operating system since the recovery console didn't solve your concern....
Hope that helps........
  • Mark Gil
    Mark Gil Jun 29, 2008
    If you can boot to safe mode try running system restore from there. If not, boot to the XP CD and try a repair install (choose the second repair option). Try not to turn off the sytem until the repair is finished
  • Sony Master
  • 13,433 Answers
Attempt to run it again or if you have a setup cd to install your windows again.
Let me know how it turns out - something may have gone wrong in the last recovery.
  • Ekse Jun 29, 2008
    Doesn't sound good.
    Run memtest on it to test your memory (ram)
    http://www.memtest.org/
    You have to download a cd image and burn it on a cd then insert it on your laptop and it will test your memory at startup.
    It may be a hardware fault or just that the recovery cds aren't getting the job done.
    Do you have a original xp or vista cd/dvd you could use to do a fresh install on your laptop?
Hi I have a VAIO VGN-T350P laptop. The windows crashes and won't boot up and give me to insert the original Windows CD. But unfortunately I have lost the cd and I should use the recovery disk. Also I...
Go Into The Bios Change The Boot Status To Either Cd Or Usb Try To Boot up On That (Sounds like You Need a Copy Of operating System)What version need more Info !! Im here To Help Donald Deane MCSE,ASE,CPO
Jul 26, 2017 | Sony VAIO VGN-T350 Notebook
Sony Vaio VGN-NR498E recovery disk
Hello
Well, the recovery disks won't allow you to go to your present system. The recovery disks are designed to put everything back the way it was when you bought the computer, minus all your applications and data. If it's your data that you need then a reputable repair service like mine can slave your hard drive to another system and recover all your data (not applications), provided the hard drive has not electronically or mechanically malfunctioned. Again, a reputable repair person can tell you the status of the hard drive.
Thanks
Jan 07, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
I need VAIO® VGN-FJ170/B Restore Disks
You can create your own disc from the Vaio recovery center.
If the computer is no longer booting up and the Vaio Recovery center is no longer accessible, you can call sony parts center to check if you can buy a recovery disc for your unit
parts center 8004887669
Sep 23, 2009 | Sony VAIO VGN-FJ170/B Notebook
Sony laptop crashed. no disk included. what do I do
Start the computer hit f10 which will take you to the utility partition there you will be able to do a full system recovery. If you look carefully you will also see the option to recover data to a cd.
Good luck
Aug 15, 2009 | Sony VAIO VGN-CR220E/P Notebook
Sony vaio VGN FS 742W notebook Startup problem.When swithed ON,Vaio,Window XP screen appears and then window 'isass' appears & notebook swithes OFF automatically.Pl.advise solution for the above....
If Windows appears, and start booting, then the problem concerns the operative system and not the hardware.
That is good news, because all you need to do is using the original computer recovery disk, or finding a Windows setup disk to reinstall Windows.
To reinstall Windows, start the computer with the Recovery Disk or Windows Disk inside and chose Boot from CD when asked, then follow instructions.
Regards.
Aug 02, 2009 | Sony VAIO VGN-FJ270/B Notebook
Can't restore factory intallations and settings: Vaio VGN-FE880E
Are you doing DESTRUCTIVE recoveries or are you doing NONDESTRUCTIVE recoveries? Try another hard drive in the machine and recover to that. Nondestructive recoveries replace the operating system without destroying the personal data. Its possible the original problem is propagating over to the recovered systems. Do a destructive recovery. Understand any data not backed up will be destroyed. Possible the original problem was a trojan virus.
Mar 23, 2009 | Sony VAIO VGN-FE880E/H Notebook
Sony laptop VGN-N130G will not boot.
use any windows xp disk boot from it and use R key to repair windows then type fixboot
if helped rate fixya
Jan 05, 2009 | Sony VAIO VGN-N130G/W Notebook
Recovery Hard Disk Access
your recovery dics should not be a dvd, but a cd. look at all of your discs and make sure you are using the right one, if you cant find the right one call sony and ask them which one to use.
Aug 28, 2008 | Sony VAIO VGN-N130G/W Notebook
Does the fj270 recovery disk from ebay make the computer like new with a blank harddrive?
I am assuming you are going back to XP?
You will run into one major problem with this process, Vista is based of Windows NT which uses a NTFS file system. XP uses the old file system of FAT32, so just wiping the hard drive probably won't work. You will have to go into your partition and re-partition your hard drive before you intall the recovery disk.
If the recovery disk is designed for your computer then yes it will restore it to all factory defaults (including drivers and software that originally came with it.
If you are not sure how to do the partition then let me know I will try to guide you through it.
Mar 27, 2008 | Sony VAIO VGN-FJ270/B Notebook
Sony VAIO VGN-S460 Notebook Logo
61 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
