Question about Toshiba Satellite M35X-S311 Notebook
Wireless Connection I keep getting a message that says Windows cannot configure this wireless connection. If you want Windows to configue this wireless connections, start the Wireless Zero Configuration sevice. Please help, I cannot connect to the internet because of this.
  • Anonymous Mar 14, 2014
    windows cannot configure this wireless connection
    Problem Solver:
  • 11 Answers
Delete all aspects of this wireless installation.make sure wireless button is turned OFF, connect via wired. make sure you can get into internet function. ensure toolbar has an icon that shows ' wireless', disconnet wired cable and turn on the wireless button. do a ''connectivity doctor scan' and see if any wireless devices in your area for secured/non-secured status. turn off wireless for now and reinstall device software driver.
Posted on Jun 29, 2008
Get Message - "Windows cannot configure this
Odds are you have some other software that is over ridding the Windows wireless configuration utility. Look in the bottom right hand corner of your screen near the clock and check each program listed there to see if there is another wireless configuration program running.
Feb 28, 2011 | Intel PRO/Wireless 2100 MiniPCI 802.11b
I've lost my PCI bus which only supported a network card and a sound card. Now the only way to access my Linksys WRT600 Router is by USB wireless. We have two WUSB54G adapters one not being used so I have...
Go into your router configuration.
Take off all security so that anyone can join your network.
Set up your USB wireless and, once working, put the security password back on.
Dec 30, 2010 | Linksys WUSB54GC 802.11g/b Wireless...
When I try to connect using Wireless Network connection the following error message now appears: "Windows cannot configure this wireless connection. If you have enabled another programme to manage this...
Your obviously having a network configuration issue. Go into Network icon, set up a network connection, make sure you have Wi-Fi and that your laptop is picking up the signal then manually set up or scan for the wifi access point, your laptop should pick up the access point and a name should appear for that wifi spot. Once that is done then you can rename your access point with your name or HOME whatever you like, its hard to explain through here.
Jun 13, 2010 | Acer Ferrari 4005WLMi Notebook
Windows cannot connect to the wireless network
I would remove old cache wireless network connections. Example is when you once connect to a free wireless access at Library or Coffee Shop. Windows save all of these profiles and this will cause problems connecting. Then use Microsoft Wireless Troubleshooting resource:
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-problems-finding-wireless-networks
Good luck
Dec 30, 2009 | Intel PRO/Wireless 3945ABG Network...
When I try to run the Dell Wireless Configuration Utility from the control panel I get the following error message:"The wireless network adapter could not be accessed. This application may have diminished...
Well Sir in this case i will advice you to disable the Dell Wireless Configuration Utility and instead use windows utility for a successful connection.
For disabling dell configuration utility follow these steps:-
1)Open dell Wlan utility , it will have five tabs at the top labeled wireless networks , link status , site monitor , diagnostics and information.
2)Click on wireless networks tab and uncheck the first option which says , "Let this tool manage your wireless network" then click ok or apply at the bottom right-hand side corner of the screen.
To Enable Windows Utility for Windows XP follow these steps:-
1)Open the Control Panel from the Start Menu.
2)From Control Panel click on network and internet connections and then open network connections from there.
3)Right-click Wireless Network Connection and choose Properties.
4)
Click on the Wireless Networks tab and if unchecked , then check the box for Use Windows to configure my wireless network settings. Then click OK.
5)Right-click on Wireless Network Connection, Select View Available Wireless Networks.
6)
This will lists all the available wireless networks in range. Select your network from the list and click Connect.
7)If you are connecting to a secured wireless network, you will be prompted for a Network key. Type the Network key(which is the password for the wireless network) and then click connect.
8)Your network list should now display your connection status. If you are connected and your router is setup for internet access, you are ready to connect to the Internet wireless.
This Link will guide you through the steps:-
http://kb.netgear.com/app/answers/detail/a_id/111/kw/wireless%20zero%20configuration/r_id/100109
Nov 24, 2009 | Computers & Internet
Configure wireless connection on acer aspire one
Some people like to disable the zero config service for security purposes. Here's how to re-enable it (assuming you're using Windows XP) -
  • Go to Start then select Run (or use (WinKey+R key combo)
  • Put in services.msc
  • Keep hitting the W key until Wireless Zero Configuration is highlight.
  • Double click to bring up the properties of this service
  • You want to make the Startup type set to Automatic and then also click the Start button (next to the stop button and below the "Service status" line.
When you're done just push ok to get rid of the properties window and you can close the services screen. You should now be able to connect to the wireless.
Oct 06, 2009 | Acer Aspire One PC Notebook
My computer when connected to wireless network keeps showing the message "Windows cannot confugure wireless network." It becomes difficult to get it to work.
You may want to disable the built-in utility of the network adapter and let the wireless zero configuration of Windows take up the task of managing the wireless network.
Jun 08, 2009 | IBM ThinkPad T40 2373 Notebook
Wireless cannot connect
HELP I MIGHT CAN IF U SEND ME AN EMAIL WTH UR NUMBER IF U CAN>
Nov 10, 2008 | Toshiba Satellite P105-S6024 Notebook
Wireless connection
HI there - Are you using windows to configure the connection?? I always suggest that you do becasue I find other 3rd party software isnt always as good / easy to use.
try going into your wireless settings
Start >> Connect To >> Show all connections >> Right click on Wireless network connection >> Click Wireless Networks tab
Ensure that "Use windows to configure my wireless network settings" is checked.
Jul 01, 2008 | Computers & Internet
Built in wireless not workong
vista?? or XP?? ensure that the wireless adapter is turned "ON"
Dec 28, 2007 | Compaq NX6110 TFT XGA Notebook
Toshiba Satellite M35X-S311 Notebook Logo
506 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
